Old 04-11-2008, 03:21 PM   #1 (permalink)
what doe's the bypass valve on the SC do??
i need to better understand it. thanks carl
User formerly known as 4carl
carl is offline   Reply With Quote
Old 04-11-2008, 05:34 PM   #2 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
The bypass valve bleeds the boost off to the intake side of the SC. This is typically manifold vacuum controlled. It is there to reduce parasitic loss when boost isn't needed. It doesn't have anything to do with power.
'05 AR Mods: Stebel Nautilus horn; tesprit's rearview mirror; Custom Interior Pictures; PPF full front clam wrap
Old 04-11-2008, 05:55 PM   #3 (permalink)
Doe's it cause any increase in the pressure in the crankcase? carl
Old 04-11-2008, 08:48 PM   #4 (permalink)
You bought a Locust?
wildwhl's Avatar
carl -
It would seem, to me, that when the engine is under boost, there would be greater crank case pressure. But what do I know, lol.
WW
She's gone.
wildwhl is offline   Reply With Quote
Old 04-11-2008, 08:55 PM   #5 (permalink)
2-Y-CHROMOSOMES's Avatar
When enough intake passes thru ie;air it closes the valve and boost is on.
This why you can cruise with a supercharger it is not on boost ....but when you gun it the intake close the valve and it is boost on.
2005 Elise 250 whp | Forcedfed Custom Intercooled Supercharger | EFI | Forcedfed Street Header | Fujita CAI | TB Bypass | Toda flywheel | ACT HD Clutch | Forcedfed Prototype Exhaust | Micromirror | Forcedfed Half Carbon Splitter | Greddy Catch Can | ForcedFed Engine Damper
2-Y-CHROMOSOMES is offline   Reply With Quote
Old 04-13-2008, 01:10 PM   #6 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
I don't see why it would. When the valve is open, the SC rotors are, basically, just freewheeling so the entire intake tract is the equivalent of an NA one. When the valve is closed, the SC is providing whatever boost it normally would at any given throttle opening, as though there was no bypass valve.
Old 04-13-2008, 02:38 PM   #7 (permalink)
wildwhl's Avatar
Just my humble opinion, but I believe increased cylinder pressure = increased crankcase pressure.
I know that on a previous vehicle of mine, the blowby went way up with the addition of an MP112, and dropped way down once it was removed (aka catch can is necessary and helpful in FI applications).
WW
She's gone.
Old 04-14-2008, 11:45 AM   #8 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
WW
Agreed. My answer was to his question about whether the bypass valve causes increased crankcase pressure. Clearly any FI could.
Old 04-14-2008, 11:52 AM   #9 (permalink)
wildwhl's Avatar
Sorry, ChrisB, I read this to mean that you didn't feel crankcase pressure would increase...my bad...
WW
She's gone.
