LinkBack (1) | Thread Tools | Display Modes |
#81 (permalink) | |
No Acceptable Substitutes
Also, and not surprisingly... the flow through the intercooler seems proportional to the smallest cross section in the ductwork... so doubling would be good...
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Switchable DRL, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Carpet Bling, Lotus Trim Shop leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness |
#83 (permalink) | |
Plug Whisperer
| '05 GG LSS Elise | Track Chariot | Too Many Mods to List | Collaborative Boosting by Ronin & S111 & BOE | EFI Standalone Engine Management | ClamHinge |See my car here:http://www.boefabrication.com ----->Last Updated: 6/15/08 1. Do the Right Things Well and Good Things Will Follow 2. Advice is often something we ask for when we already know the answer and wish we didn't |
#84 (permalink) | |
Madness...
I know there are concerns that it would block airflow but in this case and it's just my own guess, since the bottleneck at the rear clam opening is so great, the fans can only help. At speeds, (cup roof) air rams through but is choked at the fettle location, my theory is the fans help pull that stream and push through the IC. The fans I chose, if mount the way I want them to, on both sides will still leave a small open unobstructed IC space in the middle. Im no pressure engineer but imagine there's some turbulance on eighther side of the shroud, and the fans for the IC (for the exige config) can only help. I'm hoping innovate will come with the IAT parameter update soon so I can log this. I have some thermo couple but don't want to put these direct in the charge stream if dont have to... On a seperate note, I wonder how much timing changes from the ecu are a result of IAT and how much are result of other parameters like ECT... ?
91 NSX, 3.2L ITB (in progress) 93 Supra TT 95 BCNR33 GTR, 2.8L TT 00 s2000, 2.2L 08 Exige S240 |
#85 (permalink) |
My comment with the 240S roof are as follows :
- When the car is at speed... will the heat from the radiator rise, glide on the windscreen and go straight into the roof ?? this is just my theory, but if you are driving and stick your hand out the windscreen (i tested my theory), you can feel the heat is passing thru, which questions will more hot air be going into the engine bay than cold air ?? I am sure the Lotus guys have windtunnel tested the roof but I am unsure if its cold air we are catching though
Krypton Green Exige with Komo-tec 250S Photo Gallery : http://s229.photobucket.com/albums/e...omo/?start=all Modification List : http://s229.photobucket.com/albums/e...-SIMONLAU3.jpg |
#88 (permalink) |
Water cooling?
This may be a little over the top, but has anyone tried a setup whereby a small jet of atomized distilled water is injected into the cooling airstream? Maybe injection could be automated as a function of boost?
A liquid->stream phase change absorbs lots of heat... BTW- how much HP difference are we dealing with (say between an optimally cooled IC versus no IC at all?) |
#89 (permalink) | |
Madness...
#90 (permalink) | |
'07 Black Exige S
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, ForcedFed engine dampener, de-snorkle/ vel stack, cf side scoops/ mesh removed, algnmnt set up by Lucent in LA (machined control arms, etc), SS brake lines, 160 deg. thermo, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Stealth signal bulbs, blacked out turn side markers, 5 point harness |
#91 (permalink) | |
Without changing the external dimensions of the roof or the clam, I think I've gone about as far as possible be fettling alone. If I were designing the roof and the clam from scratch, I'd definitely make the "mohawk" cross section wider and/or taller.
#92 (permalink) | |
'07 Black Exige S
#93 (permalink) | |
If you look at the photos though (http://www.lotustalk.com/forums/atta...-duct_seal.jpg), the ductwork leading to the intercooler is already smaller in cross section than the opening in the clam... I think you'd have to change the ductwork too.
#94 (permalink) | |
You bought a Locust?
I do not have any data logs to support my conclusion that they work. They do. It can and will be improved when I have full use of my tattered right arm again (titanium rocks!). The fans move a reasonable amount of air, and dropped IAT's about 30-40 degrees at the track. My total expenditure was under $200 (purchased all from Ebay gradually over the winter) and they were very, very easy to install. 2 beers on a 6 beer scale. If you're confused by the white stuff - that is dust. She hasn't been driven in about 2 months... ![]() ![]()
...................... '07 Exige S CharlieX.ECU/S&B IC/3.1"/XR1 exhaust/urethane mounts/stage 1 driver - stage 2 car (driver mods in progress). Last edited by wildwhl : 07-29-2008 at 06:47 PM. Reason: typos |
#96 (permalink) | |
Madness...
i just hooked up my innovate system to watch the OBD2 IAT Pid. Before car's started, reading is a bit higher than ambient so appears to be accurate. IAT mid 30C's. Ambient is low 30C's. Infrared temp gun aimed at the IAT from exterior confirm similar temps. Once warmed up and running, IAT is consistantly around 42C. When full throttle through one gear, it'll quickly rise to 43C+. LOnger durations, 44C. In traffic, idling if the car is hot can get up to mid 40C's. Not sure how to analyze the info but it's interesting, that at highway speeds, no matter how fast I am going, the IAT doesn't appear to move much. the range is more or less 1-3C and correlation appears to have more to do with throttle rather than speed. higher speeds which normally = higher flows which = lower IC charge temps are normally reflected by IAT changes that are in line with speed variations/flow unless in cases where the higher speeds do not = higher flow. I guess making a new rear clam/hatch mold for the SC exiges was too expensive to fit in the lotus 2006 budget. When ever i have the roof off, I laugh shake my head at the fettle bottleneck location. Having owned several modified FI cars in the past, I've witnessed the fundamental importance of an efficient IC. I'm hoping the IAT Pid is accurate (via innovate's OT1 obd2 reader). Have purchased the complete RLS WI IC system and 2 Spal fans outlined above to be installed inside the shroud pushing. Climates in HK are hot and humid so should be a good testing environment. A thermocouple in the roof scoop would also be ideal for the data log but that's still in the works. (If anyone knows how to make a thermocouple for this application that yields accurate readings, please feel free to clue me in. Currently I have the wire(s) run, soldered one inch exposed, stuck in the shroud but temps are about 10C higher than they should otherwise be.)
91 NSX, 3.2L ITB (in progress) 93 Supra TT 95 BCNR33 GTR, 2.8L TT 00 s2000, 2.2L 08 Exige S240 Last edited by Mag : 07-30-2008 at 06:25 AM. |
#97 (permalink) |
It's great that people are trying this. Spal has a new controller out now - I've been waiting for it - basically a minor update of the current one. I have 2 6.5" fans which will push though from the front side - I plan to ditch the duct on the intercooler entirely and just have the roof duct directed at the IC (an RLS). IMO the bottle neck is the roof duct and bypassing it will allow much more air flow. I don't think drawing air from above the engine will be horrible especially when the car is moving. I'll log some IAT's once I get the whole thing up.
john
++++++++++++++++++++++++++++++++++ 08 Exige S 240, Liquid Blue, TP, LSD, Star Shield, Cup Air Box, RLS IC and Tubes... "The early bird gets the worm, but the second mouse gets the cheese." - Steven Wright ++++++++++++++++++++++++++++++++++ |
#99 (permalink) |
6.5" = 330cfm at 6.3A
#100 (permalink) |
Madness...
specs on the 5.2"
http://www.spalusa.com/fans/automate.../3013-3011.pdf
LinkBacks (?)
LinkBack to this Thread: http://www.lotustalk.com/forums/f157/2007-exige-s-intercooler-air-flow-study-59117/
| Posted By | For | Type | Date | |
| Elise.ch :: Voir le sujet - Intercooler Exige S 2008 | This thread | Refback | 07-17-2008 04:33 AM | |
| Thread Tools | |
| Display Modes | |
