LinkBack (1) Thread Tools Search this Thread Display Modes
Old 02-12-2009, 04:31 PM   #381 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Originally Posted by ericwgexige View Post
apk...the aluminum heat shield between the top of the engine and the IC...I was thinking the same thing. It would have to be of some help. Also, if one could fabricate another shroud on the engine side if the IC and duct the air directly outside...maybe with a puller fan or two to help it along...
Since I've just solved my data acquisition problems, I'm hoping to get real track data (as opposed to "street" data). I'd like to try the heat shield. I don't know whether shrouds on the exhaust side of the IC would help... but there are a few threads about installing pusher/puller fans. There's another solution out there that replaces the factory IC with an aftermarket IC located near the side scoops... and it sounds like its had some success.
2007 Aspen White Lotus Exige S (street ride)
2010 Isotope Green Lotus 2-Eleven (track ride)
Lotus Challenge Series
apk919 is online now   Reply With Quote
Old 02-17-2009, 11:48 AM   #382 (permalink)
Images: 2
Ideally, the entire IC would be shrouded to separate it from the super-hot air in the engine compartment. Probably look ridiculous though.
'07 CO Exige S TrkPk/TourPk/TrkContrl/Star - Braille 13.1lb batt, 2bular 8x24, Green filter, desnorkle, Gotham, shifter mods, Moroso oil pan, Pagid RS 4-2, fettled
'91 NSX Blk/Blk many suspension mods,headers,exhaust(SOLD)
'01 Integra GSR Blk/Blk Comptech header, intake, & rear tie/sway bar
'04 CBR 600 F4i Red/Blk
'01 Honda Rebel 250 - 80mpg!
ericwgexige is offline   Reply With Quote
Old 05-08-2009, 05:33 PM   #383 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Preliminary Ducting Study
Just getting started... more to come...
Old 05-08-2009, 05:55 PM   #384 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
when are you gonna do your scoop grille vs no scoop grille study? tho I found a good compromise
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 05-08-2009, 06:00 PM   #385 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
One way or another, I'm going to get some real data comparing "naked" ducts vs. "grille'd" ducts. Stay tuned!
Old 05-08-2009, 06:38 PM   #386 (permalink)
right seat driver
Brent Bauman's Avatar
Andy I'm only saying this because we has tested it on our unlimited buggy, heat transfer in that aluminum ducting is high, or bad in the case of your use. Use silicone its more expensive but won't transfer heat into its charge as easily.
Brent Bauman is online now   Reply With Quote
Old 05-08-2009, 11:16 PM   #387 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Thanks Brent! Do you have a source for 3" diameter silicone ducting?
Old 05-09-2009, 02:05 AM   #388 (permalink)
Blue Wheel Pimp
ZJChaser's Avatar
They are local to us at least :: #1 Race Specialist in The World :: » not so much you.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development
ZJChaser is offline   Reply With Quote
Old 05-11-2009, 06:56 PM   #389 (permalink)
I've got 2 pieces of 4" -3' silicone race brake duct hose high quality leftover pieces that I would like to donate to your investigational cause if it helps. I'm in San Diego. Let me know if it would help. Just PM me.
I really think an exhaust duct would be critical to maximizing airflow but that's just my gut feeling. Love your work. Keep it up.
shoco is offline   Reply With Quote
Old 05-11-2009, 07:27 PM   #390 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Thanks! You have a PM
Old 05-11-2009, 08:09 PM   #391 (permalink)
Live on the edge
Scrumpot's Avatar
I've recently mounted up twin SPAL HP "puller fans" directly to the back of my stock I/C. Had the car on the track last weekend, and believe I started to heat-soak out, at approx the 10th lap at Summit/Shenandoah. Did not have the fans wired yet, so not running (maybe even acting as an obstruction ). Going to get the fans actually wired this week, so can hopefully soon provide at least some anecdotal feedback on that here.
In any case, I'm subscribed - and very much looking forward to seeing some real data / results!
If I can help with anything on this project at all too, please just let me know. My car is an '08, but is an exact identical set-up actually, to the 07 S practically, in every way.
Big on the efforts!
'08 Exige-S Club Racer
Desnorkelled, Stage-2, HID's, DRL Defeat, Sector111 Tow-hook & Fire Extinguisher, Deeply Fettled Roof S/C Air Intake, Schroth Prof II ASM 4pt Harnesses, RLS Lightweight gunmetal coated intercooler tubes, Saikou-Michi catch-cans, dual-SPAL hi-perf intercooler puller-fans, custom painted engine cover
Scrumpot is offline   Reply With Quote
Old 05-11-2009, 09:32 PM   #392 (permalink)
Jobu no like curveball
shay2nak's Avatar
Exhaust duct?
'07 Lotus Exige S310
'08 Acura TSX 6-speed
support WTC 2!
shay2nak is online now   Reply With Quote
Old 06-18-2009, 05:39 PM   #393 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Teaser!
More to come...
Old 06-18-2009, 05:59 PM   #394 (permalink)
Really Light Stuff
Thomasio's Avatar
There is room for your setup and my setup in addition to the stock ducting. We can call it the octopus!
07 SY Exige S
.. To Order .. RLS Product Links ..
Old 06-18-2009, 06:00 PM   #395 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Nice! I've seen a couple of similar versions on LCS cars...
Old 06-18-2009, 06:02 PM   #396 (permalink)
Really Light Stuff
Thomasio's Avatar
There is a good chance the effects would be additive...
07 SY Exige S
Old 06-18-2009, 06:12 PM   #397 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
I agree. BTW, did you remove the upper duct from the clam to add the extra plumbing? That was seriously not fun.
Old 06-18-2009, 06:15 PM   #398 (permalink)
Really Light Stuff
Thomasio's Avatar
I had the rear window out, so it wasn't that bad. Lots of ABS-plastic shards and dust, though.
It would have been nice if the duct were removable, and doesn't Lotus use the most tenacious urethane/epoxy ever invented?!
P.S. Somewhere around here I have a photo looking into the duct from behind, similar view to your photo... but the two entry points are top, almost centered.
07 SY Exige S
Old 06-19-2009, 01:24 AM   #399 (permalink)
HKFEVER's Avatar
Seriously ugly Just kidding... Did you watch the movie 1942? Duct piping everywhere.
Why not consider a 3 parts CF housing ( 1st one in the cockpit, 2nd in the engine bay & 3rd the midified the IC shroud ). The PS job is very rough
2008 Exige S Sport in HK (S240) almost stock.
HKFEVER is online now   Reply With Quote
Old 06-19-2009, 11:05 AM   #400 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
A Couple More...
Engine ducting complete...
LinkBacks (?)
LinkBack to this Thread: http://www.lotustalk.com/forums/f157/2007-exige-s-intercooler-air-flow-study-59117/
Posted By For Type Date
Elise.ch :: Voir le sujet - Intercooler Exige S 2008 This thread Refback 07-17-2008 04:33 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
TheSpeedGeek
