Old 10-11-2009, 12:15 AM   #1 (permalink)
2Bular GT3 + rear grilles
Hello.
I wanted to know if anybody has already fitted a 2bular GT3 exhaust 6, 7 or 8" with the rear grilles still in places, with the exit thus going though the right grille?
Any pictures, advices, ....?
Thx!
François
onthebeach is offline   Reply With Quote
Old 10-11-2009, 12:34 AM   #2 (permalink)
Hoon
Amarao's Avatar
You might have some luck finding pictures here: Official "booty" thread...your rear-end...exhaust & diffuser photo
Amarao is offline   Reply With Quote
Old 10-11-2009, 04:23 AM   #3 (permalink)
Certified Lotus's Avatar
GT3 Exhaust
I've got an 8 inch 2bular GT3 exhaust and you can't use the rear grill due to size. You can make it fit, but it will be packed so tight (and you will have to remove some heat insulation) that it will probably be a fire hazard. Naked rear is only way to go with 8 inch. By the way, the 8 inch is fairly quite at low RPM's, but it sounds great above 4000 RPM's.
'07 Exige S,LSD,2bular Header,SportCat & GT3 Exhaust,Gotham Tune ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler&Pipes,CircuitWorx Oil Pump Gears,Moroso oil pan, Accusump,Fidanza 3.2 Kevlar Clutch & Alum Flywheel,Nitron GT3,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Lotus Racing M Mounts/High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Traqmate.
Certified Lotus is offline   Reply With Quote
Old 10-11-2009, 06:43 AM   #4 (permalink)
I plan to remove all the heatshielding.
There is thus enough space for putting the grilles back in place.
The only trick is to find the appropriate way to drill the right grille.
Any experiences?
Old 10-11-2009, 06:51 AM   #5 (permalink)
Diesel's Avatar
I have the 7" GT3 and had the shop cut out the right grille. I left the heat shielding in place (except for a cut-out for the pipe to exit). It looks very OEM. The car is at the shop now for new seats and interior work, but I will post pics when it returns. I'm very happy with the way it turned out.
'05 Storm/Red, Touring, Hard Top, Lotus Sport Ohlins and Adjustable Anti-Roll Bar, Lotus Sport Harness Bar, Trim Shop Seats, Schroth Profi II 6-Point Harnesses, 2Bular 7" GT3 Exhaust, Braille Battery, Cup Car Wheels w/ AO48s
Diesel is offline   Reply With Quote
Old 10-11-2009, 07:28 AM   #6 (permalink)
Images: 1
i have the 8 with rear retained, exit through right panel. some heat shielding needed to be removed. right panel was the one from 2bular, didnt have mine cut. it all fits fine.
alexscotti is offline   Reply With Quote
Old 10-11-2009, 07:30 AM   #7 (permalink)
Hoon
Amarao's Avatar
Any experiences?
Sounds like a good recipe for a fire...
Old 10-13-2009, 09:18 PM   #8 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
I just removed a section of the heatshield where the exhaust tip was going to exit. I got a piece of cardbard cut to look like the right side rear grille (like a template) and put it through the tip and tried to get a good approximation of the oval cutout. I then drew the oval and cut it out from the grille with a dremel tool.
I'll post a pic tomorrow morning.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
