Old 10-24-2009, 11:15 PM   #1 (permalink)
Exige S240
BadtZ's Avatar
Adding driving lights to my S240?
I have always wanted to add the driving lamps onto my S240 because they did not come stock. In my image, LOTUS must have those lamps LOL
I asked the dealer and they said the driving lights will only work if you are ON HIGH BEAM and have that extra button pressed.
So is that mean I will not be able to drive with the lamps on if I am on low beam?
Elise and Exige work the same I suppose.
any help?
Larini 6" Sport, DBW Pedals...and minor stuff
So far so good
BadtZ is offline   Reply With Quote
Old 10-25-2009, 03:14 AM   #2 (permalink)
Tu Sei Tutta La Mia Vita!
lc_09's Avatar
here is an old link, but it should answer your questions regarding the function
Elise Driving Lights Installation
2005 ST Elise
Driver and Passenger Racing Harnesses • Stainless steel brake lines • Nitron Sport Coilovers • GUT rear spoiler • GUT front lip • Quicksilver Exhaust • PIAA Rims • Tinted Side Windows • Rear panel Delete • HID headlight upgrade • Black Diffuser • Alpine Deck (for now..will be adding JVC SatNav Deck)
2005 Ardent Red Lotus Elise • Touring Package- Stage II R.I.P.
lc_09 is offline   Reply With Quote
Old 10-25-2009, 03:14 AM   #3 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
any help?
They only come on with the High beams and are actually considered high beam assist lights... You don't have to push any extra buttons as they will just come on with the high beams... They are however a HUGE improvement over just the stock high beams. Literally night and day...
Dragon is online now   Reply With Quote
Old 10-25-2009, 03:51 AM   #4 (permalink)
pla_time's Avatar
Images: 1
I'm not sure about the non-USA versions, but on my '06 Elise, there is a third button. The driving lights only go on with the high-beams as others have suggested, but you can toggle them off or on with the third button (when the high beams are on). So you can have Low Beams, High Beams with Driving Lights, and High Beams without Driving Lights (though IMO the High Beams are pretty worthless by themselves).
"Statistics means never having to say you're certain.” —Anon.
pla_time is offline   Reply With Quote
Old 10-25-2009, 04:25 AM   #5 (permalink)
lotusforsale's Avatar
Images: 8
+1 on the High Beam function and third button on my former 06 Exige.
To the OP...installing the factory driving lights on the Exige could very well require clam removal. The mesh is bonded in, so getting in there to get the lights mounted, and install new mesh with cutouts in place or doing a good job of cutting holes in your existing mesh would likely require clam removal.
lotusforsale is offline   Reply With Quote
Old 10-25-2009, 05:14 AM   #6 (permalink)
A pound at a time.
You can rewire them to come on whenever the button is pressed. I have them wired with the parking lights, so if the top button is on and the third button is pressed the lights come on.
If you want more details on how to rewire just ask.
A note on installing on an exige, it is not necessary to remove the clam. I installed them at home and what i did was cut the hole in the mesh exactly the same size as the light and bent the mesh inboard for a cleaner looking install.
The exige is prewired and the brackets installed for the lights, you just have to untape the connectors for the lights by removing the turn signals and reach toward the center of the car to untape them. They are close to the center of the car so it would be helpful to have some skinny helpers. Install the new button panel by swapping your stock and new button. And install the included relay in the empty receptacle under the dash.
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser
Sh4rkattk is offline   Reply With Quote
Old 10-25-2009, 10:16 AM   #7 (permalink)
No, I don't own a Le Car
9and3's Avatar
Originally Posted by Sh4rkattk View Post
...The exige is prewired and the brackets installed for the lights, you just have to...
Sh4rkattk-- Thanks for the info. I've always been curious about this.
9and3
'07 Exige S, Performance Pack
9and3 is offline   Reply With Quote
Old 10-26-2009, 01:14 AM   #8 (permalink)
Exige S240
BadtZ's Avatar
So got a DIY on how to rewire them to the park lights??
thanks!
So far so good
Old 10-26-2009, 01:40 AM   #9 (permalink)
pla_time's Avatar
Images: 1
thanks!
Just keep in mind that they are very bright -- and you should NOT have them illuminated when you are in any oncoming traffic. It would not be very nice, and could be dangerous for the other drivers.
Old 10-26-2009, 09:57 AM   #10 (permalink)
glb
Unattractive Nuisance
glb's Avatar
must be the 6th time I've typed this.
Best method is to use a relay so the DLs come on with high beams. No need for a separate swich at all.
In 40 yrs or so of driving, never once wanted high beams on w/o driving lights or vice-versa.
easier to wire, too.
glb is online now   Reply With Quote
