Old 07-18-2006, 01:12 PM   #1 (permalink)
Hiro
Bald tire under 1K miles
Hi Folks,
I want to hear your opinion or experience regarding (rear) tire worn.
My Exige delivered on 6/21 and it is less than 4 weeks old and about
960 miles on it.
About a week ago, I noticed center of rears worn then I checked
their pressure in the garage sitting there overnight and it was 31psi.
I adjusted to 29psi as recommended.
Last Sunday I drove it to local shopping mall and in the parking lot
I found steel belt is seen.
I decided not to drive the car and call AAA for flat-bed.
Since I am still breaking in and I never drive it hard. Of course, I
never auto crossed nor track driving.
Local dearlership told me 31psi is with in the range and did not agree
to fix it under warranty.
Any suggestions?
2006 Exige
Chrome Orange, LSD, Track Pack, Touring Pack,
Star Sheild, Schroth 4pt harness,
BF Goodrich G-Force Sport (205/45R16 & 225/45R17) for daily driving
Hiro is offline   Reply With Quote
Old 07-18-2006, 01:18 PM   #2 (permalink)
Ian
Certified Fun Stopper
Ian's Avatar
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC
Old 07-18-2006, 01:21 PM   #3 (permalink)
Drives just like it looks
PedalPounder's Avatar
Are you sure you got new tires on your car?? Maybe you got a crooked dealer.
PedalPounder is offline   Reply With Quote
Old 07-18-2006, 01:22 PM   #4 (permalink)
insert clever title here
MattG's Avatar
Images: 11
How does the passenger side tire look? There's no way it should wear out that fast with the kind of driving you describe. As for the tire pressure being 'within the range', well that's a new one. There's no 'range' that I've heard of, just an absolute number. Your tire was overinflated, and your wear pattern shows obvious signs of overinflation. However, that wouldn't explain the rapid tire wear; more likely your alignment is screwed up I'd guess.
Old 07-18-2006, 01:26 PM   #5 (permalink)
Newb
bambam's Avatar
I have to say that looks like a bad tire if this only occurred on the one wheel.. Alignment could be the other problem, but if you have never hit anything the dealer must have delivered it to you misaligned. Also, I would have figured you would have noticed either a vibration or unusual noise while driving if this were the case also. What does the passenger rear tire wear look like?
I assume that is the Advan A048? There is NO WAY that should have happened. I picked my Elise up with 400 miles on it (Leftover ’05 inventory) and drove it x-country and the tires still stick like glue in the dry and hook up very well in the wet.
--B
bambam is offline   Reply With Quote
Old 07-18-2006, 01:27 PM   #6 (permalink)
Jugga Jigga Wugga
EdHahn's Avatar
Agree w/ MattG somewhat - the tire does show signs of overinflation - but way more than just 2 psi. Severe overinflation, plus maybe some alignment problems.
That said...the absence of any tread depth all the way to the outer and inner edges also seems to be a sign of excessive wear - way more than 1000 miles ought to show. (In contrast, I have a few (5) track days on the original A048s, and they still have plenty of tread depth, with about 5k total miles.)
I would lean toward an answer that has either the car not having new tires on them when delivered to you, or, uh, the car has seen a lot of sideways driving.
Definitely NOT normal.
Magnetic Blue/LSS Delivered: 1/13/05
EdHahn is offline   Reply With Quote
Old 07-18-2006, 01:27 PM   #7 (permalink)
Randy Chase's Avatar
Images: 761
Agreed. We have reports that some cars came in and were delivered with wacky alignments. I would have that checked first.
Do you have a pic of the other side? Or are they the same?
Please do not PM me. My box is full. Thanks.
Old 07-18-2006, 01:34 PM   #8 (permalink)
Hiro
Thank you guys for quick reply.
The right side is even worse. Some part of steel belt is seen larger
area than left side.
The dealership and Lotus USA explained if alignment is off wear
must be seen either inner or outer edge of tires.
Anyway untl now, I feel the car doesn't run stably straight on
uneven pavement of freeways drive.
2006 Exige
Old 07-18-2006, 01:39 PM   #9 (permalink)
Hiro
Here's the other side.
Worse than left.
2006 Exige
Old 07-18-2006, 01:39 PM   #10 (permalink)
Lean Green Machine
Elisium's Avatar
Problem with the LSD ??
Elisium is offline   Reply With Quote
Old 07-18-2006, 01:41 PM   #11 (permalink)
bluejae's Avatar
i remember being told 24 fronts and 26 rear... i'm sticking with that until i know otherwise... i'm still looking for new tires as well...
KG Exige Delivered 5-9-2006
POLL:check for scratches "in" your headlights
Excessive tire wear? It may be your alignment
My Example
Hiro's Example
codymac's Example
to be installed: stebel horn, fumoto valve
current mods: arqray twin muffler, itg intake, 3M film full wrap and full rockers by X-Perts, rear lotus letters removed, locking gas cap, CF Mirror Covers, CF Side Scoops, black lotus nose/wheel badges
future mods:wheels, forced induction
bluejae is offline   Reply With Quote
Old 07-18-2006, 01:42 PM   #12 (permalink)
Images: 761
That was my first thought too. Too much toe or camber would be inside or outside wear.
This is strange.
I would still want the alignment checked.
Old 07-18-2006, 01:42 PM   #13 (permalink)
bluejae's Avatar
dealer replacing it under warranty... yeah.. that'll be the day... where's codymac?
and i think you're title should be changed... "bald" is an understatement
My Example
Hiro's Example
codymac's Example
Old 07-18-2006, 01:44 PM   #14 (permalink)
User, Registered
fpitas's Avatar
Maybe that's the case with the guy that aligned it
Francis
Old 07-18-2006, 01:50 PM   #15 (permalink)
MitchT's Avatar
That's got to be a manufacturing goof up,rubber not the correct hardness or the belts not set right or at the correct depth. If not than your LSD is over working your tires and not working properly. I would want a new set for free, call the yoko rep, look in the warrantee tire book than came with the car. Unless as other have said it is the LSd then it is lotus.
MitchT is offline   Reply With Quote
Old 07-18-2006, 01:50 PM   #16 (permalink)
nas213's Avatar
Definitely get the alignment checked. I just got my Exige realigned. I was shocked by the alignment. It seemed like Lotus used a random number generator deciding the camber for each corner of the car. The alignment on my car, as delivered, wasn't even close to the Lotus specs in the service manual.
P.S. Once you get your tire problem sorted out, maybe you, Jason, and I can get together for a drive. It would be super cool to get photos of our 3 Chrome Orange Exiges together.
nas213 is offline   Reply With Quote
Old 07-18-2006, 01:54 PM   #17 (permalink)
Hiro
Yes, definitely.
2006 Exige
Old 07-18-2006, 02:07 PM   #18 (permalink)
edge007's Avatar
I would like to see how many standing starts the ECU shows. Looks like some serious burnouts were done with this car.
edge007 is offline   Reply With Quote
Old 07-18-2006, 02:13 PM   #19 (permalink)
Hiro
Is ECU readouts also available on Exiges?
2006 Exige
Old 07-18-2006, 02:17 PM   #20 (permalink)
Wow. Just wow. If the dealer refuses to even inspect the car to find the problem, take them to court.
MyFutureSelfnMe is offline   Reply With Quote
