BOE REV400 - LotusTalk - The Lotus Cars Community
 7Likes
  • 3 Post By zero1954
  • 1 Post By cph
  • 2 Post By turbophil
  • 1 Post By zero1954
post #1 of 18 (permalink) Old 03-16-2017, 03:52 PM Thread Starter
zero1954's Avatar
BOE REV400
Just purchased the REV400 for my 2006 Exige. Vroom vroom
NoFear99, ERDoc74 and mwehnes like this.
2006 Laser blue Exige
2005 Starlite black Elise SOLD
1970 TVR Vixen S2
Enjoyed and sold many other British sports cars.
zero1954 is offline
post #2 of 18 (permalink) Old 03-16-2017, 04:15 PM
Recreational Mechanic
Nickshu's Avatar
Cool!!! Vroom vroom is right.
Nick____________
2005 Elise - Chrome Orange
Nickshu is offline
post #3 of 18 (permalink) Old 03-16-2017, 06:38 PM
cph
cph's Avatar
Be prepared to be shocked ... its a wild ride until you get the feel for it !!!
ERDoc74 likes this.
2-11 : BOE Built Engine / Rev 400 SC / Quaife Sequential / Dry Sump / Fastworks Tune
ELISE : K20 / TVS 1320 / EP sequential / Dry Sumped / Motec M1
cph is offline
post #4 of 18 (permalink) Old 03-17-2017, 10:20 AM
ERDoc74's Avatar
You WON'T regret it!
2006 Graphite Grey Lotus Elise: BOE Fully built Long Rod Race motor with Solid Ferrea rockers, REV400 SC, Custom mounted BOE Front HEX.. Penske SA's , BOE CF Rear clam, Exige front clam + LOTS of other mods
ERDoc74 is offline
post #5 of 18 (permalink) Old 03-17-2017, 11:27 AM
acslater's Avatar
Now all you need is a set of the BWR d/a Penskes and you're good to go
acslater is online now
post #6 of 18 (permalink) Old 03-18-2017, 05:01 AM Thread Starter
zero1954's Avatar
Has anyone tried placing the water heat exchanger where the stock Lotus Exige intercooler mounts?
1970 TVR Vixen S2
zero1954 is offline
post #7 of 18 (permalink) Old 03-18-2017, 02:45 PM
cph
cph's Avatar
Yes ... and not as successful as where BOE locate there HEX / IC up front. [ in my opinion]
Follow BOE,s recipe and all will be well !!
cph is offline
post #8 of 18 (permalink) Old 03-18-2017, 02:47 PM
cph
cph's Avatar
Be interested to see what you have done .... Custom mounted BOE Front HEX..
cph is offline
post #9 of 18 (permalink) Old 03-18-2017, 02:52 PM
The Enforcer
oldmansan's Avatar
He had the HEX installed while retaining the AC.
San
oldmansan is online now
post #10 of 18 (permalink) Old 03-18-2017, 02:54 PM Thread Starter
zero1954's Avatar
I won't be installing the Hex, just the water heat exchanger with the fans that comes with the REV400 kit.
BOE has it being mounted on the passenger side above the wheel.
1970 TVR Vixen S2
zero1954 is offline
post #11 of 18 (permalink) Old 03-18-2017, 03:04 PM
gstomp06's Avatar
That is the hex. You're just opting for the standard side mounted hex as opposed to the optional front mount hex. Unless I have no idea what I'm talking about.
2007 Chrome Orange Lotus Elise
gstomp06 is offline
post #12 of 18 (permalink) Old 03-18-2017, 03:49 PM Thread Starter
zero1954's Avatar
The Hex for the front is considerably different, and larger.
1970 TVR Vixen S2
zero1954 is offline
post #13 of 18 (permalink) Old 03-18-2017, 04:10 PM
The Enforcer
oldmansan's Avatar
Yeah, the Hex front mount is for the high horsepower REV400 builds, which are typically utilizing a built engine. IMHO unless you have a built engine you can't take full advantage of the REV400's capabilities, unless you want to roll the dice and are willing to blow a stock engine.
San
post #14 of 18 (permalink) Old 03-18-2017, 04:22 PM
gstomp06's Avatar
Yea I understand that, just clarifying that it's still a hex. It's just the side mount version.
I was just confused because use you said, "I won't be installing the Hex..."
gstomp06 is offline
post #15 of 18 (permalink) Old 03-18-2017, 10:20 PM
Exira's Avatar
How hard is it to install this rev400? Can it be DIY for someone with basic maintenance skills (i.e. oil change, brakes, fluid flush)? Or do I need a shop to do this install?
Exira is offline
post #16 of 18 (permalink) Old 03-19-2017, 12:43 AM
I am fitting the side mount hex and the front mount proalloy (no cut, keep a/c) heat exchanger in series.
Side hex first then front hex. Will do a check to see if the front hex on its own is more efficient. The proalloy radiator kit comes with sucker fans rather than pushers.
Don't want to chop the front crash structure and want the air to travel through the initially intended path. The pro alloy stuff is exceptionally made. Just waiting for an ECU to run this magic.
breeze91 is offline
post #17 of 18 (permalink) Old 03-19-2017, 08:09 AM
Plug Whisperer
turbophil's Avatar
Point of clarification, the heat exchangers were designed around boost...
The side mount that the kit comes with is for ~10psi boost in track conditions. That's the boost setting for stock motors. It's great for that...
On lower compression built motors, we'll sett he boost to about 15psi and the front mount is requisite for that level of boost and best performance on the track. We have many folks running the side mount on 15psi on the street. The side mount can deal with short bursts of 15 psi, but it's simply not big enough nor does it get enough high pressure air to shed the heat generated by 15psi boost for long periods of time...
The front mount is big enough, that we're shedding adequate heat on the REVX in track conditions, which runs 25psi boost!
There's no reliability problems on the stock motor with the way the kit is delivered. We just can't run as much boost (boost equals power) on the stock motor as we can on the lower compression built motors. The heat exchanger should be increased in size as boost goes up...
Hope that helps.
Phil
ERDoc74 and zero1954 like this.
Phil: NASA 2012 and 2014 TT1 Central Champion, 2005 GG Elige, Rev400, 400+whp
2011 Pearl White Evora, BOE Skunk Works || 2005 GG Elise, Rev400, Street Car || 2006 CO Elise, Rev400, Steet Car
turbophil is offline
post #18 of 18 (permalink) Old 03-19-2017, 08:20 AM Thread Starter
zero1954's Avatar
Hope that helps.
Phil
I'm excited as a little kid, can't wait till the kit gets here....
I have almost all of the removal work done, and the surge tank installed.
Keep up the great work Phil.
ERDoc74 likes this.
1970 TVR Vixen S2
zero1954 is offline
Human Verification
