Old 11-27-2008, 01:50 PM   #1 (permalink)
Not a poseur anymore!
Cracked intercooler shroud
I did a search but didn't come across a similar post. Anyhow, I was installing my RLS IC pipes the other day and noticed that the top corners of my plastic OEM intercooler shroud are cracked. Probably due to excessive engine movement? Anyone else have this happen?
07 Phantom Black Exige S - Touring Pack/Track Pack/TC/SS/Titan QR rack/Costco wireless rear view cam/BWR door sill protectors/Locking gas cap mod/headlight film with bubbles/Larini SC Sport/Multivex mirrors/Saikou Michi Oil Catch Cans/Dunlop Direzza Z1 Star Specs/Manly's Motor Mounts
300hpMR2 is offline   Reply With Quote
Old 11-27-2008, 04:02 PM   #2 (permalink)
Exige Cup 255
Noel's Avatar
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
I'm surprised it hasn't come up. It's a fairly common part failure and has been replaced FOC under warranty for my cases.
You guessed it, excessive engine movement especially under and off load either causes it to crack like how you see it or causes the front piece with the oval clamps to fall off.
I had 2 replaced under warranty, one at 3000KMs, one at 9000KMs. I no longer use this part as I've upgraded my OEM intercooler.
Noel is offline   Reply With Quote
Old 11-27-2008, 11:22 PM   #3 (permalink)
I guess I'll install my polyurethane engine mount inserts before considering a cf ic shroud.
Did you upgrade to an air/water setup? An RLS air/air IC would still use the shroud, right?
Old 11-28-2008, 05:17 AM   #4 (permalink)
Exige Cup 255
Noel's Avatar
Yes, I'm using a water to air chargecooler.
Apologies, NFI on RLS setup.
Won't go with an even more rigid CF setup. It if doesn't crack, it'd make the next piece connecting to the main roof duct constantly fall off.
Our local dealership even pop riveted the OEM plastic shroud to the air to air intercooler to make it move less. That still resulted in cracks over a very short time. And if pop riveting ain't gonna work, CF won't either.
Old 11-28-2008, 12:07 PM   #5 (permalink)
really light stuff
Thomasio's Avatar
Yep, RLS intercooler uses same shroud or our CF shroud. There is a ton of engine movement back there, the urethane mount stiffeners (sold on another thread) help out a lot.
07 SY Exige S
Old 11-28-2008, 12:35 PM   #6 (permalink)
def
...ault
def's Avatar
It's amazing how many problems keep coming up due to engine movement. Glad I've installed my engine mount inserts even on an elise
//kevin - 05 Graphite Gray - Red Touring / LSS / Starshield / Stage 2 + more SOLD after 1192 days and 22961 miles
def is online now   Reply With Quote
Old 11-28-2008, 09:25 PM   #7 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
haven't seen this problem before, but I just put in a new RLS IC and new IC shroud plus the engine mounts. So I guess I won't be seeing the problem anyway.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
shay2nak is online now   Reply With Quote
Old 11-28-2008, 11:01 PM   #8 (permalink)
So I guess even more reason to upgrade the engine mounts either with inserts or upgraded mounts.
Old 11-29-2008, 05:53 AM   #9 (permalink)
Images: 1
huh, my shroud is cracked too. rigid cf seems like the wrong direction to be going in here. why didn't they make this thing out of rubber?
alexscotti is offline   Reply With Quote
Old 11-29-2008, 07:05 AM   #10 (permalink)
Wizard of Pugz!
qball's Avatar
Images: 3
Well the upgraded mounts will cause some more vibration, but less engine flex... not sure if that will help or worsen this particular situation...
qball is offline   Reply With Quote
Old 11-29-2008, 07:50 AM   #11 (permalink)
It'd be great if there could be a silicone hump hose version of the shroud but that would be cost prohibitive.
Old 06-06-2009, 01:12 PM   #12 (permalink)
agirls's Avatar
Images: 73
Ah, I was gonna start a thread, glad I searched first!
I noticed all of the corners on my shroud were cracked and pointed it out to the service advisor at my dealership. I figured all they had to do was to replace the plastic piece. When I picked up the car (it was there for another reason) he told me they would have to replace the whole intercooler! After that, I felt like an a****** for pointing out a little crack. But, if it's a problem and others have had it replaced, I guess I don't feel as bad. I'm waiting for Lotus to approve it under warranty. I guess it's time to research the engine mount upgrades.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
agirls is online now   Reply With Quote
Old 06-06-2009, 01:19 PM   #13 (permalink)
really light stuff
Thomasio's Avatar
They are easy enough to fix with ABS-plastic-repair 2-part epoxy.
The cracks aren't going to harm airflow.
07 SY Exige S
Old 06-06-2009, 01:32 PM   #14 (permalink)
agirls's Avatar
Images: 73
So, another words, I am being an ass for pointing is out, lol. Well, if they replace it under warrantly, then it'll be replaced. If not, then I'll fill it in.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
Old 06-06-2009, 02:06 PM   #15 (permalink)
really light stuff
Thomasio's Avatar
It's good that you noticed it... it does mean that your engine is flopping around quite a bit. Might want to get the urethane mount inserts or mount kit.
07 SY Exige S
Old 06-06-2009, 05:08 PM   #16 (permalink)
Exige Cup 255
Noel's Avatar
All supercharged Exige with this intercooler has this problem. Yes, it's attributed to too much engine flex/movement/vibration.
I don't see how they should or need to replace the whole intercooler, only the cracked piece is replaced. But if they're so dumb, that's not your issue.
Old 06-06-2009, 05:41 PM   #17 (permalink)
A pound at a time.
Anyone experience a cracked intercooler duct? #11 Snaped off after the two front tabs.
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser
Sh4rkattk is offline   Reply With Quote
Old 06-06-2009, 10:20 PM   #18 (permalink)
agirls's Avatar
Images: 73
My guess would be that the service advisor misunderstood the mechanic. The mechanic was out on a test drive. Whenever there is an issue, he usually comes out and talks. Anyhow, it'll be sorted out and this is my sign that I need to start upgrading the weaker points of the car.
Toys-
05 Ducati S4R
02 Suzuki SV650
09 Kawasaki KLX250
Old 06-07-2009, 04:24 AM   #19 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
Yup... didn't snap off completely, but I had cracks on both sides. Repaired with plastic cement. If you hear a clicking sound behind your head when releasing the clutch or going to throttle, it's a good thing to check. No problems since upgrading my engine mounts.
Old 06-08-2009, 08:30 AM   #20 (permalink)
Carbon Guru
Composites's Avatar
Anyone broken one of the carbon fiber ones we've made? There's at least 30of them out there already.
Mike Cudahy
President
Prototype Composites
(414) 354-5144
Composites is offline   Reply With Quote
