Old 04-14-2009, 05:44 PM   #1 (permalink)
ECU DUMP help
Can anyone take a look at this ecu dump let me know if anything to be alarmed about? PDF format ECU DUMP
thank you
pctech6074 is offline   Reply With Quote
Old 04-14-2009, 05:56 PM   #2 (permalink)
NOT ßANNED!
Demonized's Avatar
Looks stellar. Make sure there is no ticking though, 8700 rev could perhaps maybe sorta be bad.
Old 04-14-2009, 05:57 PM   #3 (permalink)
bman6074's Avatar
Thanks it looked clean, but was looking for second opinion. It’s still under warranty. Will the dealer cover any problems like that?
bman6074 is offline   Reply With Quote
Old 04-14-2009, 06:05 PM   #4 (permalink)
NOT ßANNED!
Demonized's Avatar
If your oil-pump implodes they might look at the 8700 and raise an eyebrow..
Other than that, no standing starts, and barely any time in high rpm is a good sign. How many miles are on said car?
Old 04-14-2009, 06:16 PM   #5 (permalink)
bman6074's Avatar
4K
Old 04-14-2009, 06:22 PM   #6 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
4,000 miles? Then the ECU has been reset at some time in the past. 4,000 / 7.75 hours = 516 avg MPH... not likely.
That's not <i>necessarily</i> bad, it just means that you're not seeing all the data...
2007 Aspen White Lotus Exige S (street ride)
2010 Isotope Green Lotus 2-Eleven (track ride)
Lotus Challenge Series
apk919 is online now   Reply With Quote
Old 04-14-2009, 06:25 PM   #7 (permalink)
bman6074's Avatar
Originally Posted by apk919 View Post
4,000 miles? Then the ECU has been reset at some time in the past. 4,000 / 7.45 hours = 536 MPH... not likely.
Ok that seemed odd to me too. Why would the data not be seen?
Old 04-14-2009, 06:28 PM   #8 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
I've been told that a reflash resets the ECU data... and reflashes are normal update procedures, so the reset could be entirely innocent.
Old 04-14-2009, 06:31 PM   #9 (permalink)
bman6074's Avatar
Ok could that be from the dealer doing recall updates? I spoke to a lotus dealer about the car and they checked its service recordes and said it had all its updates/recalls done.
Old 04-14-2009, 06:38 PM   #10 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
You can estimate the miles since the reset like so:
0-30 KMH
6' 22" 32s OK, that's around 95.6 Km (15KPH avg * 6.375 Hrs)
30-60 KMH
0' 29" 48s that's around 22.4 K
60-90 KMH
0' 27" 25s that's around 34.3 K
90-120 KMH
0' 13" 50s that's around 24.2 K
120-150 KMH
0' 12" 7s that's around 27.3 K
150-180 KMH
0' 0" 54s that's around 2.5 K
180-210 KHM
0' 0" 10s that's around 0.5 K
Total 206.8 K or 128.5 miles ago... avg speed ~17 MPH
Old 04-14-2009, 06:40 PM   #11 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Yes... someone else should check me on this, but I understand that normal ECU updates (reflashes) clear the ECU data... I think that's why they sometimes do a dump <i>before</i> a reflash.
Old 04-14-2009, 06:49 PM   #12 (permalink)
NOT ßANNED!
Demonized's Avatar
I was under the impression that it is only reset upon request, but you likely know better...
Brain gets jumbled with all this information sometimes.
Old 04-14-2009, 06:51 PM   #13 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
That might be true... only a Lotus Tech (and CharlieX) would know for sure...
EDIT: Fixed quote
Old 04-14-2009, 06:54 PM   #14 (permalink)
NOT ßANNED!
Demonized's Avatar
You quoted my "under the understanding"..
Old 04-14-2009, 07:26 PM   #15 (permalink)
Crunchy Smurf
toedrag's Avatar
Images: 25
It would be useful to know how much time this engine has spent between 7500 and 9000 RPM, which is not a value that is displayed (or recorded?). Keep in mind that a car may not spend much time between 7000 and 7500 but could spend a great deal of time between 7500 and 8500.
I think it's a little strange that the max RPM's above 8500 are clustered in two groups:
-one within 7 minutes starting at 2 hours/36 min and
-one within 55 seconds starting at 3 hours 3 min
And, those two groups are only separated by about 20 minutes...first one ends at 2 hr 43 min and next one begins at 3 hours 3 minutes. Meaning, there was a burst of high RPMs starting at 2 hr 36 min, then again about 30 minutes later.
Top 5 speeds are all between 109 and 118 MPH, which suggest high RPM's were intentional and not caused by mis-shifts. Seems like this car was driven pretty hard very briefly, especially given the throttle position numbers - not that this is a bad thing at all. It's just something to take into account. Doubt it was ever tracked if that matters to you.
Only 7 hours Engine Life is interesting. If you can get the Service Records from a dealer, there would likely be an entry about an ECU re-flash very recently. If there isn't any record of an ECU re-flash (and I don't think any dealers would allow a customer to simply request data erasure), then maybe this is a new ECU on this car, which would be something to ask about.
2006 Laser Blue Elise
-aka, Blue Lightning 2.0, The Little Blue Car, my automobile soul mate
toedrag is offline   Reply With Quote
Old 04-14-2009, 08:27 PM   #16 (permalink)
Phantom Elise
polojcp's Avatar
This is some very gentle numbers.
07 Elise Phantom Black
polojcp is offline   Reply With Quote
Old 04-15-2009, 09:58 AM   #17 (permalink)
Cthulhu's Avatar
You're really only seeing 8/100-200 hours of driving...
4000 miles / 100 hr = 40 mph
4000 miles / 200 hr = 20 mph
I wouldn't be too happy with knowing 4-8% of my car's ECU history. Find out if the reflash is from Lotus maintainance. I would think that they should have a repair history for you VIN number. When I called, they were very up front about the information they had.
I wonder if the following scenario is possible: have the ECU reflashed, idle it for about 6 hours, then drive it for an hour before producing the attached ECU dump. It looks like there are a few high revs at 2:40 and 3:30 run time. Also, the avg throttle position shows that only 3 hours of idle are possible, and that there were 4 hours + of driving at 1.5-15% throttle.
Edit: Is the odometer engaged with power off if the car is towed by the front hook? Would the spinning rear wheels add mileage? Is anyone honestly this stupid?
Cthulhu is offline   Reply With Quote
