Old 07-05-2008, 02:58 PM   #1 (permalink)
Maxster's Avatar
Exige ECU Removal Procedure
Looking for an Electronic Throttle ECU removal procedure
Exige Storm Titanium, Track Package, Traction Control and Touring Package. Katana Supercharger, Charliex tune, Moroso oil pan, HD Oil pump, H&R valve springs, HD Engine Mounts, Larini Sport 8, Larini de-cat, blueprinted gearbox, Fire Extinguisher, Harness Stroh ASM, DBA5000 Rotors, Pagid Black RS14, Motul 600 Brake Fluid, Boomerang Rear Hook, Team Dynamics Wheels with Hoosiers R6, Toyo R888, Toda Racing Flywheel, ACT Clutch Strip Disc, Multivex
Maxster is offline   Reply With Quote
Old 07-05-2008, 03:04 PM   #2 (permalink)
OSX Black hat
charliex's Avatar
disconnect the battery.
on the two connectors below the ecu ( engine bay, looking from the rear towards the front of the car, firewall left side, metal fins)
feel underneath in the middle of the connector on the bottom most side, there is a nipple that has to be depressed, then the each connectors locking mechanism will slide either to the left or right, depending which side you're pulling off, they'll push themselves off the ecu when you do it right, then just take a 10mm socket and remove the 4 bolts that hold it in place.
i have some pics in the faq on the goth.am link in my sig.
