Exige Hatch - 2 strut design help - LotusTalk - The Lotus Cars Community
Old 04-01-2012, 07:41 PM   #1 (permalink)
Chuggles's Avatar
Hey guys, ever since we installed the larger RLS Intercooler we had to get rid of the center mount single strut. IMO the Prop-rod is very practical but really makes opening the hatch look extremely tacky and cheap. (It's a great to-the-point product, just not the elegant solution we are looking for) Here is what we are looking for, it's two gas struts that assist lifting the hatch and hold it in place while open. From what we are told it is the old system that was used on the cup cars and some earlier S2s.
Name:  2 strut.jpg
We deal with our local Lotus Dealer almost on a regular basis. They've been trying to help us remake this setup but have not yet been successful. They have to go through Lotus' UK side to get any Info on it b/c most of the US models have been retrofitted with the single strut set up.
Anyone have this set up currently or know much about mounting points etc? Lotusgarage looks like it might have some of the pieces but is missing some listings.
We are trying to not have a prop rod at all. Also we want to get rid of the ugly hunk of metal in the middle of the Engine bay that the rods utilize.
Thanks,
Chris
2oo8 Phantom Black S240 Exige, Blade 300, Larini Headers, 'decat', and 8" sport exhaust, Red Schroth 4pt and tons of other electronic/CF goodies.
Chuggles is offline   Reply With Quote
Old 04-01-2012, 09:50 PM   #2 (permalink)
JWA
Exige Sport 260
JWA's Avatar
Have you seen the Elise-like prop rod on the Sport 260s? Not as fancy, but factory parts that are light and functional.
JWA is offline   Reply With Quote
Old 04-01-2012, 10:17 PM   #3 (permalink)
Chuggles's Avatar
No I have not. I'll check it out Ty.
Btw, I edited the first post to better describe what we're looking for. See if that makes more sense.
Sent from my Autoguide iPhone app
Old 04-01-2012, 10:55 PM   #4 (permalink)
JWA
Exige Sport 260
JWA's Avatar
Here's a pic. I'm not sure why the "normal" Exige prop rod bracket is still there, but as far as I know it isn't used with this setup:
Old 04-02-2012, 07:36 AM   #5 (permalink)
Chuggles's Avatar
That's the cleanest prop rod set up I've seen. Thannks for the picture. That might be a good go to if I can't figure out the 2 gas strut design. Really trying to not have to mess with anything when I open the hatch.
Old 01-23-2013, 01:24 PM   #6 (permalink)
Any more developments on this?
I just installed the RLS prop rod with the RLS IC but the opening clearance is nowhere near enough. It's as if the prop rod needs to be twice as long.
I'd prefer the twin strut opener as I believe a single strut may lead to twisting of the rear cover.
alik is offline   Reply With Quote
Old 01-23-2013, 04:46 PM   #7 (permalink)
jacks1071's Avatar
I have the two strut setup on my Cup 240 (factory supplied). It wouldn't be too hard to make, the brackets on the lid are bonded on with black sika flex.
Ensure your strut supplier doesn't gas the struts up anymore than necessary as they can crack the lid.
If you PM me your email address and specifically what you'd like pictures of I'd be glad to photograph it for you.
jacks1071 is offline   Reply With Quote
Old 01-27-2013, 12:49 PM   #8 (permalink)
Excellent mate, thanks.
I'll send you a PM.
Old 01-27-2013, 02:01 PM   #9 (permalink)
be afraid be very afraid
aztec1382's Avatar
Images: 12
Pics would be great
slwkart
aztec1382 is offline   Reply With Quote
Old 02-04-2013, 02:58 AM   #10 (permalink)
Certified Lotus's Avatar
I made the modification on my last Exige S (my black car) for the same reason, installed RLS larger intercooler, and it was not hard. Sourced the gas struts from Lotus (was way too expensive, see if you can find them else where). Used epoxy glue to mount the connecting mounts to the fiberglass and it worked like a charm. When you realease the engine lid it just opens up all the way.You do need to be careful closing it though as the pressure needed to push down must be equal or you may crack the engine lid. Eventually I got rid of it and used the RLS prop rod as I was stripping the car of everything not absoluting needed to keep it as light as possible for track use. Here is a picture:
'07 Exige S,2bular Header,De-Cat & GT3 Exhaust,Koldfire ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler,Pipes & CF heat shield,Sector 111 Gpan, Accusump,Nitron GT3 shocks,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Sector 111 Trackmount, Lotus High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Personal F1 & Rapidfix II quick release,Traqmate.
Certified Lotus is offline   Reply With Quote
Old 02-07-2013, 06:11 AM   #11 (permalink)
2009 Cup 260 M/Sport
<@¿@>'s Avatar
This is what I did...I made a hood stay out of 1/4" ID stainless steel aircraft brake line...
I've bonded a 2.75" diameter titanium disc that is 0.040" thick for the hood pin for a 1/4" diameter titanium hood pin.
I just lay the hood stay in there like this since it has a clear vinyl hose over it to protect it.
The top is bent over with a notch in it for the bolt.
The bottom only has a hose clamp over the end and a short second clear vinyl hose over it that I place into the drain hole.
Since I no longer have the OEM latch...I took the whole piece off and made a new heat shield.
The heat shield from the other side.
All I want out of life are the keys to Jay Leno's Garage...
A man's mind, once stretched by a new idea, never regains its original dimensions.
[Oliver Wendell Holmes]
<@¿@> is online now   Reply With Quote
