Exige S dies at idle after installing mods
So yesterday I put on my '07 Exige S: Larini De-Cat pipe, Arqray titanium exhaust.
Now when idling the car will idle okay for maybe 10 seconds around 1k rpm, then it will dip to maybe 600-500, then shoot up to 2k (almost dying). Then right after that it will just stall. Doesn't matter if I'm in gear or not. Anyone ever have this problem before? I did a search but maybe I wasn't looking for the right key words! Thanks I should add that prior to these mods I never once had an issue with this. I read somewhere that the ECU takes some time to adjust? Could this be it? Last edited by prodigy : 03-09-2008 at 02:18 PM. |
Dinky Plastic Car Owner
hell, i didn't do a single mod to mine and it did the same thing.
i wonder if it's the same issue as our stock cars, which was either an ECU update or a vacuum leak in the intake (which was my issue).
2007 EXIGE S - Nightfall/Black 2007 Lotus Elise (sold) 2004 Subaru STi (sold) 1989 Metro Bus Pass (sold) 1984 BMX Dirt Bike (sold) 1979 Big Wheel (sold) |
I had a similar issue when I had a loud exhaust on my car. The checklight would come on and the car would die at idle sometimes. Since I changed everything back to the stock setting and got an ECU update the problem has been solved. I wonder if this means that anyone who changes their exhaust will have a problem, but it also looks like not everyone is experiencing this, so I'm sure what to read of this. The ECU does some relearning so I'd give it a couple of weeks and then decide what to do.
Live to Drive
Mine was absolutely perfect until my de-cat and headers.
It's normal for those type of mods. Just blip it when it's about to die so as to save the motor. It's fine ![]() ![]()
Be an alpha male. Drive a Lotus. |
yea I de-cat'ed mine too so thats probably what is causing it. I absolutely love the sound now but that's going to be really annoying to just keep blipping the throttle!
O2 sensors I reconnected into the new larini pipe |
#7 (permalink) |
I <3 chicken, I <3 liver
i've got a 3" 2B zaust, green filter and my car had idling problems before and after these mods...but since Gotham, the idle is so smooth. no probs
#8 (permalink) | |
thanks |
#9 (permalink) |
What I've learned after doing performance mods on other cars (my Elise is still stock intake/exhaust) is to reset the ECU after modding.
Disconnecting the battery for a few hours might reset the ECU. Or you can try Charlie's ECU reset: 1. Switch the ignition to ACC ( not the engine ) , get to step 2 within 10 seconds 2. Press the throttle to the floor This sequence must be done within 20 seconds 3. Let the throttle go 4. Press the throttle to the floor 5. Let the throttle go 6. Press the throttle to the floor 7. Let the throttle go 8. Wait upto 20 seconds 9. The check engine light should flash once You must depress the throttle to over 70%, and then it must be let go to under 30% Do not start the engine during that period, if the check engine flashed, the ECU is reset, if the engine is started during any part of this sequence, the learn tables will not be reset! |
#10 (permalink) | |
Excuse my ignorance but what position of the ignition is ACC? That reset would be so much faster! |
#11 (permalink) |
nope, just sent the ECU to him.
#12 (permalink) |
My car ran pretty rough also after installing a silenced decat. I reset my ECU and that helped, but it still was pretty rough and tended to swing wildly on idle. However, the problem did slowly go away after about a week so I'm pretty sure it was an ECU learning issue.
'05 Lotus Elise Saffron Yellow, Touring, Sport, Stainless Brake Lines, Moroso Oil Pan, RTD Brace KBS Mark 7 Formula 500 with a heart transplant in progress '09 600cc GSX-R Due to hit the track in August '09
#13 (permalink) |
Did an ECU reset today and still have issues with the idle. I'm hoping my car will act like lancer360's and improve over time, but I noticed something today that was interesting.
Starting the car up from cold the idle is fine, no problems whatsoever. It is just when the engine gets warmer that the idle starts swinging up and down and then stalls. What could be the cause of this??
'07 Chili Red Exige S (SS,TP,TP,TC) Larini de-cat pipe, Reverie 3-element diffuser, Rear panel eliminator, Arqray Titanium exhaust, Raceview mirrors, 55W 6k HID low beams, De-snorkel, Velocity funnel, Green filter, Gotham 265, Window Tint, tow hook, 4 pt Schroth harnesses, CF roof, Reverie CF rear spoiler, CF access panels, CF door panels, V1 mount, Concealed V1 display, Stealth Bulbs, Alpine flip up touch screen head unit, Alpine rear view camera, RLS IC Pipes, RLS IC, Gumball 3000 Tattoos |
#14 (permalink) |
Come on down
Sounds like a stuck throttle body. But, what would be the odds that happened at the exact same time you did your mod.
'06 Elise Phantom Black, Touring, Starshield, Powder Coated Black Wheels, Bobble head IMUS |
#15 (permalink) |
2007 Exige S
I have the same issues -- the car doesn't seem to be very tolerant of modifications. But I'm using FF's setup and the stock ECU is only used for speedo and a few other basic functions as the stand alone EFI unit controls the rest.
This problem is certainly "mysterious" and is not always present. FF spent some time trying to resolve this problem and appeared they did, but unfortunately a few days later the problem returned. About the only consistant observation I've made is that the harder I driver the car, the less like I get into idle oscilation issues when I'm at a stop. Casey at FF had mentioned something about Lotus not using a "standard" idle setup -- unfortunately I don't really know what exactly that means. I also have the stalls when hard braking to a stop. I was told this could be poor gas, so I run 96 octane or 100 octane and the problem persists -- so I've eleminated the bad gasoline theory. This particular problem existed from day one when the car was bone stock. Not sure what exactly is going on with these cars, but I really would like to find out and Lotus aren't being very helpful (pre or post modifications). For those having this problem, do you all have the AC option installed? Could this also be an oil viscosity issue that is causing problems with the VVT system? Rob |
#16 (permalink) |
is finding emo
this thread needs a bump
to all the noobies that dont know about idle stuff.
08 Audi RS4 09 Ducati 848 Red Great minds discuss ideas, Average minds discuss events, Small minds discuss people. |
#17 (permalink) |
there's a TSB from lotus regarding the idle issue.
that is to bump the idle screw up a ta. another thing is to keep the IACV clean. (also, change that gasket. it's very cheap.) specs : 800 rpm +/- 50 RPM good luck, good idling.
| CelicaSG.org - CSG | |
#18 (permalink) |
2007 Exige S
IACV? Got a pic of that and it's location? Would seem strange this device is immediately bad off the show room floor and on cars with < 6,000 miles on them.
Are you sure there is an idle screw on the throttle by wire cars? I can't seem to find one -- thought this was all controlled thru the ECU? My car will die under moderate braking while coming out of 3rd into neutral. But at this point I'm willing to check anything and everything since Lotus reps are completely unresponsive.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#19 (permalink) |
I approve this message
Have any of you with a de-cat used an o2 spacer for the second o2 sensor?
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934# 2004 s2000 - 378 whp 295 trq 2005 Mini Cooper S 2008 Honda Fit - 35mpg y0! 1965 Austin Mini w/ vtec |
#20 (permalink) |
With the Larini De-Cat, the only way I was able to fix the idle was to cut the springs down 2 coils on the spring loaded screws. Before the fix and the Gotham 265 tune the exhaust would throw a code but now I don't have that problem.
| Display Modes | |
