I searched, but couldn’t find anything, so hope it’s not a repost.
I was wondering if anybody is manufacturing or thought of manufacturing the extension for 07 Exige roof air scoop, so it extends to the windshield, just like 08+ models. I think it shouldn’t be hard to produce and install (using double sticking tape or glue maybe?) and would be much cheaper solution then replacing the roof. The peace could be either painted to match the color, or personally, I’d install it if it’s made of CF even without repainting. The benefits: much improved airflow to the intercooler and better looking car, IMO. |
#2 (permalink) | |
NOT ßANNED!
#5 (permalink) | |
ΒÄŅNED
See: 2007 Exige S Intercooler Air Flow Study There is one solution that "adds" a mohawk that extends past the rear edge of the roof, and over the clam. You have to cut open the top of the clam and the roof duct and then integrate the mohawk into it. Advantage: you eliminate the bottleneck at the roof/clam interface. Disadvantage: you can no longer take off the roof (easily). Others have cut open the <b>inside</b> of the Cup roof and run ducting through the rear window (not the glass version, either polycarbonate or CF) and directly into the roof duct in the engine compartment.
* 2009 Lotus Challenge Series Rookie Of The Year * (Thanks Jim, Tom, Jack, Rob & Spring Mountain Motorsports Ranch!) My videos: http://www.youtube.com/user/apk919 Last edited by apk919 : 09-11-2009 at 05:54 AM. |
#7 (permalink) |
I <3 chicken, I <3 liver
must be discontinued then.
Reverie makes a roof scoop extension also. It looks different than the stock intake. Check sector111.com the have it, i believe.
#8 (permalink) | |
What Sector111 has is rather a new air scoop, which requires pretty complicated installation (cutting out the old scoop). It must be cost prohibitive. I was thinking about extending the existing one.. |
#9 (permalink) |
oh, just half a piece like I've seen on S1 Exiges. Nope, never seen one like that for a S2 Exige.
#10 (permalink) |
really light stuff
![]() Join Date: Jul 2003
Someone gave you the wrong information. It is an RLS product, and Prototype Composites makes them for us.
The Mohawk in the photos of this thread is the RLS Mohawk scoop.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#13 (permalink) |
really light stuff
No problem... it gets complicated with suppliers & vendors.
#14 (permalink) |
picard facepalm is an emoticon now?
#16 (permalink) |
really light stuff
If you follow the link a few posts above, you will see a photo from both the front side and the back side. It can either be bonded in place, or it can be blended into the roof to make it look like an integral piece. Obviously that involves a lot more labor.
#17 (permalink) | |
Thank you |
#18 (permalink) | |
really light stuff
