First Impression 2009 Exige 260
Traded my 07 Elise for an 09 Exige 260. The former was essentially stock except for a stage II exhaust and six point harnesses. The 260 has an HK exhaust as well as six point harnesses. After wringing out the Exige on our very nice, winding, deserted and empty roads here in extreme SE WI, my impression of the new car and the contrast to its half brother are as follow:
The first difference that wacks you in the face, almost literally if you aren't well belted in, is the brakes. The first time I touched the pedal at the stop sign near my house I damn near went through the windshield. Strong as a moose, but sensitive! On the road, and once you learn a gentle touch, the combination of APs up front and Brembos in the rear are superb. The Elise had great stoppers, but the 260 is in an other world. Can't wait to get it on the track. Next, once I was rolling along and even at relatively mild speed, the engine differences became just as distinctive as the brakes. The Elise needed to be reved to move out with authority. The Exige's extra torque -- and it is a huge difference in real world driving -- and its extra power shows up very quickly. When I got out into the back roads, and push the Exige, there was simply no comparison. The Elise was a bit sluggish until you 'crossed over' to the second cam. It loved to rev. The Exige pulls hard from much lower rpm, although 1st still feels a bit flat. Once you are up up into 2d, the Exige pulls strong from about 4000 up and will hustle through corners short shifting between 4 and 6000. Push it up higher, and it simply explodes. Lovely power response and real world grunt out the wazoo!!!! Handling? The Elise was superb but the Exige has all the right 'extra bits' to move it up, once again, to another, higher plane. I could pick my line through corners and the Exige responded perfectly. A car that responds with you and allows you to drive like the proverbial scalpel. Again, I can't wait to get it on the track. Final thoughts are that the seats are incredibly comfortable and would be well worth the price of an upgrade in another Elise/Exige. Also, the extra price for the 260 vs 240 is, IMHO, worth it if you can afford to do it. All the bits and pieces, including the Accusump, the seats, etc are well worth the price of admission. I had tried a 240 and while differences between the 240 and 260 are not as clearly felt as between them and the Elise (and as I have never tried an Elise SC I can't opine there) once drive both you will have no trouble deciding which to buy. Oh, one last observation. My 07 Elise had a tiny, minimalist cup holder that slid out from under the dash. The Exige deleted this bit of extra and unnecessary weight. So THATS where the extra performance came from!!! Silly of me not to notice right away. Dave
Time Wounds all Heels! 2009 Exige 260 |
G-200 Driver
Good review.... I'm Jealous ! Update this after you track it for a while !
I <3 chicken, I <3 liver
what color S260 did you get?
#7 (permalink) |
Lotus Service
![]() Join Date: Oct 2006
hey Dave. Gad your enjoying it. I look forward to meeting you on Friday!!
If you need anything my e-mail is twaszak@foxvalleymotorcars.com or you can pm me here. T.J. |
#8 (permalink) | |
#9 (permalink) |
rsch
I'm not very confortable with brakes, fronts are too aggressive even when
cold and low/medium speed. The pedal is oversenitive and heel/toe tricky too. I think to change to blue Pagids. Also we made a dampers set up on scales, total weight with a nearly full fuel tank was 896,5 kilos.
CUP 260 ASPEN WHITE |
#10 (permalink) |
I was able to adjust to the front brakes after the first few uses and I recall that similarly 'aggressive' front brakes on my track cars in the past normally break in -- along with their user -- fairly soon. I have had feedback via pms from other owners who confirm this presumption.
I have no problem with the pedal arrangements, other than wearing driving shoes/moccasins gives my big feet more ease of movement than the protruding soles on street shoes. In fact, given the confines of an inherently tight footwell the Exige seems better suited for heel and toe shifting than several other performance cars with much more generous proportions. Dave
#11 (permalink) |
the designer
I will admit when I first got the s240 the brakes were touchy but over time they do brake in and are easier to modulate. They are fantastic brakes period...I would not change them. Also, my pedals are also perfect especially compared to earlier 05 cars.
2008 Exige S 240 For Sale: 2005 stock shifter console and change holder. PM if your interested. |
#12 (permalink) |
By the way, 896.5 kilograms = 1 976.44418 pounds Given the weight of the gasoline in the tank, it seems that Lotus is more than accurate on published weights for the 260, if not even a bit pessimistic. Given the way most other mfgs tend to understate vehicle weights, this is quite nice to hear. Dave
#13 (permalink) |
rsch
The pedal box is fine, It's the pad compound that's too aggressive perhaps.
A bit more of break in should help though. We adjusted a bit clicks for bump and rebound, removed front shims to increasing front camber adjusted springs to balance corner weight, leaving ride height untouched.
#15 (permalink) |
When are your brakes cold at the track?
![]() I find they do bite hard/sudden when cold, however at the track when hot they are a dream. I guess to each their own but I love them.
Click links to see my 2008 Lotus Exige-S 240 , '99 M3, 505rwhp '89 Mustang (
sold) , '05 WRX STI ( sold) homepages or here for my M3 vid (11MB) |
#16 (permalink) | |
#17 (permalink) |
Very nice, received the S260 in late August and was barely able to get the break in interval completed before the snow hit the ground. Much like yourself previously had an 06 Elise, the S260 is very impressive in comparison. Yes brakes are the wakeup call. Glad to see your comments.
