really light stuff
![]() Join Date: Jul 2003
Group Buy - Really Light Stuff CF Exige Rear Window
Group Buy:
The RLS CF Exige Window is a carbon fiber, CNC milled replacement for your heavy stock glass rear window. This is for closed circuit use only. Stock window can be removed without removing the rear clam of the car. (The new Exige Cup 260 deletes the rear glass in favor of carbon fiber, as well.) Stock glass: 3.40 lb. RLS CF Exige Window: about 1.4 lb. Group buy: place your name on the next #'d position. Once the group gets to 6, the group buy will be closed and the group will receive the following discounts: (MSRP: $255.00) Position #: 1: -$45 2: -$40 3: -$35 4: -$35 5: -$35 6: -$30 Parts will be delivered within two weeks of closing the group buy.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel Last edited by Thomasio : 04-30-2009 at 09:15 AM. Reason: Update specifications. |
really light stuff
The adhesive that holds the stock glass in place is quite pliable. A tool is used to split the adhesive around the perimeter of the window (it helps to remove the seats from the car and do this from the interior). Pull the window out.
Place a bead of windshield adhesive around the perimeter of the CF window panel, press in place and allow to cure. If you have a window removal blade, the process is simplified. Here is a link that shows the process of removing a generic windshield... of course, this flat piece of glass is far easier to remove than a windshield. Can be done in a few minutes (not including removing the seats). Glass Removal and Installation Alternatively, your local window replacement folks will have a pneumatic "windshield knife" tool that makes the removal of the old window very simple.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
Hydrocarbons Rule
I'm in like Flin for a friend who want's this.
Position #: 1: -$45 - Amarao 2: -$40 - Dragon 3: -$35 4: -$35 5: -$30 6: -$30 7: -$30 8: -$25 9: -$25 10: -$25
#8 (permalink) |
(Formerly PESTODUDE)
How does the sound baffling compare to the glass? Quieter, louder?
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. |
#9 (permalink) | |
Parts scattered about...
I imagine using a pneumatic knife is almost a guarantee of a broken rear window.
My car is modified.
#14 (permalink) |
really light stuff
The CF is from a top notch supplier, everything is made and produced in the USA. The sound will be slightly different than glass, but not a big difference.
#16 (permalink) |
really light stuff
The pretty ones will be all machined at once... Pictures then.
#17 (permalink) |
really light stuff
1: -$45 - Amarao
2: -$40 - Dragon 3: -$35 - bibbly 4: -$35 - Bender Unit 5: -$35 6: -$30 Let's get to six and I'll get this batch built... another $5 off for anyone who orders by this Friday... ![]()
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel Last edited by Thomasio : 04-02-2009 at 05:44 PM. |
#19 (permalink) |
really light stuff
Okay - #5 will also get $35 off of the price, and I'll make them when I get order #5.
PM me.
