lol
A Guessing Game!
So we get in the Lotus (2007 Exige S) to head to Jersey (clearly always the start to what's bound to be a brilliant day), and I look down as I near t he corner of 30th on 6th Avenue and see 230 DEGREES flashing as my coolant temp. I quickly pull over because that's absurdly high given that I've been driving for all of 5 minutes and it's only slightly drizzling outside.
Tow truck came ~45 mins later to take it to Manhattan Motor Cars. Manhattan Motor Cars called me a couple hours ago to say that they have it in their service bay and are going to investigate, and also that my car isn't eligible for the oil line recall. They'll call me back tomorrow once they've figured out what's going on. So, best guesses on what's up? My initial obvious thought was that an oil line broke (happened to my Elise), but it sounds more likely that the coolant tank broke I guess? Estimates on what I should plan to end up spending to replace it if that's the case?
2007 Lotus Exige S |
| Sponsored Links | |||
Advertisement | |||
You've got to be kidding
+1
Definitely a coolant system problem. Could also be a stuck thermostat, low coolant, air in the system, etc. If it was an oil line, you would have likely seen a low oil pressure light on the dash (not to mention an oil leak).
Come along for a ride: my videos 2007 Aspen White Lotus Exige S (street ride) ![]() 2010 Isotope Green Lotus 2-Eleven (track ride) ![]() 2008 Yellow Hornet Lotus 2-Eleven (track ride 2) ![]() 2012 Radical SR3RS |
Scott Graham
If it was the rad end cap that broke, make sure you upgrade to an aluminum one so it doesn't happen again. It's a common problem with these cars. Best of luck with it, Hope it's something small. It's good that they are performing the oil cooler lines under warranty or recall, as it should cover the labor for removing the front clam. a new aluminum radiator was about $500 shipped I think.
2008 Elise SC Aspen White ![]() Cup Airbox Stage 3 Exhaust LSS Sport Rims Exige Sport Seats Exige Rear Wing |
Chris
Another vote for broken plastic radiator caps. Go with the proalloy radiator and maybe replace the oil cooler line fittings with the NCI kit while you're at it
2005 Magnetic Blue Lotus Exige Drivetrain: Honda K20A Type R | Innovative Mounts | Arqray Ti | Innovative Exhaust | Custom Intake | Hondata KPro | proRAD | Setrab Cooler | Innovative Shifter | KTuned | V2 Fuel Tank | Radium Coolant Tank | Aero: Exige Clams | Reverie | TWRD | Craftsquare | Denag | IMRP | BSK Hatch Suspension: Nitron SA | V2arms | RTDbrace | Volk CE28N | Toyo R888 | DBA4000 | Pagid RS14 Interior: Recaro SPG | Willans | WorksBell | Sparco Wheel | aspec Ti knob |
#8 (permalink) |
Mountain Road Nut
This probably isn't your problem, but ...
Maybe you were simply very low on coolant. Our cars lose coolant more rapidly as they get older, but we tend to think we only need to add coolant as often as we needed to when the car was new. The problem is that even when low on coolant, about an inch still shows in the reservoir. This happened to me, but in my case, it started running intermittently hot for a while before spiking high. Even though an inch of coolant was showing in my reservoir, I had to put in almost a gallon of coolant over the next few drive cycles before it stopped taking more. If you were very low on coolant, and you got an air pocket in and around the water pump, it can cause the pump to stop pumping completely (the pump is no longer primed) and the temperature will spike to over 230 degrees. This air pocket at the pump problem is very common when changing coolant. |
#9 (permalink) | |
lol
Is replacing the radiator caps a clam-off job?? That's going to be a scary amount of money for what seems like a pretty small job
![]() Quote:
That seems pretty unlikely - if I was that low on coolant, I'm almost positive it'd be attributed to a coolant leak/a broken coolant reservoir. I couldn't have possibly lost that much coolant since the last time I drove it unless there was a major problem.
#10 (permalink) |
Sorry to derail the thread, but where can I get the this fittings kit you mentioned?
Winter beater - 1999 Saturn SL1 Daily driver number one - 1997 Corvette, Corsa exhaust Daily driver number two - 2005 Elise, gPan, carbon fiber front clam, rear toe link braces, 5 point harnesses Weekend toy - 1981 DeLorean, MegaSquirt 2 EFI, souped up engine. 220 horsepower, 230 lb/ft of torque. |
#11 (permalink) | |
lol
#12 (permalink) |
Chris
If the radiator needs to be replaced, yes it is a clam off job
#14 (permalink) |
Chris
Not sure if Lotus sells just the end caps or if you need to buy an entire new radiator. And if that's the case I wouldnt go with stock, even though the 2007+ "black" radiators are supposed to be improved...as you now know.
The cooling system on these cars aren't designed for longevity, they're designed to a cost cut budget. For peace of mind, I would invest in an aluminum radiator. That is, if the radiator is indeed the culprit. But even still I would take this opportunity to fix all known cooling issues.
#15 (permalink) |
Unattractive Nuisance
Radiator:
Unfamiliar with Pro Alloy, but you really want a single pass radiator. Many of us had good success with Wizard Cooling. All aluminum and nicely made. Oil fittings: The lines are fine; change only the fittings. Mine came from BAT and I also got their Oetiker (sp?) clamps for an extra measure. BOE may sell them as well. A search will find you a couple of threads on this.
05 elise (PES chip, SSRs, shift tower mods, Multivex; HID low beams); 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "Political language is designed to make lies sound truthful and murder respectable." G. Orwell. "Incontinence Emergency Hotline- Can you please hold?" |
#16 (permalink) |
On a "normal" car, one can detect stuck (closed) thermostat:
Upper hose is hot; bottom hose is cold.
#17 (permalink) |
lol
Just heard back from Manhattan Motor Cars: apparently a clamp holding a line leading to the coolant reservoir broke/came off. $500 later, it's resecured & new coolant in :v
Also, my right turn signal is loose - I'm pretty sure I remember that you can drill a small hole through the bottom to secure it? Or something like that? (which would obviously be way more cost-effective than ordering a new one) - can anyone chime in with the exact fix?
#18 (permalink) | |
anglophile in exile
You can't replace the caps insitu... and there are two failure modes for the plastic caps one being the joint between the cap and the radiator (the other is cracking at the edge). SSC (in Australia - not much use to you) take the failed OEM radiators and tig weld aluminium end tanks onto them... but again this cannot be done in the car.
See here - Indicators - TechWiki |
#19 (permalink) |
Mountain Road Nut
Actually, you wouldn't notice a low coolant problem until the point at which the water pump starts sucking air (the high pressure side of the cooling system, which includes the radiator, would still be full of coolant when the engine is running), and by then, the coolant is really low.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
