'Justa' Exige 190
How to: Exige Scoop Grills
So I recently picked up some nice carbon fiber side scoops.
Carbon Fiber Side Scoops Fits Exige/Exige S They do not come with grills, and the holes are too small to use the stock washers. I did not want to destroy my stock scoops to finish them off. So I decided to order some mesh and do the job myself. Got the mesh from customcargrills.com, I got the small diamond 6" x 36" mesh. Total cost: Less than $400 + 2 hours time. Here is how I went about creating new grills. I swear they turned out perfectly. ![]() Parts needed. - Carbon Fiber side scoops - Sheet of gloss black powdercoated small diamond mesh - Black silicon adhesive/sealer - Hole griniding bit ![]() Measure depth of new hole to be made with stock scoop. Marked the bit to make sure I didn't grind too much away on the carbon scoops. ![]() You can see the carbon scoop holes are too small ![]() Drilled and now fit the stock washers ![]() Traced basic outline of grill shape onto cardstock ![]() You can see the cut out (had to trim a little more) to fit INSIDE the stock grill. ![]() Now I am making a second template for the cutting of the actual mesh. Notice the spacings. 3/4" where it attaches, and 1/2" for the rest. (actually tapers to nothing near the bottom). ![]() My 2 templates ![]() Cut 2 mesh grills with the large template. Used a dremel with cutting wheel as tin snips would have mangled the thing. This is the hardest part. ![]() Finished cut grills with mesh center template behind. ![]()
2006 AR N/A Exige-Touring pack-Starshield-TopspeedPro1 exhaust-DeSnorked-Green filter-RTD ToeBrace-Shims Removed-CF Diffuser-CF Splitter-CF Wing-CF Scoops w/custom grills-Black Exige sticker-PC680 battery-S111 battery holddown-Rear Lotus badge-Carpet buttons-Painted shift knob-Painted Console-EBrake Gaiter-SilverStealth bulbs-Front S111 towhook-Polk speakers-Toyo R888s-Lamin-x turn signal tint 2008 BMW X3 with some mods 2006 Cayman 'S' Last edited by skottoman : 06-15-2008 at 07:15 AM. |
'Justa' Exige 190
PART 2
Next, you need to find some chunks of wood. Particle board works great, and drill them together to create a sandwich.
![]() Trace your small template (for the inside) on the wood. ![]() Bust out your trusty jigsaw, and cut that thing out! ![]() Now you'll hopefully have a piece that fits INSIDE the STOCK grill just like the template. ![]() Take one of your new cut pieces of mesh and place it BETWEEN the wood making sure to align the 3/4" and 1/2" outside edge parts. ![]() Use a rubber mallet, and (depending on which side your doing), start bending the mesh down. I cut some relief cuts on the corners, worked well. ![]() Now you should have a nicely made scoop mesh!!! ![]() Here's my pair (I actually made sure to 'mirror' the mesh so they were both pointing the same direction) ![]() Now to adhere them with the black silicon/adhesive. Before doing this, you need to curve your new mesh a little by rocking it across your thigh to fit the curve of the scoops. First layer of gooo... ![]() Put on the new mesh, you can still bend it a bit to make sure it fits perfectly, and then added another layer of silicon goo... ![]() FINISHED GRILLS! I swear these look factory. ![]() Fit and contour is perfect. ![]() Last crappy pic. ![]() I need to get some better outside pix in the sun later... CHEERS!!!! Skottoman
2006 AR N/A Exige-Touring pack-Starshield-TopspeedPro1 exhaust-DeSnorked-Green filter-RTD ToeBrace-Shims Removed-CF Diffuser-CF Splitter-CF Wing-CF Scoops w/custom grills-Black Exige sticker-PC680 battery-S111 battery holddown-Rear Lotus badge-Carpet buttons-Painted shift knob-Painted Console-EBrake Gaiter-SilverStealth bulbs-Front S111 towhook-Polk speakers-Toyo R888s-Lamin-x turn signal tint 2008 BMW X3 with some mods 2006 Cayman 'S' Last edited by skottoman : 06-15-2008 at 07:14 AM. |
06 S280
Great job! Got any shot of the difference in the mesh between stock and the small diamond you got?
I'll probably end up doing something like this but wanted some larger spacing in the mesh for more air flow. |
#5 (permalink) | |
'Justa' Exige 190
Cheers, Skottoman ![]()
2006 AR N/A Exige-Touring pack-Starshield-TopspeedPro1 exhaust-DeSnorked-Green filter-RTD ToeBrace-Shims Removed-CF Diffuser-CF Splitter-CF Wing-CF Scoops w/custom grills-Black Exige sticker-PC680 battery-S111 battery holddown-Rear Lotus badge-Carpet buttons-Painted shift knob-Painted Console-EBrake Gaiter-SilverStealth bulbs-Front S111 towhook-Polk speakers-Toyo R888s-Lamin-x turn signal tint 2008 BMW X3 with some mods 2006 Cayman 'S' |
Very nice Skottoman!
Too bad I don't have time or skill to make them by myself. ![]() I will just have to use the stock grill to fit on the CF scoops when I get them. Unless you can make one for me... ![]() Just looked up on lotustgarage for the grill but I don't see Exige parts... only Elise side grilles.... anyone know if they carry Exige grilles?
2008 AW Exige S240 - SOLD.... ![]() 2004 ChilliRed Mini Cooper (Sensible DD) |
#7 (permalink) |
Holy Guacamole!
Great work!
My videos: http://www.youtube.com/user/apk919 2007 Aspen White Lotus Exige S (street ride) ![]() 2010 Isotope Green Lotus 2-Eleven (track ride) Lotus Challenge Series
#9 (permalink) |
TWRD & Blip advertising
![]() Join Date: Jul 2004
Great write up. Thanks for sharing.
Jacob Join Lotuscar.ning.com for LA Lotus social events 05 Exise, 2bular 6 inch exhaust. BWR double adjustable Penske shocks, Hypercoil springs, HIDs, BWR front sway bar, Light weight PC680 battery w/BWR brace, BWR Black badges and wheel centers, Custom SCC paint job, SCC OEM Exige mesh kit and Exige rear clam details, LSD, Lotus sport clutch and light weight fly wheel. Sector front splitter. Stebel horn. Multivex Mirrors. Volk CE28 wheels |
#10 (permalink) |
'Justa' Exige 190
Outside shots. You can see it much better here.
Cheers, Skottoman ![]() ![]() ![]()
#12 (permalink) |
'Justa' Exige 190
If you're in the Bay Area, I'm sure they can be available.
![]() Cheers, Skottoman
#14 (permalink) |
Jobu no like curveball
looks great! thanks for the report!
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 Lotus Exige S310 '08 Acura TSX 6-speed support WTC 2! |
#15 (permalink) |
'Justa' Exige 190
Just a quick update. I have gotten to drive around with the new scoops/grills, and I have been noticing that freeway temps seem to be 2-4 degrees less with the new grills.
Dunno if I'm on crack or not but even today which is a quite hot day, I seem to have cooler water temps by a few degrees. Maybe I'm on crack but I don't think I remember taking a crack pipe to work? ![]() Cheers, Skottoman
#16 (permalink) |
i'm very impressed, now the bad news. we found that removing the grills makes the car run 2-3 deg cooler and the temp comes down faster. Removing the stock exige s grills can be a bitch. use a heat gun on the black goo and get a blade between the screen and the vent. by the way i think it looks better with them in.. carl
User formerly known as 4carl |
#17 (permalink) | |
'Justa' Exige 190
Cheers, Skottoman
#19 (permalink) |
Hydrocarbons Rule
Very nice... I used a cutter and removed my stock ones. Was not fun at all as there was about 5 times more silicone than was needed holding them in place.
Next time I have to make some mesh grills I'll have to remember your wood trick... ![]()
2006 Exige; TVS Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. |
#20 (permalink) |
Exige Cup 255
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
Well done Skottoman, I reckon you should get a kit together and sell it to members whom are too lazy and want a simple turn-key solution with one complete product. I'm sure, you can make some extra $$$ with your handy work.
