LinkBack (6) Thread Tools Search this Thread Display Modes
Old 11-04-2006, 10:50 AM   #41 (permalink)
MikeS27's Avatar
That sounds like a great idea guys!
Like stated before, do yo think it will interfere much with the Exige S' intercooler. I am thinking about doing this too to my Exige S.
MikeS27 is offline   Reply With Quote
Old 11-04-2006, 12:06 PM   #42 (permalink)
BOB1984's Avatar
No, people in the UK have removed the exige S top with no problems...
BOB1984 is offline   Reply With Quote
Old 11-04-2006, 02:28 PM   #43 (permalink)
MikeS27's Avatar
Now I have a 2nd cabrio!
I see this guy did not do the "soft top" mod. Thanks for posting the picture, the car looks awesome!
Old 11-04-2006, 02:40 PM   #44 (permalink)
blacktoy's Avatar
Wouldn't recommend removing the hard top on the Exige S as the s/c uses the air intake from the roof. The air scoop on the Exige S is bigger than the normal Exige to accomodate for this (and looks better IMHO).
The air intake on the normal Exige is blocked so is just a cosmetic touch thus removing the hard top won't effect engine performance or efficiency.
blacktoy is offline   Reply With Quote
Old 11-04-2006, 04:52 PM   #45 (permalink)
No, it's only an N/A
RichS's Avatar
Actually the scoop isn't any bigger on the Exige S (although it is 'functional' in that it isn't blocked like it is in the N/A Exige) and the remainder of the scoop (what's left over after the hard top is off) will draw in just as much air as when you use the whole scoop (with the hard top on).
While there is a miniscule possibility that removing the hard top will get 'less' air into that little opening, the amount of 'less' is so small that it could only be detected using a very sophisticated instrument of some sort.
In other words; Do this mod and enjoy the ability drive topless and quickly add a top to your Exige even if it is an Exige S.
Useful links to vendors removed at Nadeem's request.
"Nice avatar by the way, I doubt Colin Chapman would have followed the herd as I have seen many here do. --Nadeem"
RichS is offline   Reply With Quote
Old 11-05-2006, 04:20 AM   #46 (permalink)
Probably Lurking
Keeper's Avatar
I missed this one the first time around. ATUP.
Keeper is online now   Reply With Quote
Old 12-20-2006, 06:02 PM   #47 (permalink)
wanna swap cars?
RideMooch's Avatar
to dig up an old thread....
how well did the windows meet up with the softtop? Any leakage when it rains (well...more than usual)? I was under the impression the windows' height is different on the exige vs elise vs elise with hardtop.
~Matt
"but officer, its only a four-cylinder!"
'02 Subaru WRX [13ESP] "CONEATR"
co-driver of my dad's '06 CO elise [(1)47SS]
co-driver of my brothers '06 Subaru WRX STI
co-driver of.....can i drive your car?
RideMooch is offline   Reply With Quote
Old 12-25-2006, 06:55 PM   #48 (permalink)
pilot's Avatar
the roll up height most certainly is different. the trick is to adjust the window to roll up to meet the "taller" top. then, when you put on the other top, you just dont roll the window up to the mechanical stop-just to the rubber seals. (this, i sadly must still adjust)
pilot is offline   Reply With Quote
Old 12-25-2006, 07:16 PM   #49 (permalink)
ToYoTa dRiVeR
Imolas54's Avatar
i did this recently, and had to adjust the window for the different tops. also, what i found is, you will probably never want to drive around w/ the softtop on the exige just for the sole fact that it looks like crap
Imolas54 is offline   Reply With Quote
Old 03-14-2007, 07:31 AM   #50 (permalink)
Haxord but mine
Westrock's Avatar
I'm going to want to do this to mine as well. Texas weather is great for open top, but things can change quick.
What are part numbers and prices?
I'm guessing you need the 2 plastic ribs, 4 grommets and the soft top.
Do you guys know the price and part numbers so I know what to expect when I go the Lotus dealership?
I saw this on page 1, not sure what its referring to.
Originally Posted by inetd
The parts included were:
A116B0182F Conv. Bow Plug
B117B0480K Plug Spacer
1 hour labor
Total $118.61
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
Old 03-15-2007, 08:01 AM   #51 (permalink)
allegretto's Avatar
This business of airflow to the scoop is more complex than simple venturi size.
Keep in mind that on a stock roof the scoop at the top of the windshield is (probably, only the windtunnel guys can tell us for sure) in a somewhat smooth high pressure area. At the back of the cokpit position, over an open spot, the flow is likely to be far lower pressure and quite turbulent. Further, the "dead space" is different in the two systems as will therefore be the whole manifold pressure throughout the system.
In short, you have (possibly) profoundly effected the intercooler's cooling. I'd be concerned at the track about this. Perhpas it's no big deal on the street, but I'd be sure to discuss this with Lotus Sport if I wanted to do it on the Cup (and I admit, I would like to do it on my Cup).
allegretto is offline   Reply With Quote
Old 03-18-2007, 09:25 PM   #52 (permalink)
Full GRP Jacket
mrluky's Avatar
Images: 28
Does anyone know the total cost of parts?
Lotus of Greenwich charges $1650 for this mod.
My line is never wrong, it just doesn't always correspond with the asphalt.
Above the clouds, the sun is always shining.
mrluky is offline   Reply With Quote
Old 03-19-2007, 12:48 PM   #53 (permalink)
Trust in God
Needspeed's Avatar
[quote=mrluky]Does anyone know the total cost of parts?
QUOTE]
The 2 grommets and 2 spacers only cost around $7.00 for everything. The soft top is the most expensive part. I picked mine up used for a decent price. Good luck!
07 Exige S (Chili Red)
05 Legacy GT Ltd
98 Esprit V8 (sold)
02 WRX (sold)
Needspeed is offline   Reply With Quote
Old 05-06-2007, 12:31 PM   #54 (permalink)
Yo
Just done mine on normal Exige.
Didnt have a dremmel so made a series of small holes then punched out bit in middle, smoothed it off with a file.
You do get dust everywhere !
I stuck a yogurt pot behind where I was drilling to catch some debris.
JOhn
johnraiders is offline   Reply With Quote
Old 05-06-2007, 04:55 PM   #55 (permalink)
grappa's Avatar
http://www.elisetalk.com/forums/showthread.php?t=38548
Check out my post on temps,might be interesting to you.
www.fquick.com/quicker
"Quicker"
Exige S- Storm Titanium
• Touring Package
• Performance Pack
grappa is offline   Reply With Quote
Old 05-16-2007, 03:39 PM   #56 (permalink)
Selfish Asshat
ryoung99's Avatar
I just wanted to thank Pilot for his directions, I just finished mine, it worked great.
Thanks again.
2006 Exige StormTi, BWR S/C, Nitto NT-01's (love em)
2005 Stealth Focus Midget (3 of them); 2001 Ocke Mannerfelt B-24 "Batboat"
2007 Honda S2000 (wifes car), 2003 Insight (commuter), 2000 Ford Excursion
2004 Meridan 411 and 96 SeaDoo Speedster boats
2004 Newmar Kountry Star RV and various racing karts and snowmobiles
www.capitalcitymidgets.com
ryoung99 is offline   Reply With Quote
Old 05-16-2007, 04:28 PM   #57 (permalink)
intofx's Avatar
Images: 14
Do you have to cut the holes in the windshield frame as well or are they already there?
Matt
2006 Phantom Black Exige
2004 Porsche C4S
2007 Black Hummer H2 SUT
intofx is offline   Reply With Quote
Old 05-16-2007, 05:25 PM   #58 (permalink)
Ian
Certified Fun Stopper
Ian's Avatar
Matt
They're already there.
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC
Old 05-18-2007, 06:26 PM   #59 (permalink)
I know this may seem stupid, but what if you don't put the brackets in, can you still use the top?
And can you order this stuff from any local lotus dealer, what approximately is the cost of the stuff? I've seen 1650 including installation.
robl45 is offline   Reply With Quote
Old 05-18-2007, 07:04 PM   #60 (permalink)
Meow talk lotus one day?
andykeck's Avatar
Images: 1
Technically, yes. But it will flap around like a MFer without the stays in their brackets. Like a tent missing a couple of poles.
andykeck is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.lotustalk.com/forums/f157/how-install-soft-top-exige-27090/
Posted By For Type Date
Sport Car Club :: View topic - soft top para el exige This thread Refback 04-28-2008 03:32 PM
Sport Car Club :: View topic - soft top para el exige This thread Refback 04-28-2008 01:51 AM
Sport Car Club :: Ver tema - soft top para el exige This thread Refback 04-27-2008 02:47 PM
Sport Car Club :: View topic - soft top para el exige This thread Refback 04-27-2008 01:21 PM
Sport Car Club :: View topic - soft top para el exige This thread Refback 04-27-2008 11:13 AM
Sport Car Club :: Ver tema - soft top para el exige This thread Refback 04-27-2008 10:59 AM
