Old 10-02-2009, 01:16 AM   #1 (permalink)
Exige S240
BadtZ's Avatar
How to lift the hatch/bonnet if the tailgate wing is not in-place?
I tried lifting the bonnet with out holding the wing and it was
TERRIBLY HARD!
I am looking into install the spoiler on the clem, so.....
How do you guys who has their wing installed on the clem and/or wing-less
opens the bonnet?
The tiny gap between the bonnet and the clem is just unreachable with my fingers...got used to lifting it up holding my wing
This brings a "?????" to me how to lift the bonnet on the 2010 Exige
And the access-ability must be poor to the trunk with the wing on the clem right?
Jacky-
Larini 6" Sport, DBW Pedals...and minor stuff
So far so good
BadtZ is offline   Reply With Quote
Old 10-02-2009, 02:00 AM   #2 (permalink)
Hoon
Amarao's Avatar
I removed my wing and the rear cover was so light without it, it opened on it's own.
Amarao is offline   Reply With Quote
Old 10-03-2009, 10:24 AM   #3 (permalink)
Exige S240
BadtZ's Avatar
oh I see
but would it be so light that I can stick my fingers in and lift it up?
So far so good
Old 10-03-2009, 10:53 AM   #4 (permalink)
(Formerly PESTODUDE)
Illumiloti's Avatar
I keep the wing off when I drive on the street. Only put it on for the track. If I give the release lever a hard, fast pull, the hatch pops up almost an inch. If yours doesn't, maybe the post on the hatch (with the spring) is adjustable so you can tighten it down a bit, thereby increasing the spring tension which should cause the hatch to pop up further when you release it.
Randy
'07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune.
Illumiloti is offline   Reply With Quote
Old 10-03-2009, 06:08 PM   #5 (permalink)
Exige S240
BadtZ's Avatar
yeah I think I got the spring to the hardest since I got alot of trunk opening issue. (not popping up b4)
Lets try that again
So far so good
Old 10-03-2009, 09:01 PM   #6 (permalink)
luxige
luxige's Avatar
That's what I'm planning. Do you folks who delete the wing have some kind of trim to cover the 'slots' where the wing pillars normally mount, or is it not noticeable?
luxige is offline   Reply With Quote
Old 10-04-2009, 12:30 AM   #7 (permalink)
Illumiloti's Avatar
I have an Exige. When the wing is removed there are 4 small holes where the screws that secure the wing pass through (it's mounted on the engine cover). I got 4 small rubber stoppers from the hardware store. I wet them a bit to make them slippery and push them into the holes from above. I can get them close to flush, leaving just enough to grip to be able to remove. They're hardly noticeable. I can put the wing on or off in about 5 minutes. (I have the Reverie Carbon Fiber).
Randy
Old 10-04-2009, 10:51 AM   #8 (permalink)
Super charged!
Vishus_1's Avatar
Images: 62
It pops ajar on the 2010 just like any other S2 Exige. You have to open it VERY carefully by getting your fingers underneath the lip and lifting up.
The weight is a little less without the wing attached since 2010's put that Celica-llike spoiler through the clam.
2009 Exige 260 SPORT - Chrome Orange / Carbon Fiber / Black with the mustache
Purchased through St Louis Motorsports
Vishus_1 is offline   Reply With Quote
Old 10-18-2009, 03:52 AM   #9 (permalink)
Back to basics :)
Tuscan's Avatar
S1 Exiges have the same problem.... the number of times I've caught my fingers between the hatch and rear wing then begun swearing....
AKA "Esprit" on other forums.
'01 Exige S1 - Titanium.
Tuscan is offline   Reply With Quote
Old 10-19-2009, 06:16 AM   #10 (permalink)
Haxord but mine
Westrock's Avatar
If anything its harder to CLOSE the wing cause the shock now has more pressure then the weight of the clam. When my hands are full I have to push the shock with one hand push the clam down far enough with my jaw to clear the catch.
But of course with the wing its just heavy enough to clear the catch.
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
