Old 09-12-2009, 07:57 PM   #1 (permalink)
caboydman's Avatar
Innovative mounts installed
I just drove my car today after the install and I am very pleased. It has helped the shifting a lot and that is really what I was looking for.
The vibration is there of course but I don't think it is that bad. I am familiar with using stiffer engine mounts so I knew what I was in for but the benefits of these mounts far out weigh the negative.
It was my first mod with this car and I'm happy with my choice.
2008 Exige S240
caboydman is offline   Reply With Quote
Old 09-12-2009, 08:57 PM   #2 (permalink)
Iman's Avatar
These should be everyone's first mod.
2007 Exige S: Solar Yellow. Lotus Challenge Series #101
2009 Nissan GT-R: (Sold)
2007 International 8600: 450HP/1500TQ Tow vehicle
2008 Benz S550
Iman is offline   Reply With Quote
Old 09-12-2009, 09:35 PM   #3 (permalink)
stinkyonion's Avatar
Images: 2
I did Manly's engine mounts. Cheaper, faster, easier. Then had a new rattle at every 500 rpm change--dash, then driver door, then firewall, then passenger door, etc. Chaised them down, dash was the worst, like 3 different rattles in there all easily solved after taking apart dash for radio install.
2006 polar blue Elise, VF stage II, clam hinge, von Hep exhaust, HID, Zeitronix/Dashdaq (GPS, wideband O2, EGT, fuel+oil pressure), BWR fuel rail, moroso oil pan, HD SS clutch, RTV brace, green wire mod, harnesses, Oddysey 625, alpine pdx-5, jvc avx77 head unit, jl speakers, voltmeter on dash, custom gauge pod, etc.
stinkyonion is offline   Reply With Quote
Old 09-12-2009, 10:13 PM   #4 (permalink)
v My Cup Holder v
HammerS2's Avatar
What did you use to do the lower front one..? I got all mine in but that one and it is driving me nuts...
HammerS2 is offline   Reply With Quote
Old 09-13-2009, 03:47 PM   #5 (permalink)
caboydman's Avatar
On the front lower mount I believe I used a socket on the top nut with a short extension. Then a ratchet box end wrench on the bottom one.
2008 Exige S240
Old 09-13-2009, 04:24 PM   #6 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
Drove me nuts for a bit too...
+1
A wobble extension might just be the trick. Be patient, I was only able to get one or two clicks on the ratchet at a time...
Old 09-13-2009, 05:07 PM   #7 (permalink)
AKA XHILR8N!
BRTHTAKR's Avatar
Images: 6
Dash vibration fix
This adds some weight, but at least for my car the most pronounced vibrations after the mounts has been eliminated.
Simplicity is the ultimate sophistication. Leonardo Da Vinci
2005 Elise LRG, Trim Shop interior, full cage, Cup wheels, other stuff.
2007 Toyota Tundra (about 10 cup holders)
2004 BMW X3 (4 small cup holders)
1980 Rover SD1
BRTHTAKR is offline   Reply With Quote
Old 09-23-2009, 06:38 PM   #8 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
I installed mine last weekend but I can't keep up with the rattles gonna swap back next weekend
the vibration doesn't bother me but the rattles just keep getting worse and more pleantiful
/sigh
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 09-23-2009, 08:25 PM   #9 (permalink)
Zinhead's Avatar
/sigh
Put some more time on the car. The vibrations go down with use.
Zinhead is offline   Reply With Quote
Old 09-23-2009, 08:31 PM   #10 (permalink)
True, but they will always be there. My car is 100% track, so the vibes from these mounts did not bother me. But there is no way I would install these on a street car. Great track car mod, but (IMO), bad mod for a street car.
2007 Carrera S
2007 Exige S
2007 CBR600RR
deddie is offline   Reply With Quote
Old 09-23-2009, 08:45 PM   #11 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
+1
/sigh
Oh, come on... it's a Lotus, not a Bentley!
Old 09-23-2009, 09:42 PM   #12 (permalink)
Iman's Avatar
My daily is a Benz S550. My toy is the Exige. If I made my toy feel like my daily, what would I have to look forward to driving. Solid mounts make the Lotus. I actually upgraded mine to the 85a and now it feels even more like a GoKart.
2008 Benz S550
Old 09-23-2009, 09:44 PM   #13 (permalink)
really light stuff
Thomasio's Avatar
Attachment 133293
Attachment 133294
That's on top of the airbag module... I'd be wary of doing that. (Maybe you have both of your airbags out and don't care?)
07 SY Exige S
Old 09-23-2009, 09:55 PM   #14 (permalink)
Iman's Avatar
Whats an air bag?
2008 Benz S550
Old 09-23-2009, 11:23 PM   #15 (permalink)
def
...ault
def's Avatar
Manly's engine mounts only makes the front left of my car rattle when its cold... other than that, definitely worth it as this car has many problems with engine movement
//kevin - 05 Graphite Gray - Red Touring / LSS / Starshield / Stage 2 + more SOLD after 1192 days and 22961 miles
def is offline   Reply With Quote
Old 09-24-2009, 12:00 AM   #16 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
I agree but these are a little too much... my engine doesn't move at all
Old 09-24-2009, 07:48 AM   #17 (permalink)
def
...ault
def's Avatar
It moves more than you think!
Old 09-24-2009, 08:31 AM   #18 (permalink)
ΒÄŅNED
apk919's Avatar
Images: 20
Try this in your driveway: parking brake on (firmly), first gear... turn your head so you can see the engine through the rear window... now just let out the clutch enough to put load on the engine, but not override the parking brake and move the car. Tell me how much your engine moves...
Old 09-24-2009, 09:23 AM   #19 (permalink)
Iman's Avatar
The front mount is the weakest mount. If you make only the front and rear mounts solid you will run into the risk of pulling the threads out of the block. To ease up on the vibration you can also try switching the front mount to the OEM mount.
2008 Benz S550
Old 09-24-2009, 09:40 AM   #20 (permalink)
Project Nirvana Elise
shinoo's Avatar
Originally Posted by Iman View Post
... To ease up on the vibration you can also try switching the front mount to the OEM mount.
This is what we did on our Exige and it helped ease the vibes making the car more liveable. Using all 4 mounts remains the best performance solution.
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
