#21 (permalink) |
casual exige user
you are an itiot if you think you can do a better job of sorting sports cars than lotus can.
www.lotuscarclub.org "Reports that say that something hasn't happened are always interesting to me, because as we know, there are known knowns; there are things we know we know. We also know there are known unknowns; that is to say we know there are some things we do not know. But there are also unknown unknowns - the ones we don't know we don't know." (rumsfeld) |
#22 (permalink) |
When a factory spokespersons say stuff in public they speak the company line.........it does not always mean its true or optimal.
Watch the Exige S on the top gear lap, its smoking its inside wheel everywhere. The stig (a professional racing driver) said it would have been quicker with lsd. I have an S with Lsd and its traction out 2nd gear turns is incredible. In the wet its even more pronounced. As for the understeer, i find spinning the inside wheel out of 2nd gear corners just as frustrating as understeer. Thats why i ordered lsd and have optimized the front camber to dial out the understeer which is in a std geo, non lsd, lotus anyway..... |
#23 (permalink) | |
McLareghini Bugatterrari
Now listen up everybody... codymac has an open dif. xtn has lsd. Both have similar experience and similar seat time on the same track. Both run similar lap times. So close, in fact, that we can take turns running in front and neither one of us can pull away from the other on average. The simple fact is that we have each learned his OWN vehicle's dynamics and responses. Maybe they behave slightly different exiting a turn under power. So what? He knows how to get his pointed where he wants it to be, and so do I. Maybe on a few turns he has a 0.05 second advantage, and maybe on a few others I have a 0.05 second advantage. And fzust... it's a bit simplistic to say LSD promotes understeer because you're "getting taction in the rear." It promotes understeer because under power it doesn't allow the rear tires to rotate at different speeds as easily, so it takes more work by the front tires to drag the car around an arc. And max... You're an idiot if you think Lotus knew exactly what my favored handling characteristics are. Every small change in setup has tradeoffs. MY priorities may require a slight advantage in turn-in response, while yours may require a slight advantage in highway stability. Therefor I align with more front toe-out than you. Doesn't mean one is better than the other because there are different goals to be judged against. Lotus engineers are genius, but that does NOT mean the default setup is the end-all-be-all king of the world setup for everybody. Besides, it has been shown many times that setups as delivered from the factory have been all over the map. If I drive my car around the track and find one end to be looser than the other, I prefer to make a slight change and retest until I get the balance perfect for me. How can you say there's no way I could improve it? Should I just drive around with the rear end so loose and on the hairy edge of spinning all the time? No thanks. xtn
2006 McLareghini Bugatterrari, Storm Titanium... <mods> installed: air horn, Scroth 4-point ASM harnesses, Sector111 halon extinguisher and mounting bracket, Von Hep exhaust and rear panel delete, Pagid brake pads, red Volks CE28n wheels, Toyo RA-1 tires, Nitron SA coilovers, Sector111 (WorksBell) quick-disconnect steering wheel kit. awaiting installation: Scroth "pull-up" lap belts, Sector111 RTD Brace, Tony's heater bypass mod, and dropped steering rack mounting plates. </mods> Last edited by xtn : 06-27-2007 at 08:43 AM. |
#24 (permalink) |
youngin' in lust
I really think this is a matter of personal preference for this car we so affectionatly lust depending on both usage and desired feel. You will have people equally split on whether the benefits are worth it or if the drawbacks outweigh the positive. For what it is worth, you can be just as fast with or without a LSD once you have learned how to drive with the setup you have. Once you have gotten used to an open differential setup, jumping right into a LSD setup will definitely feel different, most likely in a negative way. Same applies true for the reverse. (Side note: Definitely need a LSD for 4wd vehicles, though)
#27 (permalink) | |
#28 (permalink) | ||
short angry bloke
You're right, nobody knows how to sort a car better. That must explain why the Cadena boys are having so much success right now and all the Brits go to Plans to get their cars sorted for the MESC Series. It also explains why these cars don't have all those street car compromises like minimal negative camber up front, windows that go up and down, radios, A/C, airbags, seatbelt tensioners, etc. Quote:
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. Last edited by codymac : 06-27-2007 at 11:17 AM. |
#30 (permalink) | |
Laptime wise, unless you have several severely tight hairpins there shouldn't be a difference. But the LSD cars are sure a lot more fun to drive and more controllable. Have any of you tried driving fast a non-LSD car in the rain or winter? It's just no fun, watching the engine rev up with little control over the rear and no power oversteer attitude.
C. Gomez 2008 997 GT2 - All weather, all season, 4 seater "practical" daily driver 2007 White "Martini Racing" Exige S, Touring pack, Nitron Race suspension. Track Grin Machine ![]() 2006 997 Carrera S - SOLD, 2007 Laser Blue "Gulf" Exige S - RIP, 2005 Racing Green, LSS - SOLD |
#31 (permalink) | |
....and you may want to practice your manners, especially if what you are claiming is factually wrong. |
#32 (permalink) | |
short angry bloke
I'm getting much, much better at it. ![]()
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
#33 (permalink) |
"you are an itiot if you think you can do a better job of sorting sports cars than lotus can"
That’s why they say for best handling go with -.2 in the front..I wonder where the under steer comes from? What a mystery. Carl |
#34 (permalink) |
blah
You really just have to learn your car. My LSD does induce understeer on corner exit but I've learned to drivethe car to accomodate this and I don't think it really slows me up much if any.
The one thing I do hate is the TC. I know it is designed to work with the LSD but I always turn it off. I should also point out that I have had a "factory alignment" on the car and just got it aligned. I had `1.5 degrees of toe in in the rear which could have been contributing a bit to my understeer. I'll report back after a few July track days with the new alignment.
AJ 06 Aspen White Exige - MWR Stage 4 motor : Exige S manifolds : MP62 : CharlieX Tune : FF 10psi pulley : RLS IC and pipes : Walbro 255 : RC550cc : Moroso Pan : VonHep Single : WR Race Header : JRZ DA Race Coilovers...(tons of other goodies)... 267hp/167tq at the wheels : Dyno |
#35 (permalink) | |
One more variable
This board can be very educational, I just learned the word "itiot" as cody was called by some very naive board member.
Exige Storm Titanium Track Package, Traction Control and Touring Package. Katana Supercharger, Charliex tune, Sector 111 Fire Extiguisher, Harness Stroh 4pt ASM, DBA5000 Rotors, Pagid Black RS14, Motul 600 Brake Fluid, Boomerang Rear Hook, Team Dynamics Wheels. Hoosiers R6, Toda Racing Flywheel, ACT Clutch Strip Disc, Multivex |
#36 (permalink) | |
Exige S Komo 280bhp
when i say the LSD cut my laptimes and handling of the car, i'm talking from experience, not Lotus hero worship...
User formerly known as tonyyoshi 2007 Lotus Exige S Aspen White with LSD, Traction Control, Komo-Tec Phase 2 280bhp and SJR Titanium Exhaust. Komo-tec Acceleration Watch Me Race |
#37 (permalink) |
I went with the no LSD on Lotus' recommendation in my 06 Exige. In turns 1, 4 and Oak Tree at VIR, I get wheelspin. My A048s are cylced out, but right now my perception is that the car would be faster with an LSD. I'll see what it does with new tires.
I'm also generally aware that an LSD can also produce understeer on turn in (and not just exit). As you turn in, the inner wheel is going to try and turn faster than the outer, and the LSD is going to "work" and potentially cause a push. Potentially. The best LSDs, if I understand the LSD gurus correctly, are clutch packs that are set up to free wheel under coast/braking, and then "lock" under acceleration. |
#38 (permalink) | |
#40 (permalink) | |
When God starts making cars, I'll consider them perfect and quit trying to think for myself. |
