My Exige Won't Start!
A couple of days ago I tried to start my 2007 Exige S and it wouldn't turn over or even make a decent attempt. I thought my trickle charger had failed me, but the battery seems to be charged and all terminal connections are tight. Tried boosting from my Tacoma but no difference.
I am suspicious of the alarm system since I had the LF acess panel off to check the brake fluid a day or so earlier, and of course, a limit switch ties the panel into the alarm system. Can't imagine how that would do it, and it may be coincidence. Have tried reprogramming the remotes but that doesn't help. I disable the alarm system, turn on the ignition, push the button but all I get are blinking idiot lights and the clicking of relays. |
OSX Black hat
sounds like a dead battery or loose connection.
A friend who is an M-B mechanic came over with his battery tester, and it did test as shot. Surprising, since it (Exide) has had an awfully easy life and gave no warning. He also said jump-starting might not work. If I were to pull out the old battery and connect my Tacoma battery thru jumper cables directly to the Exige's cables, should it start? The owner's manual says that the car won't behave "normally" until the computer has "readjusted" to the new battery. I wonder what that means.
Thanks! |
It's a Lotus
Replace the old, stock battery with a new fresh one. No way to know how long it sat on the lot before you bought it.
Then go from there. Not hard to install and not very expensive. That's what I did. Worked great. Best of luck. ![]()
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats. "We know they're magical and worth every minute we spend on them. The whole Lotus owners' world is like a secret handshake among people who understand that." (R&T) |
Alarmed & Dangerous
#7 (permalink) |
Larry and TheViper (Among Others) Were Right
Just to put Finis to the story I moved the (2 years older) battery from my Elise over to the Exige S and it started just dandy. I left it there and the Elise got a new Optima Red Top.
One of the Exige's fobs apparently did go bad on me just to confuse things, but I had a spare (5 fobs for 2 cars) so all is now well. Next time I'll apply Occam's Razor and save a lot of trouble. Thanks All--- |
