#21 (permalink) | |
Live on the edge
![]() Cheers, -Grant
'08 Exige-S Club Racer Desnorkelled, Stage-2, HID's, DRL Defeat, Sector111 Tow-hook & Fire Extinguisher, Deeply Fettled Roof S/C Air Intake, Schroth Prof II ASM 4pt Harnesses
#22 (permalink) | |
No Acceptable Substitutes
Also, the ring gets harder to turn as you get to the firmer settings... so it's easier to start low and count up.
2007 AW Lotus Exige S. Opts: Track Pack, Touring Pack, LSD Mods: Multivex mirrors, JLAudio 525/Stealthbox/Focal 130 spkrs, Alpine PDX-5 Amp, Sector111 F&R Tow Hook, Fire Ext, HID Kit, Bootie and Bling, Lotus leather/alcantara interior, Braille Battery, LED Parking/Dome/License Lights, Bane's stealth bulbs, alex's 1/4 turn kit, Stan's shifter mod, jim-c's spkr rings, codymac's 1/4 turn kit, Lotus Cup roof w/fettled clam, Schroth 6pt harness, RAC's & R888's, ChaseCam |
#23 (permalink) | |
Super charged!
![]() I have an 07 with track pack and haven't even tried to change or adjust it because I heard the car has to be realigned after each change. |
#24 (permalink) |
You have to realign if you change the ride height, not the shock settings. So far I've just changed the shock settings, so I haven't had the car realigned.
#25 (permalink) |
Live on the edge
^^^ What he said.
#26 (permalink) | |
HTH, -Ed
-Ed '08 Arctic Silver Exige S240 |
#27 (permalink) |
Mine came with Bliston wrenches. Is that for adjusting the height.
I had an 06 Exige that sat a good 1 inch lower than the 240 and the 06 did not have track pack. Can someone explain why the difference in height between the two?
240S Chrome Orange EXIGE - fast... very fast |
#28 (permalink) |
Yes, the Bilstein wrenches are for adjusting the height. My advice would be to measure the corner weights when you adjust the height (with the goal being equal cross-corner weights). Sorry, I have no idea why your '06 Exige would have had a lower ride height.
#29 (permalink) | |
ride height
The above are my personal observations and not backed by empirical data. |
#30 (permalink) |
Statistical Anomaly
factory settings on S240 track pack is at 3 I believe.
the non track pack suspension is said to be equivalent to a setting of 5, and suggested settings for the track is like 8 and 7 I think so unless you adjust your track pack dampeners it will be softer and roll more than a non track pack setup so I'm told...
Dude, there's my car!
#32 (permalink) |
Really helpful.
I'm not much of a track guy, so that is why on my 06 I didn't get the track pack. I don't like to mess with stuff. I guess I will play around with it, but would like some help. I'm going to change the setting to 6 and see how that feels.
#33 (permalink) |
The instrument panel lighting adjustment has to be done with the ignition on and all the lights on. You have to press and hold the button FOR A LONG TIME - like ten secs or so - just hold it in until you see the lights start dimming - john.
There should be two supplements with the big manual - one for late model Elises and Exiges and one for the S240 - the little booklet supplement has all the stuff for using the electronic goodies - instrument panel, TC, Launch etc etc. There's another 8.5x11 supplement that your dealer can print from the Lotus website that has stuff about the new alarm system and the brakes as well as a list of all the changes in the 08 models. The changes don't end there though - when my tech had mine on the lift for it's 1000mi check he noted a lot of changes to the mechanical parts of the car - for example, there are new rubber boots over some of the suspension joints that were previously known to wear out prematurely and the rear cross bar has been beefed up and the mounting points are different... john.
++++++++++++++++++++++++++++++++++ 08 Exige S 240, Liquid Blue, TP, LSD, Star Shield, Cup Air Box, RLS IC and Tubes... "The early bird gets the worm, but the second mouse gets the cheese." - Steven Wright ++++++++++++++++++++++++++++++++++ Last edited by ocelot27 : 06-24-2008 at 06:39 PM. |
#34 (permalink) | |
spring rates
#35 (permalink) |
Unattractive Nuisance
Svce Manual
Many of us downloaded from the lotus usa web site for $25 or so. If you want hard copy, print on both sides of the paper; it's big. I assume one can still do this.
05 elise (PES chip, SSRs, Sirius, shift tower reinforcement, Multivex; HID low beams) 05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold) "I can resist anything except temptation" O. Wilde. "Political language is designed to make lies sound truthful and murder respectable." G. Orwell, 1946. |
#36 (permalink) | |
#38 (permalink) |
GGM ENFORCER
Jason, I forgot to mention to you...
after I lowered the car I increased the shocks again, I think 7 & 6 from 5 & 4. It was really nice on smooth roads and on canyons, but the car rattled like a mother...It was way to stiff for commuting. I would suggest trying 5 & 4 first.
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 GG EXIGE S ** MY CAR ** VIDEO CLIPS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com |
#39 (permalink) |
Any of you guys have a foam molding piece that is stuck between the removable roof and the back of the cockpit?
Mine is starting to come undone and I can here some wind noise when I play around with it. I don't think my 06 had this foam strip.
