Old 09-24-2007, 02:33 PM   #21 (permalink)
Kevin Menshik
Kevin M's Avatar
Thank you both for the concise explanations. Much appreciated.
Kev
Kevin Menshik
07 Storm Titanium Exige S. Larini de-cat and SE exhaust. Braille B2015 Battery. Green filter, CF splitter, CF side scoops, CF shifter console, CF Access panels. Black wheel and horn badges.
Kevin M is offline   Reply With Quote
Old 09-30-2007, 03:44 AM   #22 (permalink)
Phill B's Avatar
Oil catch cans that are plumbed back into the engine are also known as oil-air separators. A good one will have a tube extending from the inlet fixture almost to the bottom of the can. It should also be half filled with loose (stainless) steel wool - the sort you buy from a supermarket is good as long as it doesn't contain detergent and you loosen it up a bit.
When the hot air/oil mix hits the inside and contents of the can the oil should condense ut and settle in the can.
Apart from the gunking up the blow by oil can also cause engine knock aka pinging, especially on cars with forced induction. You definitely don't want that.
Phill B is offline   Reply With Quote
Old 09-30-2007, 11:51 PM   #23 (permalink)
Not a poseur anymore!
Cool! I have the same Greddy catch can as Kaz on my mr2 turbo. I will keep it in case I get an Exige S.
300hpMR2 is offline   Reply With Quote
Old 10-01-2007, 12:37 AM   #24 (permalink)
necro's Avatar
Images: 1
Was there not a thread with good instructions?
07 SY ExigeS
necro is offline   Reply With Quote
Old 10-01-2007, 12:42 AM   #25 (permalink)
http://www.moroso.com/catalog/catego...?catcode=13400
To go with your oil pan.
smashfactory is offline   Reply With Quote
Old 10-01-2007, 12:47 AM   #26 (permalink)
or here.
http://www.jegs.com/webapp/wcs/store...60679_-1_10475
Old 10-01-2007, 12:50 AM   #27 (permalink)
Shouldnt this be under the "Powertrain" section?
Old 10-01-2007, 05:31 AM   #28 (permalink)
Parts scattered about...
MaineLotus's Avatar
Originally Posted by 25psi_Elise_Killer View Post
You got PM
I'd like to know where you got it also, can you post a link or send a PM?
My car is modified.
MaineLotus is offline   Reply With Quote
Old 10-01-2007, 07:23 AM   #29 (permalink)
Buz
The proper catch can routing is still not clear to me. Is there a need for a can on both breather lines? Which breather line carries the most oil/vapor? Is there an advantage to having the breather hoses continue to the intake after the can or can they be capped off and use a filter on the top of the catch can? Does the pcv valve need to be before or after the catch can? I assume both lines need a pcv valve to keep the intake air from blowing the oil back into the valve cover.
Buz is offline   Reply With Quote
Old 10-01-2007, 09:44 AM   #30 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
You can find it at the bottom of this page:
http://www.roadraceengineering.com/evomisc.htm
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is offline   Reply With Quote
Old 10-01-2007, 06:22 PM   #31 (permalink)
Phill B's Avatar
If your can vents to the air via a filter rather than back into the intake you are very probably breaking local vehicle emission laws.
Old 10-01-2007, 07:01 PM   #32 (permalink)
jkolb's Avatar
Most of the air/oil separators have an oil return line to the crankcase. Has anyone figured out where to run this line?
Jerry
2007 Laser Blue Exige S
1965 Elan (26r clone) vintage race car
2005 Audi S4
jkolb is offline   Reply With Quote
Old 10-08-2007, 08:11 PM   #33 (permalink)
i noticed blow by on my old elise and the S good idea. carl
carl is offline   Reply With Quote
