Old 08-18-2008, 04:11 AM   #321 (permalink)
dmh
dmh's Avatar
Originally Posted by MaineLotus View Post
Does DMH still have his for sale?
Yes, and at an unbelievably low price: $1100 with carbon fiber shroud. See rls intercooler w/shroud & tubes
(At some point I reckon Thomas or one of his dealers will buy it back, don't you think? )
dmh is online now   Reply With Quote
Old 08-31-2008, 09:29 PM   #322 (permalink)
Mag
Madness...
Mag's Avatar
some relevant info from another thread on this forum.
Installed an oil catch can. Appears to make a difference.
1) when took the inlet side pipe off, it was dry inside. In the past there was always oil inside.
2) Notice the max preIC temps when hard driving, high rpm, this is when the most oil would come through. Shows in the comparison between MAX temps at pre IC. However, RLS IC effectively takes out most of the heat from blowback according to data with or with out catch can. Didn't run the w/o can + stocker test.
Prior to current run, car hot from sitting after previous run to gas station & parked for about 30mins: roof 29C, pre 50C, post 50C
Compared to previous test with out catch can:
Ambient 26~28C, Relative humidity 87%
Prior to run, cold car: roof 28C, pre 30C, post 30C
(To mimick the previous test, I drove the car around for 15 mins on hwy to get similar base temps/conditions on both runs. Interesting to note RLS test was in late afternoon. Stocker at night. It was cooler at night. I couldnt work fast enough )
Tests with oil catch:
RLS
Ambient 30C
Humidity 74%
Stock
Ambient 28C
Humidity 78%
Hard drive top speed 117mph, 5mins, 2nd ~4th to 8krpm (same route last test). Didn't do the hwy test again as difficult to mimick a similar run with traffic. In anycase we are probably more interested in how the IC performs during spirited driving. Heat soak properties can be inferred from the data and applied to efficiency in stop and go conditions. Later when I get the fans on, will do a comparison for stop and go.
Here is an overlay of pull #2 of each hard drive log file. The shift points are almost identical, so the overlay is for the two VSS traces over time, rls vs stock. Same road, similar temps (see details in "intercooler flow study" post).
You can see that the rls Intercooler VSS (solid) gets to a given speed faster than the stock intercooler does (dashed line).
91 NSX, 3.2L ITB (in progress)
93 Supra TT
95 BCNR33 GTR, 2.8L TT
00 s2000, 2.2L
08 Exige S240
Mag is offline   Reply With Quote
Old 09-01-2008, 04:25 AM   #323 (permalink)
dmh
dmh's Avatar
Since you guys have now "proven" how wonderfully well the rls intercooler performs how come nobody is buying mine? It practiaccly new!
Old 09-03-2008, 03:54 PM   #324 (permalink)
Internat'l Man of Mystery
Thomasio's Avatar
How much blowby are you getting in the catch can? How many miles on your car? Still breaking in?
07 SY Exige S
really light stuff Intercooler . rls Tubes rls Water/Methanol Injection rls 3.1" Pulley rls Wing Plates .
Prototype Composites CF Roof . PC CF Front Spoiler .
Old 09-04-2008, 05:55 AM   #325 (permalink)
Mag
Madness...
Mag's Avatar
not sure how to measure how much blow by. But it's not that much. less than a full tank after installing the can and car's still relatively new at 6000 something kms... consider broken in by my standards, drive the pi55 outta her.
93 Supra TT
00 s2000, 2.2L
08 Exige S240
Old 09-04-2008, 05:03 PM   #326 (permalink)
Thomasio's Avatar
The rls Intercooler Mk II is back in stock!
The improved Mk II rls Intercooler has redesigned end-tanks for even better airflow, and ships with the new carbon fiber mounting bracket.
07 SY Exige S
Old 09-08-2008, 04:04 PM   #327 (permalink)
Thomasio's Avatar
Here is a detail of the Mk II tapered end-tank. (Shown in clear anodized finish).
07 SY Exige S
Old 09-08-2008, 04:38 PM   #328 (permalink)
Thomasio's Avatar
Comparison of the original rls Intercooler, and the new rls Intercooler Mk II.
(Intercooler on left is non-anodized, intercooler on right is clear anodized.)
07 SY Exige S
Old 09-08-2008, 04:54 PM   #329 (permalink)
MY car weighs 3166lbs
Shorty111R's Avatar
killer!!! I just need an Exige to go with this
"Any car which holds together for more than a race is
too heavy" - Colin Chapman
Shorty111R is offline   Reply With Quote
Old 09-08-2008, 05:09 PM   #330 (permalink)
Shorty111R's Avatar
Old 09-16-2008, 09:03 AM   #331 (permalink)
Thomasio's Avatar
I did some data acquisition at Autohbahn raceway in Joliet, IL yesterday.
This graph shows charge air temperature, both pre and post intercooler. This data is after 20+ minutes of full out running, and shows the maximum temperatures achieved in a 30 minute session.
Pre-intercooler charge air temperatures are the red and dashed-red curves (top two curves).
Post-intercooler charge air temperatures are the blue and dashed-black curves.
The dashed-black curve is without water/methanol injection, the solid blue curve is with water/methanol injection.
As you can see, the rls Intercooler alone took out up to 100 degrees F. The rls Injection took up to an additional 30+ degrees F out of the temperature.
The hotter things got, the better the equipment worked...
07 SY Exige S
Old 09-16-2008, 09:43 AM   #332 (permalink)
Smoky's Avatar
Data from all sources points to good things Thomas.
And folks, the clear anodized is gorgious. And it's nice knowing it'll last forever without any possibility for rust spots and other signs of ageing. Highly recommended.
Thx Thomas! (Ya, the i/c arrived... hurricane delayed it a few days, but it's here safe and sound!)
-Smoky
'07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, S111 Ultra Discs
Smoky is offline   Reply With Quote
Old 09-16-2008, 02:16 PM   #333 (permalink)
Dear Thomasio
I'm interested in the intercooler where I can find it?
Ciao
Streetracer80 is offline   Reply With Quote
Old 09-30-2008, 07:59 AM   #334 (permalink)
Thomasio's Avatar
Originally Posted by Streetracer80 View Post
Dear Thomasio
Ciao
I'm not sure how I missed this one...
You can purchase from BWR, FVMC, or myself.
07 SY Exige S
Old 10-17-2008, 11:55 AM   #335 (permalink)
Thomasio's Avatar
Listen up, naysayers and those who are spewers of misinformation and innuendo!
The rls Intercooler has been proven on the dyno, at the track... now an independent race shop has benchmarked the flow of the stock Exige S, the rls Intercooler, and the Lotus Cup intercooler.
Stay tuned...
07 SY Exige S
Old 10-17-2008, 04:42 PM   #336 (permalink)
dmh
dmh's Avatar
Stay tuned...
You must be speaking about us!
We had the rls flowed at 28" and got 320 cfm.
We tested the stock to rls A:B style at Watkins Glen this past summer. The crew did the work, I did the driving. It was unknown to me which intercooler was on the car.
On average, the stock intercooler was 1.524 seconds a lap faster than the rls with an average time of 2:10.640 (8 laps).
The reason probably is due to the increased volume of the rls which lowers the boost over the stock intercooler. The rls is also heavier which is not good in terms of performance because heat dissipation is harder to accomplish, i.e., its heat soak is harder to overcome.
Both the stock and rls took out about 105* F of charge temperature.
Old 10-17-2008, 07:33 PM   #337 (permalink)
Thomasio's Avatar
Don - put your money where your mouth is. $10,000 challenge: you have 48 hours from the time stamp of this message to put up or shut up Don. [Offer goes to anyone, not just Don... naysayers: pool your money together?]
We will have a neutral party, say Randy Chase, hold my $5,000 and your $5,000. If the following is not true, you will take the $10,000. If the following is true, I will take the $10,000.
An independent professional race shop, with no affiliation with me or my company, using a SuperFlo SF-600, flow tested these three intercoolers, and reported the following:
Stock (OEM) Lotus Exige S intercooler: flowed 363.9 cfm at 48" of water.
Lotus Cup intercooler: flowed 407.0 cfm at 48" of water.
rls Intercooler: flowed 409.7 cfm at 48" of water.
What do you say Don? Randy, are you willing to hold the $5,000 for each of us and decide on the evidence?
[Edit: expand offer to all naysayers.]
07 SY Exige S
Old 10-17-2008, 07:36 PM   #338 (permalink)
Thomasio's Avatar
P.S. Increased mass and volume are partially responsible for the increased efficiency of the intercooler. There are few people in the world that will argue otherwise.
The dyno, data logging, and flow benches all point to one conclusion: the rls Intercooler is superior to the stock intercooler, and on par with the $2,200 Lotus Cup intercooler.
Don - please explain how an intercooler that flows more, dynos more power, and lowers IAT's more, can be slower on the track (when you are driving).
07 SY Exige S
Old 10-17-2008, 07:51 PM   #339 (permalink)
Thomasio's Avatar
The race shop has been in business since 1983. Here is the flowbench machine:
07 SY Exige S
Old 10-17-2008, 08:25 PM   #340 (permalink)
Thomasio's Avatar
$10,000 challenge time remaining:
07 SY Exige S
HTML code is On
