#61 (permalink) |
really light stuff
![]() Join Date: Jul 2003
+6.5% horsepower on the Exige S, stock ECU, stock intake, stock airfilter... stock.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#62 (permalink) |
Blue Wheel Pimp
so in other words..... No, No, and 80. Thanks for answers to questions I didn't ask.
This heatsoak would be MUCH better represented with actual numbers. I'm also assuming that driving conditions were attempted to be simulated with significant air moving through the IC.
AJ - Akua Solutions - #128 Lotus Exige - JRZ Suspension - Innovative Mounts - Toyo Tires - TW Research Development |
#63 (permalink) | |
really light stuff
As I've pointed out, I don't have the data until I get it electronically from the dyno owner. From memory, outlet temperatures with the stock intercooler were up in the 130 F range (worst case), and in the 90 F range with the rls Intercooler (worst case). The test conditions were normalized for each run, and a fan was pointed at the rear of the engine bay and remained in place for every baseline run (stock intercooler) and every rls Intercooler run.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel Last edited by Thomasio : 06-04-2008 at 01:54 PM. |
#65 (permalink) | |
really light stuff
To be very clear: stock 2007 Exige S, plus rls Intercooler: +6.5% horsepower gain. Stock 2007 Exige S, plus rls Intercooler, plus rls 3.1" Pully: +14.5% horsepower total. On the DynaPack chassis dyno, 202 horsepower at the wheels. Some say that this equates to 220 horsepower on a DynoJet dyno. I'd like to try with CharlieX 's Gotham tune.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel Last edited by Thomasio : 06-04-2008 at 01:57 PM. |
#67 (permalink) | |
Blue Wheel Pimp
#68 (permalink) | |
really light stuff
I'll post some graphs when the dyno data comes in.
#69 (permalink) |
Add Lightness
I'd be curious how much of the difference is due to just heat soak on the dyno. For example, is that the difference of the averages of the dyno readings between the two setups? Or is that the difference between the first run of each setup on the dyno?
I imagine that the heat soak for the engine running on the dyno (especially for the non-rls intercooler) is greater than if you're on the street in normal driving or on the track with greater air flow. So would the real world/track gain be less than the 26 HP stated?
'06 CO Exige - sold |
#70 (permalink) |
A pound at a time.
How does your strut that holds the lid up modified? Pics please
07 Exige S - PhB., TP, TP, LSD, S111 Rear Panel Delete, 2Bular De-Cat, 2Bular 8x24 Burnt GT3, Custom AEM Intake, 6k HID's, Schroth 4pt ASM Harnesses, Milled Steering Arms, Bronze Volk TE37 w/ RE-01R's, Carbon Craftsquare Mirrors, Carbon Front Lip, Benetec Dry Carbon Undertray/Diffuser |
#71 (permalink) | |
really light stuff
That difference only gets greater with heat soak, because the stock intercooler heat soaks far worse and far faster. Results will be posted as soon as I get the data, that will show the trends better than I can describe. It was impressive.
#72 (permalink) |
I can back up the shocking stock heat soak issue on my 08 S 240. It was jaw-dropping how fast the stock intercooler soaked - IAT rose to over 140°F and WHP dropped by about a wopping 25WHP during three quick pulls. We pointed a fan at the engine bay and got an extra 19 WHP out of the stock IC for a best of 218.11WHP. The stock IC sucks monkey balls - that's the bottom line. I can't wait to get my RLS IC installed...
![]() ![]() - john.
++++++++++++++++++++++++++++++++++ 08 Exige S 240, Liquid Blue, TP, LSD, Star Shield, Cup Air Box, RLS IC and Tubes... "The early bird gets the worm, but the second mouse gets the cheese." - Steven Wright ++++++++++++++++++++++++++++++++++ Last edited by ocelot27 : 06-04-2008 at 03:46 PM. |
#73 (permalink) |
Blue Wheel Pimp
hmm..another curiosity question, does the black anodizing have any effect on performance? Talking about the RLS unit.
#74 (permalink) | |
I would also want to get mine black anodized. Interested in this response.
-Smoky '07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, ACT XTSS Clutch, Fidanza Flywheel, S111 RTD brace, S111 Ultra Discs, rls Intercooler, Goodrich S/S brake lines, Innovative engine mounts, Valentine 1 |
#75 (permalink) |
Republic to Thugocracy
Ocelot27-
Only 140 degrees. I see over 200 Without a proper dyno facility, one where you can control the environment, you are just wasting your time and money, i.e., the results are worthless. ![]() See this page: DMH Motorsports
"This is the moment when we must come together to save this planet. Let us resolve that we will not leave our children a world where the oceans rise and famine spreads and terrible storms devastate our lands." Community Organizer and Chief Obama...now intervening with natural occurrences!
#76 (permalink) | |
-john.
++++++++++++++++++++++++++++++++++ 08 Exige S 240, Liquid Blue, TP, LSD, Star Shield, Cup Air Box, RLS IC and Tubes... "The early bird gets the worm, but the second mouse gets the cheese." - Steven Wright ++++++++++++++++++++++++++++++++++ |
#77 (permalink) | |
The facility I use is climate controlled with AC and therefore the temp and relative humidity are relatively constant. The results are not worthless and I'm not wasting my money. As long as all the runs are done under similar conditions valid conclusions can be drawn. I have a degree in mechanical engineering and I know a thing or two about heat transfer. You've missed the point - the stock IC soaks very rapidly and would soak very rapidly in any dyno environment because it has a low heat capacity. Lotus had design criteria which were reached by their engineers - that doesn't mean they can't be exceeded by other engineers with different design criteria. If you don't want to be part of the experiment that's fine but don't tell us that the study is invalid when in fact it's very valid and very pertinent; the fact that a more massive IC can absorb much more heat does not need to be proven - it's a fact of heat transfer. -john.
#78 (permalink) | |
Well, maybe you ought to figure out who is out there. For one I am and I can tell you for certain that your information is inaccurate. Our dyno cost $250K Not to mention the facility. And in another facility down the road a colleague is building an engine dyno for race teams that he supplies engines to -- Grand AM & ALMS. Similar conditions? Controlling all the variables -- are you sure? For if just one is off the data is invalid. Just one! Did you read the short essays on the web page? And if so, did you understand them? No I have not missed the point...yes, the Bell intercooler is more massive by what, 20%? I've been waiting for mine for weeks now. But they will only work on the race track where air flow is sufficient to cool them. For the street why care about heat soak? Stop light to stop light Speed limit 70 MPH ![]() This is what DMH Motorsports does. Want more information then call, email, or go to monkeytuner and ask me there. Don
#79 (permalink) | |
I know you do this for a living which introduces a conflict of interest with a competing supplier - are your posts just biased by this? Yeah, if one condition is slightly different what is the real effect on the data acquisition - is it significant or within the standard deviation of the instrument? We all do the best we can with what we have available - if you'd like I can come to your facility and you can do the testing - I live in near Philly. But somehow I don't think that's the underlying issue here. Everyone jumps all over Thomas for not supplying "data" - he's working on it - lets give him a chance. My data illustrates how fast the factory cooler soaks - do you dispute this? When I install the RLS cooler I hope the data will show that it doesn't soak as fast. - john.
#80 (permalink) | |
If you were at my shop don't you think I would know it? ![]() Your data is invalid because it is was not repeatable -- pull to pull. Your IATs were way too low. What was it pull to pull? What was your oil temp? What was the torque on the tie down straps? Your tire pressure? Etc. Variables matter. Even more so on inertia style dynos. Conflict? I don't sell intercoolers. And I'm trying to do business with RLS. ![]() All of these type of intercoolers will heat soak. What is your point? Better yet, what was the point of your dyno pulls? Were you testing or tuning? Or simply seeing what your car made? ![]() Hoping? Are you kidding ![]() Thomasio: "That difference only gets greater with heat soak, because the stock intercooler heat soaks far worse and far faster. Results will be posted as soon as I get the data, that will show the trends better than I can describe. It was impressive." Real world data rather than dyno data I hope. I am all for helping but come on now...
