#82 (permalink) | |
You use the fact that you own a tuning shop to give you credibility but I suspect your motive is disputing the effectiveness of the RLS intercooler - mark my words and time will prove me right on this - planning a competing product are we??? The point was not to measure WHP accurately - the point was TO SHOW HEAT SOAK OF THE FACTORY COOLER.
++++++++++++++++++++++++++++++++++ 08 Exige S 240, Liquid Blue, TP, LSD, Star Shield, Cup Air Box, RLS IC and Tubes... "The early bird gets the worm, but the second mouse gets the cheese." - Steven Wright ++++++++++++++++++++++++++++++++++ |
#83 (permalink) |
McLareghini Bugatterrari
Confusion:
I understand the point being made about a higher mass will allow the unit to absorb a given amount of energy while maintaining a relatively lower temperature. So while sitting at a stop light the IAT won't rise as much. But once the throttle is opened, won't that same amount of heat energy be transferred back into the IA? At a slower rate of course, but the IAT is still raised, right? It's just a matter of it being raised to a lesser degree, but also taking longer to get back to baseline temp once you're rollling, right? xtn
#84 (permalink) | |
really light stuff
![]() Join Date: Jul 2003
This is very similar to the results that we recorded with the '07 Exige S w/ stock intercooler. The facility that I used was a Dynapack chassis dynamometer.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#85 (permalink) |
really light stuff
And we are trying to do business with you.
Resent that Paypal invoice, did you check your spam filter?
#86 (permalink) | |
really light stuff
#87 (permalink) |
Add Lightness
Better stated, your point was to show heat soak of the factory intercooler in a dyno environment. The rls intercooler might/should perform better in regards to heat soak on a dyno, but how about on the street or on the track? If somebody can show this and/or show some track time differences, that would be more relevant.
(cool link Don)
'06 CO Exige - sold |
#89 (permalink) |
I think it can be concluded that improvements in the absence of cool air flow in a dyno setting could only make the car that much better with cold air flowing over an even better IC? Lotus also pretty significantly changed the roof scoop on the 08's so they wanted to get more cool air to their IC for some reason.
-john.
#90 (permalink) | |
Republic to Thugocracy
"This is the moment when we must come together to save this planet. Let us resolve that we will not leave our children a world where the oceans rise and famine spreads and terrible storms devastate our lands." Community Organizer and Chief Obama...now intervening with natural occurrences!
#91 (permalink) | |
#92 (permalink) | |
really light stuff
Moving the roof scoop opening to the high pressure area of the winshield helps too. All of these incremental improvements add up. Airflow is certainly the weakest link.
#93 (permalink) | |
Thanks for the update Don - I can read too. Must you try to insult me at every juncture? The design was changed for the PRODUCTION 08 Lotus Exige correct? I'm struggling really hard here to try to get you to be nice. Maybe you can agree on this: "the sky is sometimes blue" Once again you've made claims about my data ("without proper data logging") without explaining yourself? I've asked you repeatedly to educate us all and tell us how you can tell from the plots exactly how the tests were performed and that the data is "invalid." Can't do it can you... that's what I thought. Lastly, what's your motive for being so negative about all this? -john.
#94 (permalink) | |
really light stuff
Guys, we are all trying to solve the same problem, let's put our heads together. It sounds like you have a very sophisticated dyno, we all will appreciate your data when it is available. Some of us are engineers, some of us are tuners, some of us have the best dynos, some of us have incredible knowledge of the inner workings of the ECU, some of us just have a lot of experience. We all learn from each other and come together to push the state of the art. (Lotus engineers watch the 3rd-party development here... we are actually helping Lotus improve future cars... that's pretty cool! )Nobody is trying to trick anybody, we are all using the best science that we have available. The more input we have, the better. The heat soak problem wasn't discovered on the dyno, it was discovered on the street and on the track. The dyno is simply one tool to approximate "real world" conditions. It is not good to draw broad conclusions from the dyno alone. That being said, results on the dyno can certainly be valuable ways to understand what is happening. Data logging is the other. In the words of Rodney: "can't we all just get along?"
#95 (permalink) | |
What do you mean by fettling? Fettling what? And which plastic duct do you mean? The one going from the scoop to the i/c? Or some other duct? Do you have a pic of this work? Thx!
-Smoky '07 Exige S, Chrome Orange, Track/Touring, LSD, Starshield, 2Bular 8x24, ACT XTSS Clutch, Fidanza Flywheel, S111 RTD brace, S111 Ultra Discs, rls Intercooler, Goodrich S/S brake lines, Innovative engine mounts, Valentine 1 |
#96 (permalink) | |
really light stuff
John and Don - I think you both have valuable data. Don - I get the impression that you are a perfectionist and a master of your trade, and that you are chomping at the bit to get some data using your methods - that's awesome, we can't wait... just go easy on those of us who don't have access to your pro motorsports facilities. We all want to see what you come up with, we are doing the best that we can with the resources that we have. Nobody is claiming that the rls Intercooler is the *best* solution that will ever be created. It is *a* solution. Your testing will show us how good it is in real-world track conditions. My testing shows dyno and street conditions. This is great R&D, and it is exciting to be a part of it.
#97 (permalink) | |
"Similar conditions? Controlling all the variables -- are you sure? For if just one is off the data is invalid. Just one! Did you read the short essays on the web page? And if so, did you understand them? " Did YOU read them and did YOU understand them? -john.
#98 (permalink) | |
really light stuff
If you do a search on Lotus Talk for "fettling" you will find some good tutorials. I do have pictures but can't post them now - I'm out of town. Basically, "fettling" is grinding away the edges of the duct openings that restrict airflow. When you remove the roof panel, and look from the passenger cabin toward the rear of the car, you will see the opening at what I'm calling the header-panel. (The part between the roof panel and the engine bay cover.) Inside of the opening in the header-panel, you will see the black plastic ABS (acrylonitrilebutadienestyrene) duct. Look closely, and you will see that it is not sealed to the header-panel / rear clamshell, around the permimeter. You will see a large gap, perhaps 1/8" to 1/4", around the perimeter. Fill this in smoothly with silicone (black or clear). This will prevent some of your fresh air from spilling out around and in between the ABS-plastic duct and the header panel opening.
#99 (permalink) | |
Where the roof meets the rear clam. Take the roof off and look at the duct - it's about 30% occluded by a lip in the rear clam - you just grind this off with a dremel. I recommend having a friend hold a vacuum cleaner close to the bit - this will collect almost all of the dust. -john.
#100 (permalink) |
Lotus Service
![]() Join Date: Oct 2006
thomas in my opinion your doing a wonderful job.
![]() and i know as soon as you get the graphs and data logging info you will post them. i am not trying to be rude, i just wish if the 2 parties arguing would start there own thread to do so, it would help us get updates on thomas' parts more easily, thank you.everyone keep up the great work on this products development!!!! ![]() T.J. |
