really light stuff
![]() Join Date: Jul 2003
Really Light Stuff - Supercharger Pulleys
Since the other thread has been deleted, I will be recreating the thread here. Pardon the work in progress...
RLS Supercharger Overdrive Pulleys Available in 3.1", 3.0", 2.9", and 2.8" diameters. We recommend engine tuning for anything beyond the 3.1" pulley. Make sure you have a wideband AFR to keep an eye on things. $98 plus shipping.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel Last edited by Mr. Know : 11-05-2009 at 11:16 PM. |
#3 (permalink) | |
really light stuff
My car already had an RLS Intercooler when I switched form 3.28" to 3.1". There was about a 0.5 psi increase in boost, about 14 HP. The dyno is posted on LT in one of the intercooler threads. The intercooler was about a 14 HP increase over the stock intercooler, and the pulley was another 12 HP on top of that. These #'s are from memory, I'll try to find the dyno in the other thread and link to it. I have not dyno'd stock intercooler + 3.1" pulle. Stock 2007 Exige S, plus RLS Intercooler: +6.5% horsepower gain. Stock 2007 Exige S, plus RLS Intercooler, plus RLS 3.1" Pully: +14.5% horsepower total. Yes, it was noticeable. Enough to make me smile.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel Last edited by Thomasio : 11-03-2009 at 09:31 PM. |
I <3 chicken, I <3 liver
found 'em.
top: RLS intercooler only bottom: RLS intercooler and 3.1 (IIRC) pulley.
how long does it take to install a pulley?
Mods are good for you
Less than an hour, I can do one easily now in 45 minutes.
Jack car Remove RR wheel and liner Remove pulley bolt (note remove bolt before belt or it will turn the shaft) Pry tensioner and slide belt off pulley Remove/replace pulley (will take a few extra minutes with a stock as it's on tight) Reverse order. I have used Thomasio's 3.1 and 3.0 on the 240...they are good quality and a substantial rotational mass savings.
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#8 (permalink) |
Haxord but mine
Haha! Probably not on your first time though
![]() Hell it took me longer then that just to figure out how the tensioner worked! But now that I know how everything works, ya you can change a belt out in like 15-20 minutes....taking the wheel off & on probably takes most of the time.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? |
#9 (permalink) |
really light stuff
Good find! I was looking everywhere, almost had to get out my old hard drive.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#10 (permalink) | |
really light stuff
#12 (permalink) | |
really light stuff
It is easy enough for you to try the 3.1" and dyno it... ![]()
#13 (permalink) |
really light stuff
Over the last couple of weeks certain pulleys were out of stock, but 2.8", 2.9", 3.0", and 3.1" pulleys are all back in stock now.
#14 (permalink) | |
#15 (permalink) |
what is the diameter of the VF2 SC kit pulley?
-Robert Do you know the weight saving between the oem mp62 steel pulley and rls if we say the size is 3.0? -Robert
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
#16 (permalink) |
Click links to see my 2008 Lotus Exige-S 240 , '99 M3, 505rwhp '89 Mustang (
sold) , '05 WRX STI ( sold) homepages or here for my M3 vid (11MB) |
#17 (permalink) |
really light stuff
Argh, it was in the original thread that got "lost." I think it was on the order of 2/3 lb, but it could have been less.
#18 (permalink) |
VF2 is 2.9" IIRC.
#19 (permalink) |
really light stuff
2.8", 2.9", 3.0" and 3.1" pulleys are all in stock now. Other sizes are available, PM me.
