Old 10-21-2009, 07:31 PM   #1 (permalink)
Exige S240
BadtZ's Avatar
S240 track pack need RTD brace?
do S240 fully loaded including track package need the famous fix RTD brace for the rear links?
Larini 6" Sport, DBW Pedals...and minor stuff
So far so good
BadtZ is offline   Reply With Quote
Old 10-21-2009, 09:09 PM   #2 (permalink)
I believe the track pack includes a Lotus version of the brace, but from what I've read it's not as robust as the RTD variant. I'm sure someone will chime in with a more technical explanation, or point out if I'm wrong
Savet is offline   Reply With Quote
Old 10-22-2009, 12:56 AM   #3 (permalink)
ads_green's Avatar
It does have a brace and the only difference is that it's not anchored in the middle near the engine mount - it just links the two rear suspension mounting points together. This is standard on the 211 and works with slicks so I don't think it's worth swapping out.
ads_green is offline   Reply With Quote
Old 10-22-2009, 07:03 PM   #4 (permalink)
Exige S240
BadtZ's Avatar
alright cool! basically now I need to fix fuel starve and engine mounts only now
Thanks Guys
So far so good
Old 10-22-2009, 07:23 PM   #5 (permalink)
38bfast's Avatar
and the oil starvation.
Ralph Provitz
2008 WHRRI SM Champion
2008 WHRRI Top 10 Driver
2006 Exige
V2 Motorsports
38bfast is offline   Reply With Quote
Old 10-22-2009, 07:36 PM   #6 (permalink)
User Restricted By ΑDMIΝ
apk919's Avatar
Images: 20
+1
Old 10-22-2009, 07:43 PM   #7 (permalink)
Exige S240
BadtZ's Avatar
oh crap and the oil....DO LOTUS KNOWS ABOUT THESE SH*TS?!
So far so good
Old 10-22-2009, 07:45 PM   #8 (permalink)
apk919's Avatar
Images: 20
Lotus is quite aware of the oil starvation problem... their solution is to install an Accusump on all their dedicated track cars.
Most of us who track our cars go with a baffled oil pan.
Old 10-22-2009, 07:46 PM   #9 (permalink)
^^ those DBW pedals are awesome aren't they! I bought 3 sets (for different cars) from SRP (the supplier to S111) they make h&t easy as pie.
06 Exige CO BWRized
05 Civic "Special Edition"
05 Elise CO, Trim shop interior and other things...SOLD
ACE51 is offline   Reply With Quote
Old 10-22-2009, 07:55 PM   #10 (permalink)
jmiesse's Avatar
and the fuel starvation.
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II
Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror
jmiesse is offline   Reply With Quote
Old 10-22-2009, 08:10 PM   #11 (permalink)
Metallic Rattle 4ever
mgreenbl's Avatar
and the lost power from heat soak...Andy can chime in on this!!
Mark
*former* Porsche lover
mgreenbl is offline   Reply With Quote
Old 10-22-2009, 08:15 PM   #12 (permalink)
apk919's Avatar
Images: 20
Mark
True, but it's not a safety/reliability issue, just a performance issue...
Old 10-23-2009, 06:40 AM   #13 (permalink)
Project Nirvana Elise
shinoo's Avatar
You should be fine with the factory brace. Check the stock rod ends as they do become loose over time - but they usually cover them under warranty.
Our baffled oil pan is almost ready for release. You'll also want to check out our new Catch Cans. Easy install and removal when you need to drain 'em. Both will be ready by Thanksgiving.
Fuel starvation can covered by either keeping the tank fairly full or our V2tank. The V2tank has been run down - in race conditions - to 1 gallon of fuel with safe fuel pressures. We have the data to prove it.
shinoo
sector 111 - tasty bits for your elise & exige
shinoo is offline   Reply With Quote
Old 10-23-2009, 07:34 AM   #14 (permalink)
DPM
DPM's Avatar
I'd go with Sector111 RTD over the factory one. I saw a 2Eleven last week with a broken one, guess what he replaced it with? Sector111
2006 Diasio D962R Arancio Borealis
SOLD: 05 Elise, Benetec Carbon Fiber full body & rear wing, FF 275 turbo kit , Ikeya sequential shifter, Ohlins coilovers, Porterfield R-4, Sector 111 RTD brace & HNT pad, Yokohama A048, Caterham seats, Simpson 5 point belts, Moroso oil pan, Sector 111 Boomerang, AutoMeter CF Oil Pres-Boost-Vac gauges. No AC, heat, airbags. 1619 pounds "wet"
DPM is offline   Reply With Quote
Old 10-24-2009, 02:56 AM   #15 (permalink)
Exige S240
BadtZ's Avatar
Talking to my Pedals? Yes they are awesome! got lots of pedal grip on them because of their surface finish and I dont think I can HT on any other cars now
Originally Posted by shinoo View Post
You should be fine with the factory brace. Check the stock rod ends as they do become loose over time - but they usually cover them under warranty......
Right now my lotus is still street driver, but I rmb reading somewhere even a full tank of fuel wont safe you in the track?
hmmmmmm Ill just check them frequently and wait till they break then
So far so good
Old 10-24-2009, 04:37 AM   #16 (permalink)
DPM
DPM's Avatar
When it spontaneously breaks be prepared to replace a lot more parts,(half shafts, rear clam to name a few). You'll have no idea when it is going to happen, it just goes.....
