Old 09-02-2009, 07:54 PM   #1 (permalink)
Exclamation Shifting Issues
I'm having some issues with the shifting on my 240S. When I downshift from 3rd to 2nd it grinds a bit.
I track the car often probably about 3-4 times a month. I have less than 3K on the car.
I recently installed Shifter re-enforcer & engine mounts hoping it would help with the shifting problem......NOPE...NO LOVE
TexasHooligan111 is offline   Reply With Quote
Old 09-02-2009, 07:58 PM   #2 (permalink)
FIL
Serial Thrilla
FIL's Avatar
Seems too obvious, but you sure you are good on transmission fluid.
Grinding on down shifting sounds like a synchro issue.
05' Elise - BWR supercharger, Quaife LSD, Nitron Race Triple Adjustable, LETSLA, Larini Decat, Larini Exhuast, ACT HDSS, Fidanza flywheel, V2 Fuel Tank, V2 Steering Arms, BWR sway bar, desnorkled, ForcedFed CF splitter, Manly's engine mounts, S111 harness bar, Schroth harness w/ S111 seat grommets, Oil Drain Valve, Painted Black Diffuser, Braille battery, Custom Battery Switch
05' Corvette - Z51 Convertible - 630hp 6.6L [DON'T YOU JUDGE ME!!!] (SOLD!)
FIL is offline   Reply With Quote
Old 09-02-2009, 08:03 PM   #3 (permalink)
I'm going to have to check it out in the morning. I'm pretty hard on the car at the track and I always use the clutch
Old 09-02-2009, 08:04 PM   #4 (permalink)
where can I download the workshop manual for my 2008 240S?
Old 09-03-2009, 05:00 AM   #5 (permalink)
User, Registered
fpitas's Avatar
Lotus Elise Maintenance, Drain and Refill Gearbox Oil
Tried MT-90 yet? It worked for a lot of us.
Changed Transmission Oil... Used MT-90
BTW, the tranny can also be filled from the top, using a hose attached to a funnel. No necessity for a pump unless you just prefer that way.
Francis
