Old 06-21-2009, 02:59 PM   #1 (permalink)
exlondoner's Avatar
Trunk lid removal
Has anyone done this, I'll be doing a bunch of work tomorrow and it would make is so much easier if I the lid was removed.
Any instructions or pics would be appreciated.
Thanks
exlondoner is offline   Reply With Quote
Old 06-21-2009, 05:34 PM   #2 (permalink)
luxige
luxige's Avatar
Unfortunately, the Repair Manual only covers the Elise engine lid in any detail, and only glosses over the Exige tailgate. These pics may help:
luxige is offline   Reply With Quote
Old 06-21-2009, 06:27 PM   #3 (permalink)
exlondoner's Avatar
Greg thanks the schematic.
I can see a few bolts that attach the boot
to the hinges however I'm just unsure about the piece that holds the thing that locks and hold the boot up?
Old 06-21-2009, 07:50 PM   #4 (permalink)
Head LOONY
tvacc's Avatar
This is so simple. Just 2 bolts and it comes right off. Make sure that you dont loose the washers. It should take you 5 min.
Tony Vaccaro
2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter,
www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus
Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances
tvacc is offline   Reply With Quote
Old 06-22-2009, 10:28 AM   #5 (permalink)
I approve this message
skibum's Avatar
To pop off the strut, you will see a small retaining clip on the back of the piece that can be pryed off with a screwdriver in 5 seconds. After you get that off, the end of the strut just slides off the mounting ball that it locks on to.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934#
2004 s2000 - 378 whp 295 trq
2005 Mini Cooper S
2008 Honda Fit - 35mpg y0!
1965 Austin Mini w/ vtec
skibum is offline   Reply With Quote
Old 06-25-2009, 10:26 PM   #6 (permalink)
Enthusiast
SpecRaceM5's Avatar
Best to have a second set of hands to assist. The lid weights a ton and can be awkward to remove by yourself. I typically start by removing 1 of the 2 screws on each side (4 screws total). Make sure to capture the shims and keep them in their correct position on re installation. Then I loosen the other 2 bolts and right before they are off I pop the clip off the strut. Then finish by removing the 2 remaining screws completely and sliding the strut off the lid. Re-installation is a bit more tricky but basically the reverse order with some alignment added on. Hope that helps. Oh and do yourself a favor and tape off the edges of the lid and the area surrounding the lid on the rear clam. This will prevent chips and scratches since you will likely rub the lid on the clam a little at some point.
Cheers,
Brian
Brian Eyerman
Spyder1
SpecRaceM5 is offline   Reply With Quote
Old 06-25-2009, 11:37 PM   #7 (permalink)
Hoon
Amarao's Avatar
If you remove the wing first the hatch is pretty light actually.
Amarao is offline   Reply With Quote
Old 06-28-2009, 05:22 PM   #8 (permalink)
exlondoner's Avatar
Thanks all, I managed to remove it myself, and will be re-installing it by the end of week - very straight forward.
Old 06-28-2009, 05:31 PM   #9 (permalink)
Great tips, I will be doing this once I get my CF lid from the esta group buy
05 Elise - Storm Titanium Red Leather/Touring/Starshield/Hard Top
Arqray Single Titanium/Forced Fed Race Headers/Fujita Intake/CF Zoom Rearview/CF Binnacle/CF ReVerie Shift Knob/CF Engine Lid w/ Exige Mesh/CF Hardtop/CF Roll Bar Cover/CF Access Panels/CF Forced Fed Front Lip/HID's 6000k 55watt//Black Wheels,Badges, Black Front Emblem/Black Diffuser/Ardent Red Engine Covers/Interior Carpeting Removed + Sound Deadening Foam
KeepItClear is offline   Reply With Quote
