Old 09-02-2007, 11:20 AM   #21 (permalink)
Elise Royalty
Patricko's Avatar
Originally Posted by wildwhl View Post
Paricko -
I can appreciate your comment on lugging the engine, but if you're just cruising around (i.e. little to no load) I don't see the specific concern, though your point is well taken. Even so, I doubt lugging at that RPM range will cause any issues other than getting your ass run over for lack of acceleration. Of course, in my case, things sound so much better (2bular) over 4K I keep it there anyway
WW
Yes, but if the engine is propelling the car it is under load, and the engine will be laboring just as the manual advises against.
I can remember seeing somewhere (years ago) that around 4k rpm is were you should be for maximum fuel economy.
Patricko is online now   Reply With Quote
Old 09-02-2007, 12:26 PM   #22 (permalink)
If you drive 65-70 mph on level ground without needing to accelerate, you can drive in 6th gear 3400-3600 rpm all day without hurting a thing (Elise/Exige). If you come up to a slight upgrade, passing, accelerating, then you can drop it down as many gears as you need to...*without over-revs.
The higher rpm (mentality) is from race cars, that usually have radical cams, timing, fueling, etc. Even a rally Porsche (70's era) that I had would track without a problem if the revs were over 3500 rpm...and the engine was trick...1000 rpm higher than normal ones of it's day.
What manuals say is just to protect bozos that don't know how to drive a stick and match proper rpms.
I wouldn't listen to housewives tales from 30-40 years ago relating to rpms. Just don't lug it and you'll be fine. You can lug it at 4000 rpm if the hill is steep enough and the wrong gear is selected. JMO
Ol'Racer is offline   Reply With Quote
Old 09-02-2007, 12:45 PM   #23 (permalink)
Nightfall Blue
lotus54's Avatar
Yes, if you are just giving it a tiny bit of throttle, the engine isn't 'labouring'. If you gave it more, then it could be depending on rpm.
Maybe an extreme example, but you couldn't even idle it out of the driveway without damage with the '4k rule'. I know it wasn't meant that way, but that is still the point I'm trying to make.
You don't really want heavy throttle at really low rpms. But I don't think cruising along at a lower rpm will do anything at all to damage it. Cruising isn't labouring. The BMEP is low and with all the modern electronics the engine runs just fine.
Of course, that is just my opinion.
lotus54 is offline   Reply With Quote
Old 09-02-2007, 01:05 PM   #24 (permalink)
It's a Lotus
LARRY's Avatar
Originally Posted by lotus54 View Post
I had a slow coolant leak on my '05 Elise. It was the radiator hose, slightly loose clamp.
This has been discussed here before.
But what you describe seems different.
I'd like to see the bulletin notice. Since I live a long way from any dealer, it might be something I should have them look into.
Mark
Mine had this exact problem. Radiator hose in the front of the car. Hose clamp let go.
2005 Saffron Yellow Elise, Sports & Touring Packages, Hard Top, Stage II Exhaust, '07 Probax leather seats. Los Angeles Lotus Service by Qais at 310-200-0022.
LARRY is offline   Reply With Quote
Old 09-02-2007, 02:23 PM   #25 (permalink)
Elise Royalty
Patricko's Avatar
Everything I am talking about is specific to the 2ZZ Elise/Exige, not old school myths.
The bottom line is that there is no reason to be bellow 4k rpm in this car if you are above 30 mph.
Old 09-02-2007, 02:54 PM   #26 (permalink)
Dan D
LBC111's Avatar
I wouldn't listen to housewives tales from 30-40 years ago relating to rpms. JMO
SORRY, BUT I'LL TRUST PATRICO'S WORD ON THIS.. OVER ANYONE ELSE IN THIS PARTICULAR THREAD.
TAKE NOTE OF 1) HIS JOIN DATE, 2) THE NUMBER OF HIS POSTS 3) THE ACTUAL CONTENT OF SOME OF THEM
BOTTOM LINE - I THINK HE KNOWS WHAT HE'S TALKING ABOUT!!!
But, in the end, it's your car. Do what you want.
07 Exige S: GG, Track Pack, V1, RV Camera, S111 CF roof and splitter, 4.5-lb Voltphreaks battery, 10-lb Von Hep Exhaust, Green filter, 265 crank hp +/-, Volk TE 37 Wheels, RTDbrace, Scroth 6-point ASM harnesses, W2A IC to come??, 1965 lbs total weight (est)
05 Elise: Storm Titanium, Sport, Touring, Stage II (SOLD) (May '05 - Sept '06)
LBC111 is offline   Reply With Quote
Old 09-02-2007, 03:26 PM   #27 (permalink)
The bottom line is that there is NO reason to be bellow 4k rpm in this car if you are above 30 mph.
There is NO reason to be AT 4k or ABOVE if you are driving according to what I mentioned in the previous thread. Here's what I said...
My Quote: If you drive 65-70 mph on level ground without needing to accelerate, you can drive in 6th gear 3400-3600 rpm all day without hurting a thing (Elise/Exige). If you come up to a slight upgrade, passing, accelerating, then you can drop it down as many gears as you need to...*without over-revs.
Any good engine builder will tell you the same. My experience tells me the same. Whatever turns you on...drive 5 or 6k all day...the engine won't look any better on the journals or walls at tear down.
I don't mind opinions, but you seem to state it as FACT, implying that a person will harm their engine if they don't keep the revs at 4k. If you believe that is fact then you are wrong.
Drivers will not harm their engine according to my quote. Forget me...call Dan Gurney's shop and ask his Toyota engine builder.
Old 09-02-2007, 03:35 PM   #28 (permalink)
Elise Royalty
Patricko's Avatar
i did not say that 4k is a magic number. Driving these cars at less than that will not be fun or fast...
The OP was driving at 50mph in 6th gear wich is less than 2600 rpm.
Old 09-02-2007, 03:52 PM   #29 (permalink)
I totally agree with that!
Old 09-02-2007, 04:10 PM   #30 (permalink)
short angry bloke
codymac's Avatar
Images: 19
The bottom line is that there is no reason to be bellow 6200 rpm in this car unless you've had your cam switchover point changed.
Old 09-02-2007, 04:45 PM   #31 (permalink)
Elise Royalty
Patricko's Avatar
I will see your 6200 and raise you to 7000
Old 09-02-2007, 05:16 PM   #32 (permalink)
Crotch rocket addict
Boondock Saint's Avatar
Originally Posted by Hiroprotaganist View Post
The entire evening I had been taking it easy (I mean really easy, I was just happy listening to some good music) so I knew there was no normal reason for this.
Driving these cars at low RPM's is crazy to me since the fun starts at 4000 rpm or so but in all fairness it sounds like he was just trying to relax and enjoy some music based on his quote above. I do the same thing since, even when driving slow, this car is a blast to drive and I just like to sit in it. I don't let my rpm's go that low though. I just turn up the stereo to make up for the engine/exhaust music.
Youth is not entirely a time of life; it is a state of mind. Nobody grows old by merely living a number of years. People grow old by deserting their ideals. You are as young as your faith, as old as your doubt; as young as
your self-confidence, as old as your fear; as young as your hope, as old as your despair.
- Douglas MacArthur
Boondock Saint is offline   Reply With Quote
Old 09-02-2007, 05:49 PM   #33 (permalink)
glb
Unattractive Nuisance
glb's Avatar
Paricko -
WW
I agree. One can feel lugging. Certainly his driving had 0 to do w/problem. I can do a tick over 2000 rpm in a high gear w/steady state throttle (w/PES chip). It is not axiomatic that high revving engines can't be driven at low rpms safely. Were I British, I might say "rubbish".
05 elise (PES chip, SSRs, Sirius, shift tower reinforcement, Multivex; HID low beams)
05 Corolla XRS; 72 Elan Sprint, 170 hp (Sold)
"I can resist anything except temptation" O. Wilde.
"Political language is designed to make lies sound truthful and murder respectable." G. Orwell, 1946.
Old 09-02-2007, 07:34 PM   #34 (permalink)
This has gotten off track - to be VERY specific, I was driving on level ground behind no traffic and was not accelerating. I fail to see ANY causal connection between driving in 6th gear at relatively modest RPMs and a complete discharge of coolant. If there is a causal connection, then please share. My driving style is not the issue here - or should I go back and ask Skip Barber for a refund?
Had I wanted to accelerate, pass, drive "enthusiastically", or if the engine was under stress, I would have dropped the gearing down appropriately. The sweetspot of the powerband in my old S2000 was somewhere north of 5k - does that mean that under no-load/level-ground interstate cruising I should have just kept that engine on the hot cam in 4th instead of 6th? Clearly, the answer is no.
We all know where the fun begins on this engine - but that is not the issue at hand.
Edward J. Achtner
Current:
'07 Exige S: Chili Red/Performance/Touring/Starshield
'06 VW Jetta TDi
'04 VW Touareg
Retired:
'05 WRX STi
'01 S2000
'91 900 SPG
'89 900 SPG
Hiroprotaganist is offline   Reply With Quote
Old 09-02-2007, 07:55 PM   #35 (permalink)
Nightfall Blue
lotus54's Avatar
It sounded like it to me:
>>---Originally Posted by Patricko
I agree it it way more fun faster, but I don't think it would damage it. That was what was said originally (or at least that is what I heard- not necessarily the same thing at all!)
As long as you are not lugging it - then I don't think it matters on the rpm.
I will cruise along at well below 4k all the time when just putting along.
Mark
Old 09-02-2007, 09:42 PM   #36 (permalink)
You will have been at a bit less than 2600 RPM (50mph in 6th gear) and that will have been hard on the engine...
Regarding the attached chart, are you sure the ratios it uses are correct? According to the Elise manual page 159 the first line (1000RPM) should be 5.1, 7.7, 10.7, 13.6, 17.3, and 19.4 MPH, with ratios 3.17, 2.05, 1.48, 1.17, 0.92, and 0.81.
dododge is offline   Reply With Quote
Old 09-03-2007, 02:37 AM   #37 (permalink)
LWK
Lightbulb
I had identical situation to my 07' S (blk radiator) too, after pulled aside I found the coolant bottle seems empty, I poured half bottle of water in and it runs fine again. Took it in to the dealer last week, they found out the radiator has minor leak due to this problem.
LWK is offline   Reply With Quote
Old 09-03-2007, 03:18 AM   #38 (permalink)
Guys, this is getting a bit off topic, sounds like a coolant leak more than a driving style issue. Don't forget there are coolant pipes that run beneath the car from the back to the front, maybe sprung a leak somewhere beneath. Maybe he also coincidentally has a transmission problem as well. Who knows
vyuen is offline   Reply With Quote
Old 09-03-2007, 05:52 AM   #39 (permalink)
Elise Royalty
Patricko's Avatar
No I am not sure, I found it on EliseTalk so it must be correct
Old 09-03-2007, 08:30 AM   #40 (permalink)
Elise Royalty
Patricko's Avatar
... I fail to see ANY causal connection between driving in 6th gear at relatively modest RPMs and a complete discharge of coolant. If there is a causal connection, then please share. My driving style is not the issue here - or should I go back and ask Skip Barber for a refund?
Yes you should SB did not teach me to drive like that at Laguna Seca when I did the 3 day race school in January
HTML code is On
