El Jefe - Agent 111
Using the Exige forum
Hi, based on requests, and because I think it makes sense.... I created an Exige forum.
The idea is that Exige specific discussions and questions should be posted here. If the question or discussion is related to an Elise or an Exige... such as questions about the engine, radio, how many monkeys can fit in the trunk, etc... please put those discussions in the proper forums. If the discussion is specifically about the Exige, or items only found on the Exige, then this is the right place.
* V E R I T A S * A E Q U I T A S * We have been feeling the buzz since 2002 2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds. ..is a stranger in an open car. Tempt you in and drive you far away |
prepare your time!
ummm how many monkeys can fit in the "boot" lol
thanks good call for the exige guys out there!
2005 KG Lotus Elise Touring package and SS no hartop... WTB YOUR KG HARDTOP PM ME 2002 Supercharged Nissan SE model Xterra -SEXterra greetings from NOT Iraq haha |
#7 (permalink) |
72 Daytona- 69 Mclaren
I own a 06 with 3500 miles. My problem begins when the transmission gets warm during trach days. The shift from second into third becomes stiff and than increasenly difficult.. A double clutch up shift seems to solve the problem. Has any one experienced the same or similar problems.
#9 (permalink) |
Keep it simple and real
hblotus, have you had the shifter cables adjusted?
Around 3,000 miles, shifting my '06 Exige started becoming reminiscent of my Porsche 914/6's gearbox (where the driver had to be clairvoyant to successfully make certain gear shifts). Qais, at So. Bay Lotus, adjusted the cables, and everything has been (mostly) fine. My car now has 8,500 miles. At times downshifting into third (only when at the track) can be tricky. I think it might be due to engine movement upsetting the shift cables / linkage. I am considering installing ForcedFed's engine damper (www.forcedfed.com/elise/dampers) to see if it makes a difference. Other ET'ers report more crisp shifting after the installation.
#10 (permalink) | |
Petit Le Mans
regards, Fred (FredVa1). |
| Display Modes | |
