Old 05-01-2009, 11:34 AM   #1 (permalink)
intofx's Avatar
Images: 14
Above diffuser exhaust with BWR SC?
Still hunting down the source of my 7000 rpm stumble. It all started when my twin tip Larini took a dump and I replaced it with the 6" based on Sector's recommendation. I'm planning on borrowing a stock exhaust to isolate the problem but am curious which above diffuser exhausts are working well with the BWR supercharger. If it matters, I have Charlie's tune.
TIA,
Matt
2006 Phantom Black Exige
2004 Porsche C4S
2007 Black Hummer H2 SUT
intofx is offline   Reply With Quote
Old 05-01-2009, 11:36 AM   #2 (permalink)
Live to Drive
Bavarian Motorist's Avatar
My Larini SE is fine with me BWR.. I don't think your problem's the exhaust...
Old 05-01-2009, 12:31 PM   #3 (permalink)
intofx's Avatar
Images: 14
My Larini SE was fine with mine until it "went bad." Once I replaced the SE tipped Larini with the 6" I began having issues. When I swapped the exhaust, Sector 111 suggested I NOT go with another SE twin tip Larini as they had been having issues with supercharged cars and heat. It is the only part of the equation that changed and I have chased after AC relays, electrical issues, etc... So, I'm going to find a stock exhaust and put that on to see if it is the culprit. Assuming it is, I need to know what other exhausts are playing nice with after market superchargers. When I started having issues, I contacted Charlie and he was not surprised that I was having issues with the Larini.
Matt
2004 Porsche C4S
Old 05-01-2009, 01:05 PM   #4 (permalink)
Live to Drive
Do you have a rear panel delete?
Old 05-01-2009, 01:34 PM   #5 (permalink)
I <3 chicken, I <3 liver
shay2nak's Avatar
Yeah, he has panel delete. I would say get 2bular, but BWR doesn't carry them now. You have to order from Jim directly.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
Old 05-01-2009, 06:00 PM   #6 (permalink)
intofx's Avatar
Images: 14
Is that what you are running?
Also, you don't happen to have a stock exhaust I could borrow for a few hours do you?
Matt
2004 Porsche C4S
Old 05-01-2009, 09:16 PM   #7 (permalink)
shay2nak's Avatar
Hey Matt,
you have a PM
Ara
Old 05-08-2009, 10:42 AM   #8 (permalink)
Liberté!
Darth G-F's Avatar
2bular!
Great exhausts! Jim is a nice guy to deal with.
2006 Ronin Supercharged Lotus Elise
2008 BMW 328Xi
Darth G-F is offline   Reply With Quote
Old 05-08-2009, 02:36 PM   #9 (permalink)
Yahoo! Got my Rotus!
dma550's Avatar
Accoring to Fred @ BWR, if you have the larini with pipes @ 2" you're ok, but the design is a little circuitous. I am holding out for a 2t 8" GT3 or his dual above diffuser that is in development.
David Avery
05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE
08 BMW 135i Stock
visit Spyderclub.com
dma550 is online now   Reply With Quote
Old 05-08-2009, 05:53 PM   #10 (permalink)
dma550's Avatar
Interesting info re: the 2tubular I mentioned:
Does it exist? Dual-tip (through-the-grill) exhaust for Exige S?
David Avery
08 BMW 135i Stock
Old 05-08-2009, 08:51 PM   #11 (permalink)
Form and Function
plastique999's Avatar
I have BWR with Charlie tune as well.
I also have 2bular decat and 2bular 8" GT3 exhaust.
Along with cup air box....I last dyno'd at 227 to the wheels.
...and I track my car a lot!
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
Old 05-13-2009, 11:19 PM   #12 (permalink)
intofx's Avatar
Images: 14
Well, you were correct. I found my problem so I'm reporting back to all of the threads I participated in during my search for the issue as it may be helpful to someone else down the road. It turned out to be a bad/damaged spark plug. Hopefully it was just a defect and not a larger issue. Needless to say, I will be keeping an eye on the plugs. Here's the thread with pics:
What's going on with this spark plug?
2004 Porsche C4S
