#41 (permalink) |
the stock Lotus sc elie and exige S , do we know what kind of header they are using ? I am not much cncenred about gaining a few ponnies with a header but i am concerned about temperatures that a S/C kit will create such a kit to my engine. so if stock elise/exigespercharged models are using the same exhaust system(header,cat, exhaust) then i am fine with my setup. if anyone knows about that please let us know.
p.s. If i was leaving in the US i would meet charlieX for sure and would tune my car with headers etc. but since tune via e-mail is never a goo option...please let us know if anyone knows anything about the point i am asking..thank you P.s2 besides what do you need the headers when the new kit with intercooler is available ? get ur extra ponnies from there !!! ![]()
I have the simplest tastes... I am only satisfied with the best !!! "Simplify & Add Lightness" J.P |
#42 (permalink) |
I <3 chicken, I <3 liver
the elise SC and exige S should have identical exhaust system
#43 (permalink) |
OSX Black hat
stock 240 vs with header/sport cat, the smooth one is the stock car.
Sinclaries in london had tested this cat before and reported the data back to magnaflow, with test pipe, cat and sport cat.
#44 (permalink) |
OSX Black hat
funS11, AFR's are a little lean the elise/exige race cars run at around 13.5 but they have a supply of engines !
![]() if thats a sniffer its probably ok, if its off a bung precat then its off. its hard to make out but if the cat isn't doing what it ought to, it'll introduce a wobble in the run as the pressure builds/releases.
#45 (permalink) |
what did Sinclaire find out about the difference between sport cat & test pipe. I actually talked to Andy this morning, I would have asked him if I had seen your post earlier. I was under the impression from Jim, that the difference between his sport cat & test pipe are a couple HP. I'm talking to Sinclaire to have Jim hook me up with his interchangeable sport cat/test pipe piece instead of the sport cat.
#46 (permalink) |
OSX Black hat
About 15HP and a smooth dyno vs a wobbly one, which pretty much sums up that last dyno sheet on the S240.
#48 (permalink) |
DENNAB
Sorry to sidetrack but I have a question Charlie. Does tripoints dynapack run higher or lower numbers compared to L.A.P.D's dynojet? I think blake's car posted some monster numbers with his header on a dynapack. Was he using a sports cat or test pipe? I believe you've used both dynos extensively. Thanks
#49 (permalink) |
oh the red curve is the stock car? The wobblie curve is the new header & sport cat WITHOUT tuning??
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 EXIGE S ** MY CAR ** VIDEOS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com Last edited by shay2nak : 10-10-2008 at 02:34 PM. |
#50 (permalink) | |
OSX Black hat
I forget which hardware he has, if he was running the same sport cat, you'd see the wobble factor, it'd look even worse on a dynapack. The smooth one is the factory car, the wobbly is the one before tuning , the only change is the header and sport cat (that i'm aware off), i changed it to wider throttle opening but did not tune it for the header, since it just wasn't running the numbers it ought too.
#51 (permalink) |
IIRC, he has 2B header & sport cat. Can you post the before & after Blake's dyno if you have it?
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 EXIGE S ** MY CAR ** VIDEOS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com Last edited by shay2nak : 10-10-2008 at 03:09 PM. |
#52 (permalink) |
OSX Black hat
here you go. green/red before, blue/blue after, if you look as well that peak torque 144 is barely there
#53 (permalink) |
right seat driver
CX, so you're saying I'm wobbly.
Only after lots of Fat Tire, I'm gettin started right now. Car is running good, dropping a few codes, but I think I know why it didn't measure up. Hope to see you next week while I'm out in Vegas for LCS, can we work on it some more Mon 10/20? If not I'll catch you next time in LA. Our race in Primm on the 25,26 weekend got canceled so I won't be out all week. I am also coming out for SEMA maybe then as well. I'm anxious to see what it will do with good juice. |
#54 (permalink) |
Brent, what's the setup on your car? (the dyno above)
#55 (permalink) |
OSX Black hat
sure thing brent, shame about the race, they are/were having some sort of race to state line in atv's next week.
#57 (permalink) |
is the "before" stock, or is it with all the mods before CX? Tuning included Gotham upgrade also?
#59 (permalink) |
did your tuning include 100% throttle opening? LOL sorry I'm asking all these questions.
#60 (permalink) |
Track Junkie In-Training
Resurrecting an old thread....
I'm curious, have there been any updates relative to header + sport cat (or de-cat) tunes for SC cars since this post last went up? I know many guys are running EFI's but what about new reflashes with Lotus ECU? Ran my car on a mustang dyno the other day & the car is running high 13 AFR's on average (with a brief spike above 14) using a sniffer. I have a BWR SC with everything else essentially stock. The car runs great on the street but am concerned about a lean situation on the track (as I know a couple of guys who've blown engines). I'm going to have a custom dyno tune within the month & am considering the PPE setup (Header + Sport Cat). Any success stories tuning this combo with the BWR SC & keeping AFR's at or below 13?
2005 HRM Elise Mods: BWR SC Kit, Nitrons, NGK BKR7EIX-11s, Stage II, SS lines, Pagids, Forged Wheel Studs, Oil Catch Can, HIDs, Aux D Lights, W Strps (Red Outline), AL Shift Kit, BLK Suede Brk Cvr, Pwdr Coat BLK Diff/Whls/GC, MB CC/AC, Red Brk Calprs/Engine Cvr, LTS Rear Badge, CG-Locks, Alpine 9886 HU, JL VR 5.25" x 4. "You're Never Too Young To Plan For Your Mid-Life Crisis." |
