Old 06-24-2009, 06:36 AM   #61 (permalink)
08 Exige S 240
CUP_240's Avatar
sounds great mate, well done ...
have you had a chance to spend more time on the tuning ? 300rwhp shouldnt be far away ;-)
Is your PPE header a 3" merge or std ?
CUP_240 is offline   Reply With Quote
Old 07-22-2009, 10:12 AM   #62 (permalink)
E.D.'s Avatar
I have a std PPE header with the bigger runners, not 3" though.
Last Tue i finally went to my car again, sitting in the parking lot of the company who arranges the whole import procedure, to fix the rough idle (didn't had the time in US to do that). Two surprises:
1. Front clam damaged during transport, so bye bye deductible assuming that insurance company will not try to deny the claim.
2. Elise doesn't start, although it did start when they drove the car out of the harbour to the garage. Tried to jumpstart the car by connecting to another (big) battery, didn't work. The battery appears OK, so something else is wrong. Car will now go to a nearby local Lotus garage.
In addition i can't get my new laptop to connect to the EFI using a USB--> RS232 cable, even after reading Phil's instructions how to do it, so that was fun also. Maybe the cable is f-ed up because i tried it with 2 laptops w/o succes. So now i'm hoping to resurrect my old laptop which died, because that old laptop did connect to the EFI w/o problems in the US.
Enrico
'06 Laser Blue/Magnolia Lotus Elise * BOE TVS SC * EFI * Lots of other things
'07 Graphite Grey/Tan BMW 335i w/JB3 tune, Helix IC and BMS DCI
E.D. is offline   Reply With Quote
Old 07-22-2009, 10:19 AM   #63 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Front clam damage? Mind sharing the company name?
Old 07-22-2009, 10:28 AM   #64 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Front clam damage too? Grrr, that's stinks
Don't sweat the car not starting. Given the world record speed install, it doesn't surprise me that it might need a little help. First check your fuses. Seems like the coil fuse will pop from time to time if you're jump starting or cranking for a long time.
You may need a different serial->usb converter. I'm by no means a computer guru, but I have found that those converters are not all created equal. Once you get her hooked up, upload that new firmware first and then the map I sent out and she should tick right over unless something just "ain't right". You should be able to identify if anything isn't right buy looking at your data controls on the lap top. Call me or Kris if you need anything. You know we're always happy to help
Best,
Phil
Old 07-22-2009, 11:21 AM   #65 (permalink)
E.D.'s Avatar
i believe it's TRD shipping or something like that. probably some idiot drove the car off the ship too fast, hitting the road and there you go...
on the positive side, my old laptop appears to work again, so I'll copy the new map from Phil and the firmware update to my old laptop which works OK w/EFI.
Enrico
Old 07-22-2009, 11:33 AM   #66 (permalink)
E.D.'s Avatar
Best,
Phil
thanks for the offer, if the 7h time gap permits it and we're lost for a solution, i'll give you a call.
thanks again ENrico
Enrico
