Old 10-02-2009, 07:15 AM   #1 (permalink)
Anyone know what this plug is??
Hi guys,
I am posting this here as I have a BWR SC and having issues and just found this plug hanging loose??
The plug has 3 wires and is shaped differently to most other plugs I have seen on the engine. From what I can see it has an Orange central wire and a black and grey wire on either side - See pics attached. This is located in a small harness near the breather pipe and belt side of the engine, just underneath the oil solenoid.
I am hoping and praying it connects to somewhere useful and that it might fix the issue I have been having.
Anyone know what it is and where it goes?
Many Thanks
Steve
steve-elise is offline   Reply With Quote
Old 10-02-2009, 07:24 AM   #2 (permalink)
really light stuff
Thomasio's Avatar
That's about where the passenger's side VVT valve is, but I don't remember what the plug looks like.
07 SY Exige S
Old 10-02-2009, 07:26 AM   #3 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Could be Knock sensor next to where the coolant tube goes into the block, possibly for your charcoal canister! Hmmm, is it in the same harness that your injectors and solenoid are in?
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 10-02-2009, 07:34 AM   #4 (permalink)
Thomasio if you mean the VVT Solenoid that is just above it. If you look in my first picture it is the gold cylindrical item closest to the camera and you can see at the top of the picture the connector is fine and there.
This loose plug I found further down the engine and yes, passenger side in the USA.
Cheers
Steve
Old 10-02-2009, 07:36 AM   #5 (permalink)
really light stuff
Thomasio's Avatar
Originally Posted by steve-elise View Post
Thomasio if you mean the VVT Solenoid that is just above it - the gold cylindrical item closest to the camera and that is fine and connected. I found this plug further down the engine and yes, passenger side in the USA.
Cheers
Steve
Drats! I wanted to win.
07 SY Exige S
Old 10-02-2009, 07:42 AM   #6 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
If it is in the same harness as your injectors I am betting on the knock sensor - if you have your belly pan off take a light and look up above the Mocal sandwich oil adapter and look next to the coolant lines and see if it is plugged in!
Old 10-02-2009, 07:44 AM   #7 (permalink)
really light stuff
Thomasio's Avatar
My money is on ZTEC for the win on this one!
07 SY Exige S
Old 10-02-2009, 07:47 AM   #8 (permalink)
Hi ZTEC, I do have the Belly Pan off. I tried looking from underneath but couldn't seem to see through to that location as I believe the alternator is in the way.
I'm a real novice when it comes to mechanics, can you describe what the Mocal sandwich oil adapter looks like?
Does the knock sensor have a 3-way plug like the one shown?
Many Thanks
Steve
Old 10-02-2009, 07:54 AM   #9 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Sorry the "Mocal" adapter is where your oil lines connect directly above the oil filter... Above that on the Block itself (It is up high) you have a Knock sensor to the left of where your "coolant loop" goes in and out of the block! I am just guessing but through process of elimination you will and need to figure out what isn't connected! It's tight in there but use a good flashlight and if you have a dental mirror start looking for the connectors home! I would start there.
Old 10-02-2009, 07:58 AM   #10 (permalink)
Thanks ZTEC - Okay - will go and have another look again now.
If anyone else happens to have a BWR kit and know what this plug is or perhaps what the other end of the knock sensor looks like that would be great.
From what I've seen most of the other sensor/plugs around the engine seem to only have 2 wires whereas this one has 3 so must be something different
Cheers
Steve
Old 10-02-2009, 08:05 AM   #11 (permalink)
really light stuff
Thomasio's Avatar
That looks like an OEM connector as opposed to something that the kit would have come with, but I'm speculating.
07 SY Exige S
Old 10-02-2009, 08:08 AM   #12 (permalink)
Crazy Car Guy
Looks like the TPS wire.
www.VisionFunction.com - Site Under Construnction - Stay Tuned
Jermaine@VF is offline   Reply With Quote
Old 10-02-2009, 08:13 AM   #13 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
That is the exact reason I was asking if it was on the same harness as the Injectors! - Would the car even run without the TPS?
Old 10-02-2009, 08:16 AM   #14 (permalink)
Crazy Car Guy
Yes... !
Old 10-02-2009, 08:39 AM   #15 (permalink)
Hi guys, looked again and yes it is part of the same harness that the injectors are fed from.
Jermaine, where is the actual TPS (Is this Throttle Position Sensor?) - Is it anywhere near where I found this plug ie near the dipstick and just underneath the VVT solenoid?
My car is NOT a DBW - it is a cable throttle so is this perhaps why it is sitting disconnected? or am I way off the mark?
Cheers
Steve
Old 10-02-2009, 08:47 AM   #16 (permalink)
Cheers
Steve
typically on the throttle body.
2005 Magnetic Blue Elise - "the Lotus" (original I know)
2001 Jeep Wrangler - "soul crusher".
If you dont GET it after you drive it, then you dont GET it - serpent
mrcarcrazy is offline   Reply With Quote
Old 10-02-2009, 08:58 AM   #17 (permalink)
I'm just posting a couple more pictures to give the position of the plug some better context. ZTEC I think I can just see the knock sensor wires you were talking about - see the closeup picture and from a quick google, I think the knock sensor is a 2-wire plug - but may be wrong.
I found the plug dangling further down but for the life of me can't see anywhere it goes.
If the TPS is truly on the throttle body then this plug is miles away from it.
Cheers
Steve
Old 10-02-2009, 09:34 AM   #18 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
TPS is 3 wires and is on the other side of the engine.. So not TPS... Knock sensor is two wires, but different colors and plug... So not Knock...
Obviously not VVT as stated before...
Not either charcoal canister sollenoids as they're both red plugs and different style...
Keep 'em coming guys
Edit- FWIW- As I recall the AC wire is a multiple pin plug that has only one wire going to it and the other wire grounds on the compressor. It does have a sub assembly though, but it doesn't strike me as the AC plug... The crank signal is blue and yellow wires as I recall and is twisted pair and insulated...I don't remember which one it is off the top of my head, but those are a few that are worth ruling out
Double edit: Doh I see that it has 3 wires in your first post.. I was just looking at pics and didn't see the black... In either case the TPS has different colored wires, so still not TPS and the knock sensor only has two wires, so still not it...
Old 10-02-2009, 10:53 AM   #19 (permalink)
is it possible it is from the inertial cutt off switch?
looks like the same connector from my mod Emergency Unlock Switch – Easy Mod Pictorial
or it could be from the oil pressure sensor. Just the first things that popped into my head.
Old 10-02-2009, 11:11 AM   #20 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
I know the alternator has a 3 pin against the firewall but I am trying to remember what else is on the injector harness!
