Old 11-26-2007, 11:19 AM   #201 (permalink)
disproving HD MTBF daily
charliex's Avatar
Originally Posted by PhoneBoy View Post
How about just providing the correct brand injectors that don't need to be spliced.
Correct meaning ones that don't need to be spliced, or correct meaning injectors that have been tested over and over and over again with this application ?
Again hardly anyone has asked for it, if they had, the kit would have been modified appropriately.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it.
charliex is online now   Reply With Quote
Old 11-26-2007, 12:45 PM   #202 (permalink)
PhoneBoy's Avatar
Correct as in both.
In other words, injectors with the correct connector to fit the OEM wiring.
OMHO it doesn't make sense to start cutting and soldering, like MacGyver turned mechanic, when there are better ways of doing this. This seems like an oversight for what sounds like a great kit.
I would expect that a company like sector 111 would update the kit.
'06 Lotus Elise - Solar Yellow, Touring, Hard Top, Star Shield, microMIRROR, Bootie, and ChaseCam
'07 Yamaha WR250F
'05 Dodge Grand Caravan CV
'04 Toyota Sienna
'02 Ford Explorer
'98 Mariah Shabah 180
PhoneBoy is online now   Reply With Quote
Old 11-26-2007, 12:49 PM   #203 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Maybe I missed it in this thread, but what boost is this kit running at? My mechanic wants to know...
Thanks
Driving a Lotus Exige with sticky... performance tires on icy roads or in standing water is about as much fun as walking a high wire treated with WD-40 - Car & Driver
BWR supercharged... I suppose I "got the power" now??
Bavarian Motorist is online now   Reply With Quote
Old 11-26-2007, 12:52 PM   #204 (permalink)
06 SY Exige
LordZ's Avatar
While I don't like cutting wiring when it's not needed, I would much rather have a well known injector that requires a splice over a cheap ebay special with the right connector. Not all injectors are created equal...
LordZ is offline   Reply With Quote
Old 11-26-2007, 12:53 PM   #205 (permalink)
El Jefe - Agent 111
Randy Chase's Avatar
Images: 761
Are you asking about the BWR kit? Or are we all still talking about another kit?
If so, it runs the same as the stock Exige S.
We have been feeling the buzz since 2002
2006 Noble M400. Getrag tranny, Quaiffe LSD, Hinged clams. Duratec dual turbo V6. Hoosier 315-18 tires. 2350 pounds. 0-60mph in 2.9 seconds.
..is a stranger in an open car. Tempt you in and drive you far away
Old 11-26-2007, 02:07 PM   #206 (permalink)
PhoneBoy's Avatar
Agree - Quality injectors with the correct OEM connector.
'07 Yamaha WR250F
'04 Toyota Sienna
'02 Ford Explorer
Old 11-26-2007, 02:15 PM   #207 (permalink)
charliex's Avatar
Correct as in both.
You can't have both, since there are no other injectors that have had the same amount of testing in this application, we'd have to change them, then install them on as many kits again and see if its got the same results. Given the number of people that have required them, that'd be a lot of work for not much in return.
They're also not off ebay, nor are the harnesses, they're OEM connectors.
It makes perfect sense to me, the existing injectors work and have been tested a lot, its two wires per injector and you can cut off the old ones, with enough wire to cut off the new ones later, and rewire new the stock ones (if you decided to return the car to stock )with no issues at all.
If you don't want to do that, use a conversion harness or a kit that doesn't change the connector, or even choose to change the injector type yourself, either way the problem is solved.
Old 11-26-2007, 02:24 PM   #208 (permalink)
Live to Drive
Thanks...didn't realize how off-topic we were
Old 11-26-2007, 02:40 PM   #209 (permalink)
06 SY Exige
LordZ's Avatar
Just so we are clear I didn't say any part of the kit was from ebay. Just mentioned that since I'd rather a known good injector (RC Engineering has always been a fairly decent one) over some of the upgrades that are online, I think Venom was one we had tons of problems with in the TTZ side of things.
We did start using Nismo (Nippon Denso) and SARD though for the higher power cars. SARD always required a splice, Nismo was plug and play but then again it's a Nissan company. RC Engineering were pretty good, but we always sent them off to be balanced and flow tested just in case, especially if used.
Old 11-26-2007, 02:42 PM   #210 (permalink)
charliex's Avatar
I realise LordZ, i just wanted to make it clear to everyone else too
SARD is something i've been looking at recently.
Old 11-26-2007, 02:47 PM   #211 (permalink)
PhoneBoy's Avatar
That was (sort of) my point. Why not select an injector that fits the OEM connector (and has the desired specs, of course) first, then do your testing. just my 2 cents.
'07 Yamaha WR250F
'04 Toyota Sienna
'02 Ford Explorer
Old 11-26-2007, 02:56 PM   #212 (permalink)
charliex's Avatar
Well unfortunately i don't have a time machine to go back and do the last two or so years again, the current injectors were choosen for valid reasons, the different connectors were weighed as part of the choice, and so far in those two years, no serious issues with that choice.
I'm not sure why you think scratching the current injectors and restarting trials with customers superchargers would weigh well against a theoretically possible problem in cutting 8 wires, even if it is twice so that you can return it to stock.
Sure if it were a problem that needed to be fixed, then it'd be done, but so far you've been the only person i know of thats been adamant about it, and i see the other solutions i gave you as viable alternatives for you, so at the end of the day i see no issue, certainly not one that'd require a restart of research and development.
RC also sells conversion harnesses,, but if i recall correctly i don't know if they had the exact combo, they said they did, but others disagree.
Old 11-26-2007, 03:01 PM   #213 (permalink)
06 SY Exige
LordZ's Avatar
Feed type, flow pattern, lots of variables in an injector other than connector types.
We had great results with the SARD 800cc's. Of course they came with nice bling billet fuel rails too which is why alot of the guys went with them. But the Nismo were rock solid too. Just the largest they had were 740's... Personally I never needed anything above a 555, 4 digit HP numbers just weren't my thing.
Anyone know what the BWR kit is coming with injector wise? The RC from the Greddy kit or something else?
Old 11-26-2007, 04:51 PM   #214 (permalink)
PhoneBoy's Avatar
Well unfortunately i don't have a time machine to go back and do the last two or so years again, the current injectors were choosen for valid reasons, the different connectors were weighed as part of the choice, and so far in those two years, no serious issues with that choice..
Perhaps if we could find a Delorean ...
Sorry - not saying that at all. In an ealier post you mentioned just swapping the injectors with comparable ones but with the OEM connctor. Sounded easy (to me at least )
'07 Yamaha WR250F
'04 Toyota Sienna
'02 Ford Explorer
Old 11-26-2007, 05:40 PM   #215 (permalink)
Are the stock "S" injectors Bosch, Seimans, Delphi, Lucas, etc.?
Ol'Racer is offline   Reply With Quote
Old 11-26-2007, 05:48 PM   #216 (permalink)
charliex's Avatar
with equivalent not comparable ones, just just have to find them and match all the parameters lordz listed.
my friend has a delorean with a lotus engine, its a start.
Old 11-26-2007, 05:52 PM   #217 (permalink)
Anyone who has completed a SC install would probably tell you that it's not worth there time, effort, and skin on their knuckles to return the car back to stock.
Splicing 8 wires and soldering is a piece of cake. splicing them back is as easy. All you need is some shrink wrap, soldering iron and some solder. That was the easiest part of the install.
Old 11-27-2007, 08:43 AM   #218 (permalink)
Anyone know?
Old 11-27-2007, 09:27 AM   #219 (permalink)
High Roller
JUNGLISTluder's Avatar
Images: 6
If I bought this kit without knowing the injectors were not Plug and Play, I would be seriously mad.
Cutting the fuel injector harness is completely unacceptable to me, and may even prevent me from purchasing this kit!
I don't care how easy it is to splice/cut/solder/etc....for a $5500 kit, I would at least expect adapters or PnP injectors....
06 Lotus Elise - AR/Blk, Touring, Premium, TC, HT, DRL Delete, X-Pel, TS Pro1 Exhaust, TS Pro1 Intake, BBmod, Saikou Michi OCC, 6000k HIDs, Stealth Bulbs, 07+ Letters, Re-grooved Bilsteins, LG Stone Guards, CR Engine Covers, S111 Folding Tow Hook, FF CF Spoiler, 17" PIAA FR-7s, CharlieX 06 ECU V2.0, Greddy/BOE Supercharger
88 BMW 528is - Blue/Llama Beige, M20 stroker motor, Alpina SW, 3.73 LSD, BavAuto Springs, Bilstein Sports, M3 SSK, 16x8 BBS, 225/245 tires, shadowline
JUNGLISTluder is offline   Reply With Quote
Old 11-27-2007, 01:12 PM   #220 (permalink)
06 SY Exige
LordZ's Avatar
They can probably offer the adapters extra. But that just doubled the number of connectors that could get corroded, bent blades, or just not have full contacts on them. While this car is still new in the US, I have had numberous problems with older cars (6-12 years) and their connectors. On Z's it was a normal occurance to have to cut an injector or coilpack harness wire to solder on a new one. In fact I kept spare ones in the glove box with a cordless soldering iron. Had to use them a few times on friends vehicles too.
Heat and age can tear these things up easily, espeically if they are laying ontop of the manifold which has to be done for all these kits. While the adapters will probably just fine, I would be concerned over time with multiplying your points of failure. Just ask anyone who has installed an AFC and went with vampire clamps over cut,splice,solder...
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
HTML code is On
S
