Old 08-18-2009, 06:10 AM   #1 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Dual Chargers ?
What do you get when you take a VF supercharger and Franks/Ronin's Beast of a Turbocharger Lotus?
I think we are about to find out!
Holy ****
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's!
ZTEC is offline   Reply With Quote
Old 08-18-2009, 06:17 AM   #2 (permalink)
Third Eye Open
ZTEC's Avatar
Images: 3
Roll the clock back to the mid 80's and Franks knowledge of Rally cars and you might find his inspiration :
One of the last of the World Rally Championship Group B monsters, the Lancia Delta S4 was an instant classic since its debut in 1985, where it won the first race it was entered in, the RAC Rally of Great Britain. With over 550 horsepower available via a supercharger to reduce throttle lag and a turbocharger for top end performance, acceleration to 60mph in came in less than 2.5 seconds on gravel, the Delta S4 was destined to be a dominant force in the rally championship. Delta S4 features included carbon fiber bodywork, lightweight tube frame chassis, all wheel drive, and a mid-mounted engine for optimal weight distribution. In 1986, Henri Toivonen took victory at the prestigious Monte Carlo Rally, and suffered a fatal crash in the 1986 Tour de Corse while leading the event. The sad news signaled the end of the Group B era, with the cars being deemed by the WRC governing body as too fast and too powerful for the conditions.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/LR3qknARFyU&color1=0xb1b1b1&color2=0xcfcfcf&featur e=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/LR3qknARFyU&color1=0xb1b1b1&color2=0xcfcfcf&featur e=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></embed></object>
Old 08-18-2009, 06:20 AM   #3 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
You get a whole lot of stuff that can go wrong.
But it can be done and has been done many times...
Edit: He's not going to be running it threw the wussy MP62 is he? If so it'll be slower and make less power than the turbo by itself due to restriction and massive amount of heat in the charge air that will be produced... Not to mention the power loss to the little supercharger trying to compress already compressed air. It'll take a large intercoolers with a huge cores to try and pull away that much heat... Should be an interesting build just to see the results if it can be done without all the childish innuendos and name calling.
Dragon is online now   Reply With Quote
Old 08-18-2009, 07:58 AM   #4 (permalink)
usurbrain's Avatar
I don't know Frank, but I'm sure from seeing stuff he does, he knows what he's doing....
2008 Exige S240
Storm Titanium, Touring Package, Starshield, Cup Car wheels with R888, Arqray Twin muffler, Cup Car airbox, Nitron Double Adjustable suspension, Saikou Michi catch cans, Bride seat, HID headlights, Lots of track parts...
usurbrain is offline   Reply With Quote
Old 08-18-2009, 08:56 AM   #5 (permalink)
Drunk on alcohol
25psi_Elise_Killer's Avatar
Had 1 shop try to do it here in SoCal on an Evo, but it ended up being a real PITA to deal with
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com
25psi_Elise_Killer is offline   Reply With Quote
Old 08-18-2009, 09:06 AM   #6 (permalink)
2/3 hp to the paws.
Simba's Avatar
It can be done, but it's really only suited for really bizarre applications, like the requirement of using a massive turbo on a tiny engine and needing as much off-idle torque as you can get. E.g., rally cars.
These days with the restrictor requirements, there's no point in twin charging, as there's no point in using a huge turbo to begin with. That's why current rally cars run lots of boost at low revs (thanks to anti-lag) and galactic craploads of timing with much less boost in the high revs once the turbo becomes considerably less useful thanks to the restrictor.
On an Elise, the packaging and heat management for such a system would be an absolute nightmare. Much better and easier to just use a VTG turbo.
Old 08-18-2009, 09:47 AM   #7 (permalink)
Testing your next engine!
QuadCamSix's Avatar
Yup AND it will be cheaper and MUCH easier to tune. The actuator controllers have become far better than just a few years ago and there are all sorts of gadgets on the market for running these things now. Im surprised nobody is running one in an Elise yet.
The Lotus Elise is not a very practical car, but it could probably be considered the most practical motorcycle ever made!
QuadCamSix is offline   Reply With Quote
Old 08-18-2009, 09:54 AM   #8 (permalink)
Drunk on alcohol
If Frank needs a little more power earlier, maybe he should look into a twin-scroll design. Below is a boost plot on a single scroll GT35R versus a twin scroll GT35R
Twin scroll with dual wastegate manifold:
Old 08-18-2009, 10:03 AM   #9 (permalink)
NOT ßANNED!
Demonized's Avatar
It's Frank, pretty sure no-one is changing his mind.
Will be cool to see how it works out.
Old 08-18-2009, 02:30 PM   #10 (permalink)
Parts scattered about...
MaineLotus's Avatar
I think it's a cool experiment and knowing Frank, it'll turn out and run perfectly. Lots of low end torque and high end turbo power.
My car is modified.
MaineLotus is offline   Reply With Quote
Old 08-18-2009, 04:59 PM   #11 (permalink)
MaineLotus's Avatar
Packaging is simple because the VF, BWR and Katana both position the throttlebody in the stock position. Heat management isn't a nightmare but does require some thinking.
My car is modified.
Old 08-18-2009, 05:06 PM   #12 (permalink)
MaineLotus's Avatar
Yes
My car is modified.
Old 08-18-2009, 05:22 PM   #13 (permalink)
Live to Drive
Bavarian Motorist's Avatar
Seems like over-kill?
Old 08-18-2009, 05:51 PM   #14 (permalink)
GoFast+Turn Left OR Right
JRzCarz's Avatar
I saw this done with a Mini Cooper S (before the turbo model) on a show car in Orlando - he said it worked well - small turbo ahead of the stock supercharger.
PS: ZTEC - Nice of you to let that car into your lane with the yellow winged beast yesterday under the East-West underpass.... such a gent!!
06 Ardent Red, Touring, FF exhaust, light fly/hd clutch, snorkel delete, green filter, Porterfield R4S, FOB range improved, BWR key, micromirror, visor delete, HIDs, TR Motorsport F1/R888s, Schroth 6pt/sys.6.pk/V force bar/R3 Rage, shift mod, 6lb Braille, extinguisher
JRzCarz is offline   Reply With Quote
Old 08-19-2009, 04:15 AM   #15 (permalink)
MaineLotus's Avatar
Exactly, well said!
My car is modified.
Old 08-19-2009, 05:30 AM   #16 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
Originally Posted by MaineLotus View Post
Yes
It'll be interesting to see how it will handle the volume of air from the turbo. It'll also be interesting to see how the super charger psychically holds up to the amount of stress and heat it will be enduring. I'm assuming he will go with a larger exhaust housing on the turbo now as it will spool faster with the supercharger on it. I'm pretty sure it will definitely pick up some bottom end, but I think It will sacrifice power at the top end. Overall cooling the air charge is gong to be a PITA.
Keep us updated on the progress...
Old 08-19-2009, 06:37 AM   #17 (permalink)
MaineLotus's Avatar
Cooling charged air is easy since the VF will redirect straight into the existing single intercooler, no PITA.
Different turbo housing, yes. Additional stress? - remember the air entering the supercharger is already compressed by the turbo.
My car is modified.
Old 08-19-2009, 07:03 AM   #18 (permalink)
Hydrocarbons Rule
Dragon's Avatar
Images: 2
I don't think that intercooler by itself will be able to cut it, but it will help.
Additional stress will come from much hotter air in to the supercharger and much much much hotter exiting and the fact that it will be compressing a much higher volume of air. In theory the super charger will run a lot hotter and have more resistance on internal parts and bearings. You have to remember your trying to pump 400-500 hp worth of air threw it on the top end. That is what he was doing with the turbo set up isn't it?
If he want's more low end I think a Sequential Twin Turbo set up with one small turbo and then a slightly larger one would be the best bet for actual function. Plumbing it all however would be interesting to say the least...
Edit: Just fount the post over there.. I see he will be using a large intercooler so that should take care of heat going in to the engine.... It still should be fun to see how the little MP62 will handle it. But then us guy's over here on LT like me that have built in the neighborhood of 100 engines and transmission and tuned with multiple EMS's, built 20 or so 400-700hp cars don't know what we are talking about.
Old 08-19-2009, 11:04 PM   #19 (permalink)
Bender Rodríguez's Avatar
I do know from a stress point of view supercharges and turbochargers are "supposed" to be designed to handle quite a bit more pressure than there operational range to deal with the high spikes. For example when the throttle closes and the BOV just starts to open for a very small amount of time the pressure against the compressor blades is much higher than it would typically operate at. In comparison the change relative to pre-compressing air is quite small, I can't say its not significant or that it wouldn't be the straw that break the camels back but i would be very surprised.
Personally I’m more a fan of the dual turbos as well but there is really no reason this concept won't work. The only problem I can foresee would be managing heat and if Franks going to run the same amount of boost I think it will be passed the surge limit of an MP62.
Bender Rodríguez is offline   Reply With Quote
Old 08-20-2009, 05:03 AM   #20 (permalink)
Denuo Volatilis
...m...'s Avatar
...that's my thinking, too - dramatically simpler and lighter...
