#21 (permalink) |
Lotus Sales
Lotus parts needed.
*intake manifold *supercharger inlet(swan neck) *supercharger outlet *front motor mount *blower nose support(alt bracket) *rear blower support bracket The stock oil dipstick tube can be modified. An adapter plate for the crankcase ventilation has to be fabricated. If the vehicle is already equipped with a Greddy/Tripoint/Katana....a new blower nose piece should be purchased as the Exige nose is about 3/8" longer. The liquid to air unit we are using is about $700 and the design seems to fit quite well allowing the A/c to be kept in the vehicle. An aftermarket oil cooler will be needed as we utilize the stock front mounted oil coolers as heat exchangers for the intercooler. We opted to use a Mocal Laminova oil to water oil cooler as it quite small and easy to find a place to put it. A coolant resovoir and 1(or 2) pumps need to be added to the intercooler system. This was just a quick overview....A lot of little things such as oil lines, coolant lines, wiring and other misc things need to be made as well. Hope this is helpful.
00 Acura Integra...05 F250 Powerstroke diesel INTERNET FORUM BOARDS"A place where everyone seems to be an engineer" |
#22 (permalink) |
Impressive list
2006 Tripoint SC with 10psi pulley and Aquamist, custom 2.5" free flowexhaust, FF headers, Decat, Ohlin's, track brace, custom carbon bits 1994 Caterham 7, R400 zetec conversion in progress |
#23 (permalink) |
Lotus Sales
A116W6727F Clip, double, fuel pipe retaining, fir tree fix.
A120E6115S Stud, M8, manifold to head, upper left A120E6167S Gasket, vent tube to cam cover A120E6170S Hose, No.3, crankcase ventilation A120E6171S Gasket, mounting to block A120E6177S Clip, breather hose, retaining A128E0003F Inlet Manifold, 'swan neck', supercharger A128E0005F Outlet Manifold Port, upper A128E0008F Drive Belt, ancilliaries + supercharger, with AC A128E0009F Outlet Manifold Port, lower A128E0012F Inlet Manifold A128E0013F Breather Vent Tube A128E0014F Guide Tube, dipstick A128E0015F Breather Mounting Spigot A128E0016K Bracket, alloy, insulator to engine, modified A128E0017F Mounting Bracket, nose A128E0021F Mounting Stay, supercharger support A128E6000F 'O' Ring, inlet manifold sealing A128E6001F 'O' Ring, outlet port lower sealing A128E6002F 'O' Ring, outlet port upper sealing A128W2217F Bolt, M8 x 55 x 1.25, flg. hex. hd., inlet/stay fixing A128W2218F Bolt, M10 x 50, flg. hex. hd., bracket mounting A128W8056F Stud, M8 x 25, lower centre fixing C120A0055F Bracket, engine to chassis, RH CLS3L0008F Bracket, clip support
#24 (permalink) |
MMA Fighter
Location: Where the drugs are cheap and the girls are easy
So like 1200 for parts and 800 for the i/c? Then i'd have to get a tune but am i missing something? Looks very good Casey!
05 NFB Elise / Katana SC / No Snorkle / 3.2 "10" psi pulley / Stage 1 Exhaust / Decat / Green Filter |
#25 (permalink) | |
You only need what Casey previously posted. Also it will be more than $800 probably closer to a $1000+. Casey ended up using the front right engine mount and that sucker is Expensive. The good news is you do not need to order the dipstick that sucker is like $270.. OUCH
2005 Elise 250 whp | Forcedfed Custom Intercooled Supercharger | EFI | Forcedfed Street Header | Fujita CAI | TB Bypass | Toda flywheel | ACT HD Clutch | Forcedfed Prototype Exhaust | Micromirror | Forcedfed Half Carbon Splitter | Greddy Catch Can | ForcedFed Engine Damper |
#26 (permalink) | |
Lotus Sales
You also need a pump 100-250....a coolant tank 100-400...intercooler pipes need to be fabbed...i/c mount fab....oil breather fab...oil lines fabbed...water lines fabbed..couplers 40-70...exige s blower nose piece ?250-300...pulley(exige s offset)..belt...wiring(relay...) quite a few an fittings....I guess all the lettle parts could add up.
#27 (permalink) |
nice work!
Great to see more IC solutions coming to market...
Elise'06ST:RAC-Girodisc-Larini 8"-Zoom-Braille-Reverie intake-raceview-Saikou Michi-FFengine damper-Nitron sportpro-RTVbrace-extended undertray
#28 (permalink) |
just for giggles
#30 (permalink) |
XPRMTL
Casey(Forcedfed) is da man!
![]() The evil genius at work!
05 Elise Spyder II, Chrome Orange, 1586lbs. Stasis/Alcon "lotus cut" brakes, Supercharged and Intercooled @305 Crank HP "My dream car is now operational!"
#31 (permalink) |
XPRMTL
A couple more of his secret weapons. This guy does great work!
![]() Still need to go HD on the upper I/C hoses though.. Casey, call me...
#32 (permalink) |
XPRMTL
Here is an image showing some of the ExigeS parts on the list..
Sorry for the thread heist but I love what Casey/ForcedFed did with my car. Couldn't be happier
#33 (permalink) | |
Casey, FYI ugduck designed and built the "Low Water and Switch Map Bank Circuit".
#35 (permalink) |
The vendor sent us the wrong core so it was sent back.
#36 (permalink) |
XPRMTL
If you were aiming that at me?.. The car seems to run at the same temps as before..Same temp variations. I don't have an oil temp gauge. Always seems to have power never feels as if there are heat soak issues. I wanted an pre and post I/C temp gauge but Casey was really busy at the time. I neewd to get the car back to him but he is VERY popular..
#38 (permalink) |
XPRMTL
Seems to be no noticeable change in regard to H20 temps. I do live in a pretty temperate region(Berkeley/Fog/low summer temps 70's to low 80's).
#39 (permalink) |
XPRMTL
It IS a Mocal Laminova coolant to oil cooler. Coolant comes from front mount radiator to intercooler then to Mocal on to the surge tank the circulation pump then back to the front mount radiator.
#40 (permalink) | |
gas, gas, gas, gas
Jay-05' ST, HT, Touring Red I have a theory that all.... ![]() Katana flags 9 VF flag 1 |
