Old 10-04-2009, 07:02 PM   #201 (permalink)
Eyelise's Avatar
I still haven't figured out how/where to mount the MAP sensor. I bought a longer vacuum hose to free up some room, just haven't come up with a solution.
Eyelise is offline   Reply With Quote
Old 10-04-2009, 07:08 PM   #202 (permalink)
Hoon
Amarao's Avatar
What is the purpose of this air-adder pipe? Besides adding air...
Amarao is offline   Reply With Quote
Old 10-04-2009, 07:09 PM   #203 (permalink)
Eyelise's Avatar
What should I do with the hose coming from the gas tank if I choose not to reinstall the charcoal canister apparatus? Do you think it would be a problem to reconnect it to the TB to elimnate any gas fumes from being released into the engine bay? Would it create a vacuum?
Old 10-05-2009, 02:38 AM   #204 (permalink)
luxige
luxige's Avatar
Apparently, to clamp in a bench vise while porting the manifold...
luxige is offline   Reply With Quote
Old 10-05-2009, 07:15 AM   #205 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Map Sensor
Here's one of my favorite spots... Also did you get my email over the weekend regarding mounting the EFI in the cabin if you're interested... I added some pointers that may be helpful within the install instructions... Specifically section VIII (along with other bits and pieces throughout the whole manual). They're up on the website now, FWIW...
Take care,
Phil
Old 10-06-2009, 03:57 PM   #206 (permalink)
Eyelise's Avatar
I was thinking the same thing for mounting the MAP
Old 10-06-2009, 04:08 PM   #207 (permalink)
Eyelise's Avatar
I was just putting together my CAI. I had the TurboXS CAI and figured I would just reuse most it. I was measuring the ID and OD of the tubes and noticed there is an internal lip in the MAF tube that reduces the ID to 2.5". I was thinking of replacing it to eliminate the restriction from the MAF itself but using a full 3" tube should improve flow even more. I found everything I needed on intaketubing.com
Old 10-06-2009, 04:27 PM   #208 (permalink)
Eyelise's Avatar
Now I have to start buttoning things up. I also decided to install the BOE clam hinge. I'm just guessing I'll be in and out of the engine bay lots in the future.
05 Saffron LSS Elise (#151): BOE TVS SC, BOE fuel surge tank, EFI standalone, 3" CAI, Saiko Miaki OCC, Innovative motor mounts, ACT/XT/HD clutch, Fidanza FW, Sector 111 track brace & steering arms, Ported OEM manifold, Larini SE, LETSA, Nyon SW bar bushings, SS brake lines, Pagid Blacks, Deka GTX12
Old 10-06-2009, 08:28 PM   #209 (permalink)
luxige
luxige's Avatar
Home stretch, man!
Old 10-10-2009, 06:40 AM   #210 (permalink)
Eyelise's Avatar
I mounted the MAF and will be working on putting the interior together today. I haven't decided what to do about the charcoal canister. If I don't re-install it what should I do with the line from the tank? I can't find the thread on the motorcycle canister, anyone have a link?
Old 10-10-2009, 07:50 AM   #211 (permalink)
Eyelise's Avatar
I need some edification. Who can tell me what the components do?
Old 10-15-2009, 03:36 PM   #212 (permalink)
Eyelise's Avatar
No takers on the emmisions stuff huh?
Old 10-15-2009, 03:37 PM   #213 (permalink)
Eyelise's Avatar
My intake pipes came in today. Everyhting fit nicely.
Old 10-15-2009, 03:46 PM   #214 (permalink)
Eyelise's Avatar
Here is the replacement battery I ordered. Phil, any suggestions on relocating the battery? I know the directions haven't been updated yet. I 'll be putting time in on the clam hinge modification this weekend.
Old 10-21-2009, 07:30 PM   #215 (permalink)
Eyelise's Avatar
I started re-routing the battery cable across the firewall to the new battery location. It just about reaches, might be just a little short.
Old 10-21-2009, 08:23 PM   #216 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 6
Sorry for crummy cam phone pics, but the camera is in the house, so I made do
Here you can see where the battery goes and the basic setup for deleting the charcoal canister.
RE the canister, you essentially cut the final solenoid from the canister and cut the quick connect line from the hard line coming from the tank and marry the two together as shown in the pic...
Hope this helps!
Best,
Phil
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
ViX
