#21 (permalink) | |
looking forward to your future upgrades |
#23 (permalink) |
Coolant system bypasses
Can anyone provide specifics on the adapters needed for the throttlebody bypass and the U hose elimination? The bypasses are mentioned in the directions and sound like a good idea.
#24 (permalink) |
Plug Whisperer
Sure, just disconnect the TB coolant lines and route one of the coolant lines back onto the head... You're essentially just taking the the TB out of the loop... On the U-bend, just cut the coolant hose that makes up that u bend and use it. It's already a formed hose that will work perfect for the task. It's much easier to understand once the intake id off the car, etc...
Lookin good ![]() Phil
#25 (permalink) | |
Thanks phil,
I guess you mean like this for U-tube: Quote:
#27 (permalink) | |
If Lotus did this from the factory, they would double their sales.
05 GG Elise: Exige clam, LSS, Stage 2, ACT HD, DBA5000, CF scoops/splitter/mirrors/panels Others: Lex ES300Coach, Volvo V70R 300hp/260k Missed:01&04 Wranglers, 71 CJ5(225V6) Need a Johnson County or Kansas City personal injury/wrongful death attorney/lawyer/law firm?http://www.kcatty.com Looking for a Johnson County, KS DUI lawyer/attorney? http://www.JohnsonCountyDUI.com Need a Johnson County, KS lawyer/attorney to help amend or fix a speeding/traffic ticket? http://www.JoCoTraffic.com |
#28 (permalink) | |
Have you dyno'ed your tvs yet?
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
#29 (permalink) | |
Thanks.
"I think a Ferrari is a scaled down version of..... God" |
#30 (permalink) |
Mods are good for you
This is a comparison v. my Katana (3.2 pulley) Note this TVS tune was one of the very first 'out of the box' maps and still produced 275+ whp, and I had throttle cut off lower at 8100 for safety. This was the 5th run in less than 25 minutes and the best too - the TVS is amazingly resistant to heat soak. Got my tune dialed in now and guessing it's near 290hp/190tq when I get back to the dyno.
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#31 (permalink) | |
"Are you in a band??"
#32 (permalink) |
2007 Exige S
I'm jealous!!
![]() Congrats! TVS is definitely the smart and cost effective choice to get to what I feel is the max the chassis/drivetrain can withstand in stock form. Without an IC you'll get even better throttle response and less weight. To make my M62 deliver the same HP consistantly, I would need to add air/water charge cooler, water pumps, monitor pressure, etc. etc. -- a lot of weight for the same results as a TVS with no IC. TVS is a simple elegant solution, but so are most of Phil's solutions - top notch. Rob
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#33 (permalink) | |
How would these figures be different on a dynojet? Estimates?
#34 (permalink) |
Plug Whisperer
Oh no
- Not the dyno wars again Would be better on a different/new thread... Even on the TVS thread, but not this install thread...Need to get back on topic-- quick!!! ![]() Edit: Sleepe, No offense intended. This thread is just going wonkey... ![]()
#35 (permalink) |
2007 Exige S
That Katana tune looks a little wacky there Dave. Nice and sorted on the TVS though.
Rob
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 05-05-2009 at 02:21 PM. |
#37 (permalink) |
Yup,
If we continue off subject nobody will be able to see my install posts. Not trying to be a downer, just want the thread to be useful for guys like me that need lots of help with the mechanical stuff. Maybe I could clean things up a bit later on if that doesn't offend anyone. |
#38 (permalink) |
Phil, for the BWR kit conversion the alternator stays in the same spot or do you recommend to put it back and relocate the charcoal canister? what are your thoughts on this? hope this isn't too off topic.
EB Turbo
Guldstrand Motorsports Technician. Burbank, CA. PM for custom work and service quotes. |
#39 (permalink) |
Plug Whisperer
Good Question...
For BWR kits, you move alternator back original location, as the alternator ties into the nose support for the blower. We provide the same simple bracket that we use on the Katana kit for charcoal canister relocation... Nothing too fancy, but functions plenty well and doesn't weigh a thing. Although with the EFI, I doubt anyone will run the canister I'm starting to question whether to include the canister bracket at all...Cheers, Phil
#40 (permalink) | |
Phil,
Would the charcoal canister be needed when we have to go for an inspection. I'll have to reconnect the OEM ECU once a year and swap out the fuel injectors but what about the charcoal canister? Quote:
| Display Modes | |
