#121 (permalink) |
Ok I started with the fuel system upgrade. I must say it took more than one trip to the parts store to get the OEM fuel lines off. The difficult one is the one nearest to the fuel rail. It takes a particular quick connect release tool. I had to buy two before I found one that worked. There are four spring prongs inside the connection that need to be compressed. Unfortunately the ribs in the end to the fuel line block insertion of the tool. I finally bought a plastic one and was able to force it in.
#124 (permalink) |
I mounted the Tank and took a look at the fuel lines. Maybe I was tired but I couldn't sort the connections. It should be simple but I got lost in the instructions. A diagram would really help here. I'm a visual guy. The surge tank has 4 connections, the regulator has 4, and we have the plastic hardline from the gas tank and the line to the fuel rail line. I know the side connection on the tank goes to the plastic hardline from the main gas tank. I believe the tank connection furthest left is the overflow line. I need help with the rest LOL. Phil a 1,2,3 match the numbers would be nice.
#125 (permalink) | |
Hydrocarbons Rule
It's in the instructions at this link on the BOE Fabrication web site.. ![]()
#126 (permalink) |
2007 Exige S
Pic of the fuel release "tool" is in Phil's docs online, the plastic ones work great (cheap and simple).
Hint of the filler cap/neck -- good idea to mark it's position so that when you tighten it back up and put the clam back on it'll fit. -- if you removed it or losened it. Another suggestion -- since you have version 1 of the fuel surge tank (like me, or was I version Beta) you might want to use some thick duty heat shrink wrap on the Power terminals covering wire and nuts. Rob
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#127 (permalink) | |
Meow!!
![]() p.s. Don't want to threadjack but from no bars and 5 miles to station pump full "click" off was 13.32 gallons last night with the ProAlloy tank (54 litre capacity).
#128 (permalink) | |
Damn too late. No idea how it will align.
#129 (permalink) | |
OK, this pic definitely did not print out in my instructions or I have an old set. Time to check the website for updates.
#131 (permalink) |
Plug Whisperer
The top is for adjusting the FP. Simply turn the hex bolt with the pump running until you see about 52-53psi (in your case) and then hold the hex and lock it in with a wrench. the open boost reference port on the side of the reg remains open and not connected to anything...
Get the latest instructions for the surge tank and TVS... small changes to help make things simpler... I hope ![]() Out of town for the next week. Good luck! Phil
#134 (permalink) |
2007 Exige S
What Jim said, he's da pro when it comes to wiring.
#137 (permalink) |
I ran the wires for the NGK AFR. I haven't tapped the power yet. Soldering the lambda wire to the analog out is straight forward but I wasn't sure about the power. I guess I'll cut the switched wire and solder all three together. Finding a ground shouldn't be tough. I mounted the controller as mentioned and found it on the floor of the car the next morning. The velcro didn't hold. I'll find a better mounting method. What is the deal with the calibration?
#140 (permalink) |
Hydrocarbons Rule
And if you don't mind ruining them you can use a vice grips...
| Display Modes | |
