#144 (permalink) |
I ran into a little trouble mounting the TB to the swan neck. I need a little input from Phil.
First, one of the 4 bolts coming from the SC/swan neck adapter is spinning when I try to tighten the nut holding the swan neck in place. The others were fine. It is not loose just not tight. The other issue has to do with mounting the TB. One of the OEM bolts appears too long. The studs are fine but one of the OEM bolts will not tighten down all the way. Phil, I did not see any new hardware. I'm sure the studs are in the right place. They are too short for any other location. |
#145 (permalink) |
2007 Exige S
I believe Phil is on vacation in deepest parts of Colorado, think he'll be back next week.
If you can post a pic of what your issue(s) is, I might be able to provide some guideance. I'm not a TVS guy but might be able to give you some suggestions. Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs Last edited by robains : 08-06-2009 at 08:26 AM. |
#146 (permalink) |
Plug Whisperer
I'm back from the mountain peaks of CO and getting caught up on emails and PMs the best I can. Jeff, give me a ring of you're still having a question about some steps. You know I'm happy to help
![]() Best, Phil
#148 (permalink) |
I have most of the ECU wired. It was a learning process. The first harness took me forever. I labeled every wire after tracing back to the OEM ECU harness. I also managed to solder 3 splices before sliding on the heat shrink. I guess I learn slow. The ECU reconnect harness went real quick. It took me only a fourth of the time. I still have to do the splice connect and chasis connect. I couldn't find the chasis connect in my hardware. Anyone have a pic of it? Phil?
#150 (permalink) |
Kris provided a neat little T splice crimp on the splice connect. It was filled with solder so all you had to do was heat the crimp and insert the last wire. I was able to get heat shrink over it as well. I thought it was a nice neat splice. I don't see why these can't be used for the over three T splices. Kris any thoughts?
#152 (permalink) |
I finished 95% of the wiring. Now I know how to solder. The only surprise was one of the wire colors in my OEM ECU harness did not correspond to diagram from Kris. It was #20 "throttle position sensor" I traced it several times to the harness and even checked the plug going to the TB. Mine was green yellow and not orange black. After discussing it with Phil I went ahead and spliced in the green yellow wire. The only thing I can fathom is that mine was an early 05 model #0151 and it might have changed shortly there after. Phil was working on an early 05 #1750 that had the right colorsbut mine was significantly older.
#153 (permalink) | |
-Robert p.s. Eyelise, I'll buy your fuel line if you don't need it....and if its reusable.
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
#154 (permalink) |
2007 Exige S
Orange/Black is water temp sensor wire so going with green/yellow was probably correct. Not sure what to say about the bolt -- I would have done a trip to the hardware store to get the correct length rather than cut it, but I'm sure it'll be fine.
Yes you can re-use stock fuel line, that's why it has disconnects. Cheers, Rob.
'07 Exige S (Track Pack & LSD) + EFi 550ci injectors + Mahle 9:1 + DRS Port + SuperTech Valves + Weapon R Header + 2.9" pully + TODA Clutch + FF Engine Damper + RLS IC + Greddy catch cans + opened roof slot + RTD brace + Milled steering arms + Larini 8" + FF air intake + Moroso oil pan + Ultradisc 2 piece front/rear + Reverie 1650mm wing + ReVerie front splitter + IQ3 Dash + 4pt ASM + Pioneer AVIC-N2 nav + rear camera + RAC monolites 888s 195/225 + Lotus LSS Hoosier R6 205/225 @ 1921 lbs |
#155 (permalink) |
Phil,
I received the chasis connect and got it wired in. All the wiring is done now. I'm going to pull the coil and VVT wiring out on the loom as you suggested to clean things up a bit. Do you keep the plastic wiring harness mount that attaches to the valve cover? Any tips? |
#156 (permalink) |
I re-installed the alternator and rerouted the crank position wire as mentioned. I did notice the alternator now sits on top of a wire connection for the compressor and not the hard lines. The connector is mounted to the top of the compressor with a bracket and screw. Do I need to relocate it to make room for the SC? I remember you said it was tight. I'll post a pic later.
#157 (permalink) | ||
Plug Whisperer
![]() ![]() All those facotry sensor connections have a lot of extra slack, so take the time to position them where they won't get crushed. Pretty common sense type stuff as I'm sure you know Best, Phil
#160 (permalink) |
2007 Exige S
For EFI to monitor boost (manifold pressure) -- it's important.
| Display Modes | |
