A/F Gauge install - LotusTalk - The Lotus Cars Community
post #1 of 12 (permalink) Old 12-12-2012, 02:18 PM Thread Starter
A/F Gauge install
Not sure this belong in the proper forum topic but anyway.
In the attached image, you can see the AEM A/F gauge which I connected to the sensor somewhere on the exhaust.
There are a bunch of wires with some doc as to what wire connects to but I honestly have no clue as of where I'm suppose to bind them wires... I'm clearly lame when it comes to electrical/electronics stuff, hence the question.
Would anyone have some pointers? Am I going to have to take the dashboard out and cut some wires here and there, crimp things around? seems a little out of my league...
Thanks!
GronkDaSlayer is offline
post #2 of 12 (permalink) Old 12-12-2012, 04:18 PM
evansp60's Avatar
Remove your driver seat, the center console and the rear panel behind the seats and you'll find the access route to the rear of the car. Run the wires thru the center console up the back and into the rear engine bay by way of the hole in the firewall. It's easy to see as there are already wires running thru it. Put it back together and the wires are all hidden. Nothing too complicated. Use search function and you'll find some pictures to help you.
evansp60 is offline
post #3 of 12 (permalink) Old 12-12-2012, 05:41 PM
Vulcan Grey's Avatar
Vulcan Grey is offline
post #4 of 12 (permalink) Old 12-12-2012, 08:37 PM
RichardNHCooper's Avatar
I have run wires this way in my car and it is a time consuming PITA. I ran ome wires under the sill on the left side. I lifted off the sill and the vertical panel in front of it. I then pushed a small draw wire from the small opening at the rear with a wire coat hanger this allowed me to pull cables under the sill and to the dash. They run from the engine bay over the side and down and forwards to where the black plastic side vent locks in at the front. I have enlarged the hole there to fit in more wires. I actually have left a SS draw wire under the sill permanently as I am always adding things. So now it is a 10 min job to run new stuff from the engine bay.
2009 Elise S,Rev 400 ,BOE black series short block, Ferrea Valves , MWR springs,PPE headers and decat,SSC Harness bar, PenskeDA,Shaved V2 steering arms ,FF engine damper. Saikou Michi catch cans, NGK wideband. Modded Toyota E153 gearbox ,60l Proalloy fuel tank , Aeromotive 320 fuel pump,Exedy clutch LSD , SSC ECU, CompositeWorx SP1 seats ,Larini muffler, Aussie-clamhinge.
RichardNHCooper is offline
post #5 of 12 (permalink) Old 12-13-2012, 09:47 AM Thread Starter
Thanks!
I'll see what I can do. I already have access to the harness since the rear clam is off and everything so that's not a problem. Now I have to figure out how to splice them wires and make sure I use the correct ones. I'll do some search and see what I can find.
post #6 of 12 (permalink) Old 12-13-2012, 09:56 AM
antinym's Avatar
Richard seems to have a good idea. I ran wires through the center console, behind the interior bulk head and through the main harness grommet behind the drivers seat. If you do go that route, put some soap on your wires, it'll make it much easier to pull.
As for splicing, there's two small fuseboxes under the dash. Test them for constant hot and switched hot.
Use a fuse tap(like this one:
Amazon Amazon
) then you won't have to splice into the car's harness. Easier, and safer if you're not a wiring guy.
Hmm...
antinym is offline
post #7 of 12 (permalink) Old 12-18-2012, 02:41 PM Thread Starter
Originally Posted by antinym View Post
Use a fuse tap(like this one: Littelfuse FHA200BP ATO Add-A-Circuit Kit : Amazon.com : Automotive) then you won't have to splice into the car's harness. Easier, and safer if you're not a wiring guy.
Which is totally my case
post #8 of 12 (permalink) Old 12-25-2012, 08:06 PM
Westrock's Avatar
You can also go STRAIGHT back through the center console following the emergency brake and shifter cables. They are within sheaths, so they will not rub on anything. I have several wire harnesses going through this area. No problems in 5 years.
Heres some various pictures I have posted before, just to give you some ideas.
Gauge on center console
Gauge on dash
Constant and Switched sources under the dash, requires removing the dash though which requires some work plus you have to replace the 4 snaps on the airbag cover since they are designed to "break".
Enjoy!
Westrock is offline
post #9 of 12 (permalink) Old 12-26-2012, 09:47 AM
antinym's Avatar
Oh sure, do it the easy way!
Hmm...
antinym is offline
post #10 of 12 (permalink) Old 12-26-2012, 01:06 PM Thread Starter
Thanks for the pictures, that should help. I'm still waiting for a couple of things and then I'll be able to do this. I also have to connect the +/- analog signal wires. This should also be interesting since I'll have to pull out 2 wires from the aux harness connector.
post #11 of 12 (permalink) Old 03-26-2013, 09:28 PM
You happen to be in the Bay Area? I can lend a hand.
Nessal is offline
post #12 of 12 (permalink) Old 03-27-2013, 11:32 AM Thread Starter
Thanks!
I ended up having FFTEC install both gauges (I bought a boost gauge during the tuning process) while doing the tuning of the car. I had to have the A/F gauge on for the tuning.
  LotusTalk - The Lotus Cars Community > Lotus Discussions > Powertrain (Engine, Transmission, etc) > Forced Induction
Human Verification
