Gauges for super charger?
Hey guys,
I tried searching and couldnt find anything. Are there any addtional gauges I should be running with a super charger? I know the boost is constant depending on the pulley size (if there is not belt slipping). So I dont think a boost guage is need but what about oil temp/preasure or a/f guage? Thanks.
"I think a Ferrari is a scaled down version of..... God" |
NOT ßANNED!
Boost pressure gauge would be nice if you wanna make sure your belt isn't slipping, Oil temp and pressure should be standard in all cars imo, and A/F gauge when you're adding boost is a good idea.
Hmm well If i went the the gauge pod that goes infront of the shifter console by (i think forced fed) that would supply me with two, dont know where I would put any others haha.
Drunk on alcohol
Boost gauge is handy to diagnose boost leak problems as well...
'06 Evo IX Stage 1E Tuned by Road Race Engineering(Stock:turbo,intake,internals,ECU) Walbro 255lph fuel pump,RC Engineering1000cc Injectors, AVO exhaust,RRE dyno tune flash, Dejon Tool boost controller (325whp @ 22PSI Costco 91 octane, 353whp @ 25psi on 100 octane, 383whp @30psi on E85) , Zeitronix wideband,Zeitronix Ethanol Content Analyzer, Defi BF gauges, Stoptech rotors, SS brakelines,Graphic/Interior Design,Brand Identities,Invitations www.nomadic-nomads.com |
Do any manufacturers make gauges that display multiple parameters in a single gauge? (like oil temp/oil pressure/boost in one)
-Just got the VF2 installed...awesome!
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
Drunk on alcohol
#7 (permalink) |
Three gauge panel
I posted a thread about a month ago about a carbon fiber 3 gauge panel that I have fabricated and was looking for about 6-8 positve responses for a group buy. My avatar is a photo of the panel installed in my 2005 SA Yellow. I have a boost, oil temp., and oil pressure gauges in it. I have had only one reply to date.
#8 (permalink) | |
NOT ßANNED!
#9 (permalink) | |
#10 (permalink) |
Form and Function
For sure....oil pressure.
www.FaceNBody.com 2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C! Spec Racer Ford #237 |
#11 (permalink) |
boost, oil temp, water temp
this Defi gauge setup fits in the din slot for the radio allowing a cleaner look. Defi - DIN-Gauge <info here ![]() ![]() ![]() ![]() |
#13 (permalink) |
Third Eye Open
I never understood why anyone would accept looking down to see the gauges and thought the offerings available were a poor compromise because of space limitations in our car, My solution was a Twenty dollar triple pod from ebay and a can of flat black to mount my DEFI boost and oil pressure and an AEM a/f in the middle - simple, cheap and viewable.
GO: Vision Function Stage II Intercooled Bliss with Charlie's ECU magic and Ronin's Tenacity! STOP: DBA 4000's, Porterfield R4! TURN: Nitron S/A's Toyo RA1's 225/245 on Rota's! |
#14 (permalink) |
I'm looking for a guage cluster to replace my OEM radio. I can count the number of times I have listened to the radio on one hand. I'll likely also put one in front of the shifter. I'd like boost, oil pressure/temp. The NGK wideband comes with a A/F. Water temp is in the OEM dash. I think that would do it.
#15 (permalink) | |
Can you pick and choose? I'd like oil pressure rather than water temp.
#16 (permalink) |
i installed mine in the two air vents in the center looks very cool and factory and a custom built lower pod with two boost and wideband afr in top oil pressure and fuel pressure on the lower pod
"IT IS WHAT IT IS" |
#17 (permalink) |
JabStrongFierce
I'm getting PLX gauges for my Subie, possibly the Elise if I don't get a dash later
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/WKevPRuBZcM&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WKevPRuBZcM&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object> <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Sk9wUUeQ6Qo&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Sk9wUUeQ6Qo&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
2006 Elise : JFG | Nitrons | 2bular 8" Single | Reverie diffuser and misc. carbon bits | Tripoint Engineering W/A Intercooler | Ronin supercharger | DRS EFI and tuning |
#18 (permalink) | |
Also, where do you have your data logger/box thing mounted, mines in the small holder above the cig liter, I'm not sure if I like it there
06 Exige CO BWRized 05 Civic "Special Edition" 05 Elise CO, Trim shop interior and other things...SOLD |
#19 (permalink) | |
I think I will be going with oil pres, oil temp, and wideband afr. Now I need to figure out what brand of gauges to use.
#20 (permalink) | |
Future 2ZZ-GZE member...
I'm s0o0o0o going on the Greddy Infometer Touch route...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/dT3aRjrN45E&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/dT3aRjrN45E&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object> But then again I'll be running the emanage ultimate and the v-manage...so it will all sync up together very nicely! haha This thing is just too cool though...resets codes...can act as any gauge you want...and can datalog fuel trims so I can keep my piggyback tune happy! This may be better for you reflash people than the standalone ECU crowd...
