Old 04-30-2007, 10:03 AM   #21 (permalink)
Harrybauls's Avatar
Originally Posted by Lotus F1
I notice the wastegate you mention says speicial low boost at 7psi. I just want to verify. This is 7psi base and not the limit right? I can boost 15-16psi if I adjust it to do so right?
Yup. Boost controller. Manual bleeder type, or electronic.
Harrybauls is offline   Reply With Quote
Old 08-21-2008, 12:17 PM   #22 (permalink)
kverges's Avatar
Wish I could change title to read 3 years later (almost). Still doing fine, but not driven a huge amount (probably only 9K with the turbo) due to other cars I also drive. After my Rota wheel disaster on track and replacing all the broken bits (frame survived and was straight when I checked alignment and corner weights) I decided to change the exhaust to go through a metal substrate cat and no muffler, straight back. I like the sound, and can now pass any emission test thrown at me with no noticeable loss of power. Car makes about 230 rwhp, not the power of some setups, but runs and runs and runs. With everything on board still under 2000 lbs without driver. Been averaging about 25 mpg city and highway and using boost a fair bit.
kverges is offline   Reply With Quote
Old 08-21-2008, 01:46 PM   #23 (permalink)
2zz parts scattered about
MaineLotus's Avatar
Possibly one of the only remaining Hass turbos, although sounds like not much Hass in your setup now.
MaineLotus is offline   Reply With Quote
Old 08-22-2008, 12:39 AM   #24 (permalink)
Future 2ZZ-GZE member...
GTsRasta's Avatar
And still on a dreaded greddy emanage ultimate tune.
I read through the piggyback black magic thread you made again, and I still don't see the exact problem with checking fuel trims every once in a while, and zero'ing them out. It has been working for you and jlitman thus far.
Originally Posted by scottyb View Post
Maybe you should put a disclaimer in your sig saying that you don't have a Lotus nor have tried any of the products you are constantly posting about.
03 Celica GT-S, 6 Speed Manual, Carbon Blue
Performance Mods: AEM Cold Air Intake, TWM Short Shifter
GTsRasta is offline   Reply With Quote
Old 08-24-2008, 10:22 AM   #25 (permalink)
kverges's Avatar
Maybe I should be more clear. I check the tune out of an abundance of caution but do not need to zero any fuel trims. The tune has been stable in closed loop mode. I really don't think the learn feature causes any fuel problem if you tune to be stoichiometric in closed loop and focus on open loop
HTML code is On
