Haxord but mine
How to remove top back bolt on VF SC flange?? (PIC)
I got it off. Had to remove the unit and use a vice grip to get it started.
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? Last edited by Westrock : 07-06-2009 at 11:00 PM. |
#2 (permalink) | |
NOT ßANNED!
![]() Won't fit? Vice grips, perhaps?
Haxord but mine
A standard allen wrench definently not. If I cut it down to like 1/4" on the short end it might fit. I just wanted to hear others experience before I "mod" another tool
-David 2006 Storm Ti Exige + VF Stage 2 Vision Function Supercharger Install Thread Stereo Harness Info | Exige with no wing?? |
User Restricted By ΑDMIΝ
Can you fit a hex bit in there? Then you might get an open end wrench on the bit...
Haxord but mine
Good call, I'll try that.
06 S280
I didn't use those stupid allen's at that bolt and a few others. Good ol bolts worked alot better although don't have as much bling factor.
![]() Cut down an allen wrench, that worked on a few of the intake manifold bolts I put in. |
#7 (permalink) |
Haxord but mine
Ya even a allen bit was too tall to go in there. I think I might have to cut down a 6mm allen so that just like 1/4" of the short end is left.
#8 (permalink) |
User, Registered
That sure looks like a place where a hex head bolt would be better. Then an open-end wrench would reach it easily.
#11 (permalink) | |
the allen bolts are a horrible idea.. use studs/nuts they work.. also use regular bolts on the outlets.. |
