Old 07-20-2008, 07:43 AM   #1 (permalink)
Kareem of WheaTT's Avatar
I searched, but cant find instructions on charcoal canister delete..
I'm totally stuck here....I can't figure out how to remount the charcoal canister after s/c install or delete it. I can't find any good instructions on either one. The sector 111 directions are vary vague and I can't get it to work.
Previously RacyTracy's 2005 Chrome Orange Lotus Elise. Sport Package, micro mirror, rear window tint, Von Hep exhaust, Sector111 Katana supercharger, Green Filter, De-snorkel.
Kareem of WheaTT is offline   Reply With Quote
Old 07-20-2008, 09:46 AM   #2 (permalink)
MPR
Canadian Lotus
MPR's Avatar
there is few post on this. with pictures as well. keep searching.
remove the 3 rivets on the original bracket to remove
bolt the charcoal bracket supplied at right fender well
mount the charcoal canister on the mount
plug in vent, purge lines and other hoses as before
to remove:
take out the charcoal cansiter and brackets
tie the remaining hoses
plug the connector or use a resistor
plug the evap tube on the intake
2006 MPR Lotus Elise Supercharged longtube header test pipe arquay ti single iridium k&n oil catch can act xtss competition front rear spoiler reverie diffuser eliminator ohlin coilover 9" wide works weels hoosier a6 harness bar RCI 5 pt 9 lb battery hawk pads g2x data acquisition lm-2 wideband sensor prosport gauges
996 Cup DC2R Miata 302 Ducati 57S eg b18c
MPR is offline   Reply With Quote
Old 07-21-2008, 12:35 AM   #3 (permalink)
Enthusiast
SpecRaceM5's Avatar
Removal of the charcoal canister is pointless. It does not rob the car of anything and helps it to run more efficiently. If you are driving a full blown race car (track car doesn't count) then you may benefit from the weight savings, and will not benefit from the canisters function. Otherwise, just leave it in place. As for the relocation, you need to mount the new bracket to the motor mount as shown. Once it is mounted, slide the canister in with the top pointed forwards. You will need to play with the angle of it in order for it to not interfere with anything. I hope this helps.
Cheers,
Brian
Brian Eyerman
Spyder1
SpecRaceM5 is offline   Reply With Quote
Old 07-21-2008, 06:12 AM   #4 (permalink)
Bender Rodríguez's Avatar
Here is a few pics/ instructions
Fuel Tank Mods
Bender Rodríguez is offline   Reply With Quote
Old 07-24-2008, 09:42 AM   #5 (permalink)
gas, gas, gas, gas
choi0706's Avatar
chop the large fitting line/ chop the vent line/ insert vent line to large fitting line with clamp/ plug in purge valve and vent.. works great..
Jay-05' ST, HT, Touring Red
I have a theory that all....
Katana flags 9
VF flag 1
choi0706 is offline   Reply With Quote
HTML code is On
