#21 (permalink) |
disproving HD MTBF daily
around the same, the fuel only really changes drastically when you're on boost, off boost they're not much different to NA cars, otherwise think teen prom nite.
the driveability is good too, spent a lot of time smoothing it out
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 |
#22 (permalink) |
New and Improved!
I have had the 2006 Katana on for around 8000 miles...
No problems at all, other than needing a smaller belt than came with the kit. I'm also waiting on an intercooler solution and ready to pull the trigger asap. Get a Katana and you'll wish you did it sooner.
2006 Lotus Elise - Chili Red - VF Supercharged and Intercooled - Black Badges - Red Inserts - Grey RAC Monolites - Toyo R888's - South Bend SS-TZ - Fidanza Flywheel - Forcedfed CF front spoiler - Craftsquare CF Mirrors - Reverie 3 Element CF Diffuser - 5" 2bular Ultra Oversized Tip - PPE 4-1 FI Header w/ Decat - VonHep Rear Panel Delete - Innovate XD-16 and LC-1 - Mr.C Radar Mount - Clutch Travel Mod - Shifter Bolt Mod - re-ENFORCER - Drv. Lights Mod - A/C Panel Mod - Odessey PC625 - CIPA Mirror |
#23 (permalink) |
My experience is around 27 mpg on highway with my girlfriend on passenger (mean driving very slow). In the same context with NA set-up, I reach one time 35 mpg.
On everyday purpose, with cups everywhere, since the car is more powerfull, I am close to 20 mpg, and with NA, it was more like 23 mpg, sound similar. But in term of drivability, the car is much better, don't need to rev the engine all the time. Since I like to calculate everything, I am calculating all the time my fuel consumption... OK, sound stupid...
____________________________________ Elise 2006, white, Katana Europa 1969, green, H22A, 194 whp, 1550# CONFIGTECH.ca / Solidworks |
#24 (permalink) |
Thank you for all the reply. I will be pulling the triger within the month or so and will deefinitely have Charlie tune on this kit. Because of Cahrlie tune, this is the reason I am picking this kit over BWR. Thank for all the hard work Charlie!!
By the way, I know how to do some basic maintainence, I dont know how hard is to do the installation of this kit myself. I dont recall seeing post step by step on how to install this kit. How is the instrcution on this kit? Regards |
#25 (permalink) |
Form and Function
Regarding those with the Katana, what other modifications e.g. headers, intake? best compliment the S/C?
www.FaceNBody.com 2005 Lotus Elise: Larini SE exhaust,HID's,turn signals delete,rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,Gut Aero wing,Gut front splitter,CF 5-element diffusor,Exige mesh, Ohlins DA,RAC monolites,Toyo R888's,Pagid RS Blues,CO painted calipers,SS lines,Reverie XC CF seat, Reverie CF steering wheel,V force harness bar,Schroth Profi II 6 pt harness,shifter re-Enforcer, BWR key to BWR S/C! 2007 E63 M6 (many mods...) |
#26 (permalink) |
926
Alternator Bracket
Has anyone else with a katana had a problem with the alternator bracket failing?
For the time being, the kit/install is under warrenty (installed last spring ... and yes, I like the power). But mine will have it's fourth (!) alternator bracket installed later this week. It was last replaced 2 weeks ago, and I wanted to make sure that it was truely fixed, so I pushed it hard at the track Saturday. It lasted less than 2 hours (spread over 4 sessions). I'm beginning to worry. I can't be the only one who likes to accelerate hard out of corners. It starts with a stumble on exit, ... as if the rev limiter is kicking in. Then, after a comuple more corners, the power drops off dramatically and the battery light comes on. When I park in the pits, I can smell rubber when I lift the engine cover, probably because of the belt slipping. I'm told that this is a unique problem, but something is not right. It's either a design flaw with the alternator bracket, or a problem with the install.... Your thoughts?
'06 Elise, SoY/Red, Touring, Sport, LSD/TC, Hardtop, Stage 2, 4tress/Schroth, Micro/Multivex, Alpine/Focals/JLsub, CF console & A/C surround, Ultradiscs/R4s/stl lines, Extinguisher, Tow Hooks, Blackwatch key, RTD Brace, Ohlins, Traqmate, Katana Supercharger, Shifter reinforced. Last edited by char : 09-02-2008 at 06:07 PM. |
#27 (permalink) |
Just changed my oil yesterday and did my 15,000 inspection and re-torqued everything. I made sure to check my alternator brackets and they are absolutely perfect. I bet for some reason you must have something flexing or improperly installed that is causing all your failures. I suggest you talk with Turbo Phil since he is the guy who made those brackets and did all the research.
#28 (permalink) |
A guy I was tracking with had a Katana. He complained that the brackets holding the supercharger broke. When he notified to S111, they sent him replacement brackets of the same design.
I understand that at some point in the run, S111 redesigned the brackets. Has anyone else has this problem? |
#30 (permalink) |
I have also been considering the Katana.
Aside from the base install and CharlieX tune, what else can be done to boost the output? Pully? Does a larger exhaust compliment it more then on a N/A car? Intake?
2005 Elise, Black. ![]() 5000k HIDs so far and plenty more to come
#31 (permalink) |
Liberté!
No problem with my Katana.
I did about 5000km and 3 track days since the install. Everything is working perfectly. Let us know why your alternator bracket keeps failing. There must be a reason. ![]() Regarding mileage. On the highway, I'm doing pretty much the same as stock. In the street always in boost, that's a different story. ![]()
BMWCCA Instructor VanDiemen F2000 2008 BMW 328Xi 2006 Lotus Elise Chrome Orange Ronin Katana
#32 (permalink) | |
Plug Whisperer
1 was to myself (I had the very first design attempt at these-Of course the stuff on my car is always at the prototype level ), 2 were to person referenced above (Still can't see why his car is having the issue), and 1 that installed the locking plate on the wrong side of the bracket, which obviously caused misalignment. IN the few instances where there has been a problem, Sector has been very good about getting parts shipped out. If there's a problem with a part, just drop them a line. That's part of the cool thing about using a place like Sector111. They provide great service ...Best, Phil
| '05 GG LSS Elise | A Track Chariot | BOE Flip-Top-Lid [FTL] | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08 If something ain't worth doing right, it ain't worth doing at all... |
#33 (permalink) | |
926
I tracked the car 20 plus days last year with no problems ... and just as much this year after adding the katana, with no problems other than the bracket. The car is still under warrrenty and gets regular dealer maintenance. Something must be causing this...
'06 Elise, SoY/Red, Touring, Sport, LSD/TC, Hardtop, Stage 2, 4tress/Schroth, Micro/Multivex, Alpine/Focals/JLsub, CF console & A/C surround, Ultradiscs/R4s/stl lines, Extinguisher, Tow Hooks, Blackwatch key, RTD Brace, Ohlins, Traqmate, Katana Supercharger, Shifter reinforced. |
#34 (permalink) | |
Plug Whisperer
You're right about the bolts-- which is amazing, as they're OEM grade bolts and the other two brackets I replaced (one of which was my own) were not due to breaking bolts. Yours is the only one that is doing that Since your case is so rare, I have to look at the installer or the car, as the problem seems to be unique to your car. I nkow it's not your use as there are several users that put 20 track days a year ont he kit, so that's not all that unusual...When I spoke with the installer, I found that the torque sequence wasn't being done correctly, which I later found was a problem with the instructions- not with the installer (However, that still doesn't explain why nobody else is havign the problem). Hopefully you now have the last set of brackets that you'll ever need. Your car has been a bit more of an annomoly rather than a massive issue. Nevertheless, I sure don't want you to miss a single day at the track due to something I could have done better! ![]() Best, Phil
#35 (permalink) |
Live to Drive
Hooray for Phil!!!
And sector111... who supplies useless goodies that I keep buying left and right ![]()
Driving a Lotus Exige with sticky... performance tires on icy roads or in standing water is about as much fun as walking a high wire treated with WD-40 - Car & Driver BWR supercharged... I suppose I "got the power" now?? |
#36 (permalink) | |
Plug Whisperer
#37 (permalink) | |
Plug Whisperer
You know with a 3.2" pulley, the correct tune, open up the intake with a 3" tube and a K&N filter, along aftermarket exhaust, you'll have your 30whp extra. You probably already have the exhaust- so just the pulley, tune, and intake...![]() Just say'in ....Best, Phil
#39 (permalink) |
Plug Whisperer
Not necessarily. Just a tune. How you get it is up to you. Charlie can tune it or you can tune it.
The EFI is just one route, and the route I chose because I'm into such things. Charlie probably has a tune in his database or can have him do a custom tune based on your mods or desires... I found nice torque and HP gains on a custom tune by dropping the pulley a touch (extra 1.5 psi boost) and tuning for the bolt-ons and still well within a "safe" zone on pump gas... Best, Phil
#40 (permalink) | |
New and Improved!
![]() I'm just glad there is an easy upgrade path for the Katana and Charlie's tunes to back it up.
